Adding steering wheel controls
Discussion in 'Audio & Video' started by TacoFry, Jul 11, 2013.
  1. Jul 11, 2013 at 11:30 AM
    TacoFry
    TacoFry [OP] New Member
    Hey,
    I have a 2012 Tacoma and wanted to add the steering wheel control buttons to my truck. Has anyone done this or sourced a location to get the oem ones?
    Thanks
  2. Jul 11, 2013 at 11:32 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Would have to just buy a new steering wheel that has the buttons, as well as the wiring that connects to your HU...
  3. Jul 12, 2013 at 4:29 AM
    Frogsauce
    Frogsauce Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    I looked into this also, but it would require you to buy a clockspring.
    If you do it, post up how you did it. I might take another look at that route.
  4. Jul 13, 2013 at 11:28 AM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    For older trucks you need steering wheel with controls and new clock spring. Wiring is there as long as its a pre runner in older models. After a certain year they started using the same clock spring in all trucks, guessing it was cheaper. Best bet is unplug your battery and pull off the airbag and see if you have the open port to plug into your clock spring.
  5. Jul 16, 2013 at 7:54 PM
    TacoFry
    The wiring is there from my stereo to the steering column, I was told by someone that the clock spring was already there, since it was the same one that serves the cruise control switches. I looked online and four the switches for like $300, but that is a bit steep for a nice to have
