Adding a tailgate lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by oiwi, Mar 22, 2012.
  1. Mar 22, 2012 at 3:09 PM
    oiwi
    oiwi [OP] Member
    Hawaii
    2012 PreRunner Sport
    none....yet
    I have a 2012 tacoma with the backup camera in the tailgate handle. From what I've been told, when you convert the OEM taligate handle to one that locks such as pop & lock, the camera needs to move to the left side of the handle.
    The 2012 has a grid on the display on the mirror. Does moving the camera to the left affect the alignment of the grid?
    thanks
  2. Mar 22, 2012 at 3:17 PM
    Sullyman
    Sullyman Crusty ole' conservative fart
    Augusta, Georgia area
    2010 Black TRD Sport
    Cat-back exhaust, BluLogic, Back-up Camera, Extang Solid Fold Tonnau cover, Pop-n-Lock PL8521 electronic tailgate lock, Illuminated 4x4 switch, Smittybuilt Nerf Step Bars, Toyota bed mat, Tinted the windows darker, CB with custom fab'd antenna mount, Grillcraft grill, AFE Pro Dry S filter with secondary filter removed. Differential breather relocation mod. Bridgestone Dueler AT/Revo 2 tires Weathertech mats Spec-D HID Halo's Bilstein 5100s front set at 2.5" w/OEM springs 4-leaf TSB w/ SkyJacker add-a-leaf
    I have a 2010 with the pop-n-lock electronic actuator installed...didn't have to change my handle or move the camera to the left...
  3. Mar 22, 2012 at 3:19 PM
    Sullyman
  4. Mar 23, 2012 at 12:27 AM
    oiwi
    oiwi [OP] Member
    Hawaii
    none....yet
    thanks for the tip...i'll check it out.
  5. Mar 23, 2012 at 2:49 AM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
  6. Mar 23, 2012 at 9:00 AM
    oiwi
    oiwi [OP] Member
    Hawaii
    none....yet
    The kit looks like its "plug & play". But did you have to cut wires to install it? The product website doesn't give a whole lot of info on this.
    Thanks for the info guys I appreciate your help.
  7. Mar 23, 2012 at 10:26 AM
    S7ICKlVlAN
    Dave
    Hawaii
    2012 TRD Sport DCSB
    The kit is plug and play. I did shorten the harness from PnL so that I didn't have to bundle the extra up in my passenger kick panel. I had to re-crimp the terminals for the T-Taps (included in kit).
  8. Mar 23, 2012 at 11:19 AM
    oiwi
    oiwi [OP] Member
    Hawaii
    none....yet
    Thanks for the info & tips...I think I'll go with that instead of the "keyed" one.
  9. Mar 24, 2012 at 12:06 PM
    Sullyman
    ...and you shouldn't have to drill a hole in the tailgate...just run the wires with the harness for the camera....once you get it under your truck, cross it to the driver's side...up the frame and in the grommet under the driver's seat....If you do some searching you'll find other threads on this...one guy documented the install pretty well with pictures...
  10. Mar 25, 2012 at 9:33 AM
    oiwi
    oiwi [OP] Member
    Hawaii
    none....yet
    thanks sullyman! I'll do that.
  11. Mar 25, 2012 at 9:42 AM
    Holyfather
    Holyfather Well-Known Member
    Arizona
    2011 TX Pro TRD
    Front Bilstein 5100s @ 1.75"
    Another cheap theft deterant is just putting hose clamps around where the tailgate attaches to the bed
  12. Mar 26, 2012 at 8:38 AM
    oiwi
    oiwi [OP] Member
    Hawaii
    none....yet
    Does that secure the tailgate shut or just make it harder to remove?
  13. Mar 26, 2012 at 10:02 AM
    pdrunk
    pdrunk Well-Known Member
    2012 DCSB 2.7L
  14. Mar 27, 2012 at 5:49 PM
    oiwi
    oiwi [OP] Member
    Hawaii
    none....yet
  15. Mar 30, 2012 at 1:07 AM
    DCGirl
    DCGirl Well-Known Member
    California
    4x4
    I installed my clamps months ago and noticed today that my tailgate cables were loose like somebody possibly, I think likely tried to take the tailgate but failed. Both were loose. At first I wondered whether it happened while I opened and closed the tailgate but as I messed around with it myself it seemed unlikely. I have a pop and lock that I have been meaning to install and I will be installing this weekend since I am in a "bad area" where I know crackheads roam through so maybe this person could come back. Whatever I won't make it easy for them. SOB!!! I love my truck but hate how easy Toyota made it for potential thieves!
  16. Mar 30, 2012 at 1:38 AM
    rkaui14
    rkaui14 Active Member
    Hilo, HI
    2012 MGM PreRunner SR5
    Westin Platinum Oval Steps 21-2775, Undercover Classic, Tacoma sill protectors
    I did the hose clamp mod to temporarily secure the tailgate and make sure it didnʻt "walk away." Iʻd never heard of anyone stealing tailgates :eek: until I came to TW. Not that big an issue here on the Big Island as well. But for the stuff in the bed, bought an Undercover Classic. Holds everything pretty secure and goes completely over the tailgate so unless someoneʻs either breaking the gate or the cover, my hose clamp mod is useless :D
  17. Mar 30, 2012 at 8:21 AM
    drsus
    drsus Well-Known Member
    Los Angeles, CA
    4Runner TRDpro
    stock
    i installed the regular pop lock and u do move camera to other side and you can see it throws off the alignment slightly. I have the navi which doesnt display grid lines, but i can clearly see that I'm missing the corner of my bumper on one side now...which kind of blows for the cameras purpose.
  18. Mar 30, 2012 at 9:27 AM
    BradyT88
    BradyT88 ┌∩┐(◣_◢)┌∩┐
    Somewhere Offroad
    Mostly Stock '05
    I went with the dyno power tailgate lock. I found it for cheaper than the Pop n lock. It installs the same as the PnL and works fine. Came with way too much wire though. Didnt even use the short length of wire. The long one was plenty and would be even for a DC LB.
  19. Mar 30, 2012 at 11:25 AM
    oiwi
    oiwi [OP] Member
    Hawaii
    none....yet
    Thanks for the tips everyone...that helps.
    I put a piece of blue tape on the center of my bumper & I found that in the current configuration the grid is not centered anyway. I haven't installed the pop & lock yet but I am thinking about installed the power one. My only concern is if it fails for whatever reason I won't be able to open the tailgate to fix it.
  20. Mar 30, 2012 at 11:27 AM
    oiwi
    oiwi [OP] Member
    Hawaii
    none....yet
    I looked at the undercover & almost got it but seems kind of a hassle when I need to remove it. But I can see how it eliminates the need for the tail gate lock. I decided to go with the retrax....thanks for the tip.
