Adding HIDs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeS., Jun 18, 2008.
  1. Jun 18, 2008 at 6:04 PM
    MikeS.
    MikeS. [OP] Well-Known Member
    Far Eastern WVa
    2008 DC LB 4x4 in Speedway Blue.
    Undercover bed topper, Nerf style step bars, Python alarm, Ham radio with 250 watt amp and chrome wheel well bling.
    So how do you change to HIDs? Is it a bulb swap with the OEM headlights? I know you have to add a ballast. Is the wiring just swapped out? Is the factory wiring on a 08 able to handle HIDs?
    Has anyone done a write up on doing this mod? I couldn't find one as a sticky.
    Thanks y'all
  2. Jun 18, 2008 at 9:47 PM
    hail-bop Command
    hail-bop Command Well-Known Member
    I Don't Crawl I Haul A$$!
    05+ Tacomas use an H4 head light bulb.... You can look on EBAY for an H4 HID Kit. This kit comes with everything you need to do a full HID conversion. The kit comes with 2 ballats and that plug in to your factory light harness and 2 H4 hid bulbs that plug in to your factory light housing.... Also keep in mind that with the HID kits you get what you pay for... I would recommend you get a Dual Beam Kit (Means you have high & low beam light) made my McCulloch or Phillips available at www.xenonpros.com they have both kits at good prices with plenty of Kalvin ratings to chose from.
  3. Jun 18, 2008 at 9:51 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
  4. Jun 18, 2008 at 9:56 PM
    hail-bop Command
  5. Jun 18, 2008 at 9:57 PM
    hail-bop Command
    Looks good though:)
