Adding Truetrac to Sport with Auto LSD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Friedtacolover, Sep 9, 2017.
  1. Sep 9, 2017 at 11:12 AM
    Friedtacolover
    Friedtacolover [OP] Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Dont really want to give up my 2015 Sport 2wd thats close to being payed off. Looking for a little more off road capabilities like sand, mud. Im currently going to upgrade my suspension to ome's and 2" aal. I already have A/T tires. Would adding a Detroit True Trac be worth it for what im looking for? Or is it the same as my auto lsd button
    I understand a 4x4 or off road tacoma is better for this but if i want to keep what i have what are my options.
  2. Sep 9, 2017 at 12:00 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The truetrac is much better than the auto LSD and will add traction, it is the best bet short of a locker. I've run them in previous Toyota trucks. While the auto LSD is helpful, it is a system that responds to an already slipping wheel and tries to brake it to limit the spin as the open diff will direct power to the wheel with least traction. The trueurac will seamlessly apply power to both wheels and not have to react after traction has been lost. I wish you could have the truetrac and the locker on these trucks. The only drawback of the truetrac is that if you get into a situation where one wheel is in the air, the ability to transfer power is lost, however your auto LSD would then work with the truetrac to transfer power to the wheel with traction.
    Will it be enough really depends on what kind of mud you get into. Keep in mind airing down your tires creates a wider footprint which will help you in both mud and sand.
    Lord Helmet and JoefromPTC like this.
  3. Sep 9, 2017 at 12:07 PM
    Friedtacolover
    Travis
    Ontario, Ca
    Crashnburn 80 you answered my question perfectly and gave me the info i wanted to know thanks! Looks like ill be looking into a true trac to cover my needs.
    Lord Helmet and crashnburn80 like this.
  4. Sep 9, 2017 at 1:28 PM
    Charger92
    Charger92 Built for pure function!
    British Columbia Canada
    2007 Tacoma double cab long box
    I had a 92 Ramcharger and put a true trac in back. I don't know if it was wheel base, design of the rig with the extra SUV weight, wider track width or what, but that rig would wheel the crap out and above in 2wd over my Tacoma in 4wd any given day.
    I should have never sold that rig.
    I'm going the same route in my Tacoma, true trac in back and hopefully some type of e-locker in front.
    Maybe I can get the Tacoma to get wheeling closer to the Ramcharger. Never had any ill effects with the true trac. I like em.
    dirtnsmores likes this.
  5. Sep 9, 2017 at 1:31 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    I've heard the TRUTRAC is not good in snow, not sure if it's true or not.
    Friedtacolover[OP] likes this.
  6. Sep 9, 2017 at 1:37 PM
    Friedtacolover
    Travis
    Ontario, Ca
    So your running sport or sr5 then? And a 4x4? This gives me some great confidence in keeping my current setup rather then buying a new truck already equiped.
  7. Sep 9, 2017 at 2:45 PM
    Charger92
    Running a DCLB 4x4 sport with the factory limited slip. On the Tacoma I have a canopy top, hi-lift, axe and shovel, Engel fridge, 2 jerry cans, tools and fluids all for extra weight and still crap in comparison offroad. Had rear end shop go through the tacos rear LSD clutch packs and they are good.
    After having the Ramcharger wheel so great for 15yrs, maybe I expect more out of the Tacoma. But as the family grew into 4 doors and needing more room in back along with the following and being a Toyota, the Tacoma seemed the next best choice.
    I thought going more modern with all the computer help now, the wheeling would improve.
    Like I said 2wd in the RC with the true trac was way better than my stock Tacoma in 4wd. Steeper climbs, better in the rock gardens, went through deeper snow, hookup on pavement in the rain and any on road felt great. No clicks, no wheel hops, no chirps around corners or anything I'll. Nothing also to ware out like a LSD.
  8. Sep 9, 2017 at 2:47 PM
    dumprat
    dumprat Well-Known Member
    Southern B.C.
    08 tacoma DCLB
    TSB leafs, weather techs, ram mount,jack&shovel mount, and more to come.
    People say the full Detroit is super dangerous on ice and snow. I call bullshit. I have had two of them in rigs and never had a problem. One was an early bronco one was a TJ unlimited. No worries on snow. Ice required some driving as it will kick sideways. No worse than any other short wheelbase rig and actually better and more predictable than one with an open diff.
  9. Sep 9, 2017 at 2:57 PM
    Charger92
    I heard the same and have driven a full locked rear on icey switch back roads here in BC not cool always wanting to push you around on slight off camber.
    Learned to take my time and aways kind of shit but did it.
    Once I had the true trac driving was actually fun. I could slide it where I wanted, let off and easy on the gas no icey off camber dog tracking with back end wanting to come around, always felt in full control.
    Depoxy likes this.
  10. Sep 15, 2017 at 7:24 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    looking at the web site for the eaton trutrac rear diff and dont see any listings for a 2nd gen 2015 tacoma?
    Do they make one? can someone point me in teh right direction or have a model #.
    i have the 2015 double cab 4X4
    The catalog only lists up to 2005
    1995
    - 2005
    8.4" Tacoma, Tundra, T-100
    1.29"
    30 spline
    3.54 - 5.29
    Lord Helmet likes this.
  11. Sep 15, 2017 at 7:27 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
  12. Sep 20, 2017 at 11:22 AM
    blksandpearl2010
    blksandpearl2010 Yeah, yeah...
    NC
    2010 LB trdSport
    old man emu, nitrocharger shocks, darkar leaf springs, bbs wheels, access tonneau cover, laufen AT 275/65/18,
    Look on 4wheelparts.com usually can find it.
  13. Sep 21, 2017 at 6:27 AM
    babylon5
    David
  14. Sep 22, 2017 at 7:53 AM
    babylon5
    David
    Any recommendations on drivetrain shops in canada/ontario or close the the border that could do the installation of the truetrac rear?
  15. Sep 22, 2017 at 12:10 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    3rd Gen Tundra WCP TRD OR I-Force Max
    Any quality drivetrain shop should be able to install it with no issues.
