Adding SS extended brake lines ... how much fluid is needed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PreRunner, Mar 29, 2010.
  1. Mar 29, 2010 at 5:42 PM
    PreRunner
    PreRunner [OP] Well-Known Member
    for the install? It's a brand new truck and want to stick with OEM fluids. just wanted to know how much fluid i should pick up from the dealer before having shop do the install. thanks.
  2. Mar 29, 2010 at 6:04 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Just get a bottle of dot 3 fluid from someplace. It won't take much though.
  3. Mar 29, 2010 at 6:18 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    +1
    You'll probably use more in a mighty vac bleeding the brakes than what you actually put in the truck.
  4. Apr 5, 2010 at 8:23 PM
    taco_man
    taco_man Well-Known Member
    Austin
    Houston
    09 texas edition
    Borla exhaust, K&N intake, Full sound system
    so i need 2 bottles for when i change out my brake lines???
  5. Apr 5, 2010 at 8:46 PM
    dexterdog
    Oly WA
    2012 F150
    If a shop is doing the install why are you worrying about brake fluid? 1 bottle will be plenty if you insist on buying from the dealer.
  6. Apr 5, 2010 at 9:36 PM
    taco_man
    Austin
    Houston
    09 texas edition
    no im doing the install myself and i have no idea how much i need.
  7. Apr 5, 2010 at 9:47 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Get two, better to have more than not enough.
  8. Apr 5, 2010 at 9:48 PM
    dexterdog
    Oly WA
    2012 F150
    buy two bottles of brake fluid. Use a mityvac if you got one or go ghetto and use a piece of tubing on the bleeder valve and the other end into glass jar filled with brake fluid.
  9. Apr 6, 2010 at 5:07 AM
    PreRunner
    had both front and rear stainless lines installed yesterday. they used about 85% of the bottle of toyota brake fluid i got at the dealership. It took 9 about ounces.
  10. Sep 6, 2011 at 9:56 PM
    DreDog
    DreDog Well-Known Member
    Andrew
    What did they charge total? Including installation
  11. Sep 6, 2011 at 9:59 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    He's banned now, and unable to answer you.... and i'm unsure of what your referring too
