Adding the towing hitch, have the dealer do it?
Discussion in 'Towing' started by akjone02, Aug 4, 2010.
  1. Aug 4, 2010 at 12:29 PM
    akjone02
    akjone02 [OP] Active Member
    Andy
    Capital Region NY
    So I'm getting my Tacoma today. It's been about a week since I went in to first pick it up, but it's been delayed over and over again because I asked the dealer to install a towing hitch and they keep running into problems (sent the wrong one, mechanic out sick, sent the wrong one again, etc). Finally I just said heck with it, I'll do it some other time, I want my truck.
    Now my question is, do I have to bring the taco in to another local dealer and have them install a trailer hitch for me, or is this something I could do myself? Is this something I shop around for at auto shops in the area, or is it a dealer only buy/install?
    For some info, I've got the 4x4 access cab 4 cylinder manual. I'm talking about towing only small stuff (like a jetski), so don't worry about my lack of a v6. I have no experience working on cars :) Thanks in advance.
  2. Aug 4, 2010 at 12:34 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    It's fairly easy to do yourself with basic mechanics tools (metric socket set, torque wrench, etc.) but if you don't feel comfortable doing it or don't have much experience then you can always go to uhaul. They sell and install hitches and the wiring.
  3. Aug 4, 2010 at 12:34 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    They are pretty easy to install yourself. Or call a buddy over and split a 6-er on the install.
  4. Aug 4, 2010 at 12:37 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    x2. Very easy install. You used to have to drill the frame but now most aftermarket hitches use existing holes in the frame. Hardest part is the wiring unless you're getting the plug-n-play 4-prong wiring harness.
  5. Aug 4, 2010 at 1:35 PM
    Primersinmyshoe
    Primersinmyshoe Old Sheepdog
    St. Louis, MO
    gray, shiny, dependable
    Glock 36, spare mag
    Go to U-Haul and have them do it.
    Do you have a tranny cooler yet?
  6. Aug 4, 2010 at 2:05 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    The after market ones are simple to install yourself if you have basic and tools and a driveway. If not, as was mentioned, Uhaul sells them and installs them. Probably cheaper than a dealership as well.
  7. Aug 4, 2010 at 5:10 PM
    Taco.Tim
    Taco.Tim Well-Known Member
    Tim
    Georgia
    2010 Buhlue Access Cab 2WD
    Looking!
    Very easy to do. Wiring is simple if you use the plug-in harness, but it just does tail and brake lights. Four 12mm x 1.25 bolts, about 25 to 35mm long will do the frame bolts (nuts are already welded to frame).
    Two bolts at the bumper, I used 3.5" long 3/8-16 bolts. Little plastic caps on the bumper are easy to pry up.
    Mine was a bit harder to do being a cheapskate, and using a Gen 1 hitch that I had laying around to put on my Gen 2 truck.
    Tim Glover
  8. Aug 5, 2010 at 5:58 AM
    akjone02
    Andy
    Capital Region NY
    Thanks for all the responses. I'll definitely go ahead and try to install it myself then. I'm handy enough with tools, just not experienced with cars in general and I hate welding. I was worried installing the hitch would involve the latter. If it's just bolt on then I can do it myself.
    In a followup set of questions, is there a particular hitch I should look for, or maybe a particular quality in a hitch?
    Also, someone mentioned a transmission cooler above. Can I get one of those for a 4 cylinder manual? I know they're available for the v6 automatic but (again, inexperienced with cars) I didn't think manuals used them.
  9. Aug 5, 2010 at 6:19 AM
    Pugga
    Massachusetts
    Look for a quality brand of hitch - Uhaul, Reese, Hidden Hitch, something that is proven when it comes to towing. You can pick them up through a local autoparts store or online at JCWhitney, Autoanything, etc. If your trailer doesn't have brakes on it, you can get away with a 4-prong wire harness, these are available as a plug-and-play add-on and plug right into your tail lights, no soldering or wire splicing required. If your trailer has brakes, you'll need a 7-prong wire harness with a brake controller. This gets a little more involved but still isn't terrible. I haven't installed one of those in a long time so they may make a plug in model by now for all I know.
    If you're just towing light things like a jet ski, you'll be fine without a transmission oil cooler, especially with a manual transmission. Don't get me wrong, they're not a bad idea and couldn't hurt, but they're really needed for towing heavy loads for long distances. They're also a more welcomed addition to an automatic transmission because of the heat the torque converter creates.
  10. Aug 5, 2010 at 6:21 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    No cooler for a manual.
    I have several hitches from Wal-mart with no issues. As long as it's rated for your towing capacity or higher, you should be good.
  11. Aug 11, 2010 at 3:09 AM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    If all your going to tow is a jet ski you don't need a hitch. You can tow that with a ball on your rear bumper.
  12. Aug 29, 2010 at 2:22 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Just want to bump this up for a question...
    Will U-haul install a hitch that you buy from somewhere else? Also, will they offer the $5 lifetime warranty for it also?
  13. Aug 29, 2010 at 2:30 PM
    Primersinmyshoe
    St. Louis, MO
    Glock 36, spare mag
    :eek:
    Let me guess - probably not.
  14. Aug 29, 2010 at 2:32 PM
    Incognito
    VA
    Oh come on, the thread isn't THAT old... :p
    Just wanted to see if anybody else had done what I was thinking about.
  15. Aug 29, 2010 at 2:35 PM
    Primersinmyshoe
    St. Louis, MO
    Glock 36, spare mag
    Would you take your own steak to a restaurant and just pay to have them cook it for you?
  16. Aug 29, 2010 at 2:40 PM
    Incognito
    VA
    No, that's a bit easier than installing a hitch... :eek:
    The more I think about it, it was a stupid question. I looked online as to which hitches they had available for sale, and they had a Class III tubular-framed hitch... Any pros/cons to that as opposed to a conventional square-framed hitch?
  17. Aug 29, 2010 at 3:38 PM
    Barnone
    Barnone Guest
    Nope, either one is fine. What ever floats your boat.
  18. Aug 29, 2010 at 5:30 PM
    Incognito
    VA
    Got it, thanks Vince.
  19. Aug 30, 2010 at 6:15 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    The Uhaul hitch is made by Valley, it hides the best and seems tough, why not just have them put on their hitch? Tell the tech to not throw away the bumper caps, as they can be trimmed and hide the bolts nicely.
  20. Aug 30, 2010 at 6:52 PM
    Incognito
    VA
    That sounds good, didn't know about the quality of their hitches compared with others. Thanks for the info!
