adding weight to tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by makikid808, Oct 26, 2011.
  1. Oct 26, 2011 at 9:01 PM
    makikid808
    makikid808 [OP] They call me unko
    Kamaki
    Kula,Maui
    98 Tacoma sr5 4x4 5VZ-FE 3.4 manual
    fabtech 6" lift, all-pro 5" rear lift springs, 17x9 ATX slot, 295/70/17 nitto trail grapplers, Borla catback exhaust system, K&N FIPK, bully nerf bars, wet okole seat covers, tints (factory tint plus 5 on back 35 on front), sounds(kenwood deck, kenwood IE speakers all around,kenwood 720W amp for mids, kenwood 1000W amp pushing orion 12" sub), LED dome map and door lights
    im planning on adding on some body armor but was thinking about how would this effect the truck itself and its performance. i see that people add gears when they put on bigger tires because of the weight. would this be kind of like the same thing with the body armor weight?
  2. Oct 26, 2011 at 9:20 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    weight is not the main reason people change gears when they get larger tires. Adding larger tires has the same effect as lowering the gearing (higher top speed/less torque and acceleration). Putting in higher gears reverses the effect of larger diameter tires.
    As to your question on the effects of weight on handling, i don't know, but it's a good question. It would be a good idea to put in stiffer suspension if you are going to put on a lot of weight.
  3. Oct 26, 2011 at 9:25 PM
    makikid808
    Kamaki
    Kula,Maui
    ohh ok. but the suspension was going to be the start of mine. i was just looking into the future for this reason of the whole weight thing
  4. Oct 26, 2011 at 9:59 PM
    x2468
    Likely effects will be slower acceleration, lower MPG and if you don't put stiff enough suspension, excess body roll (lean in turns) and dive under braking. But I dont have anything that adds weight to my truck yet so I can't tell you for sure how noticeable it would be.
  5. Oct 26, 2011 at 11:59 PM
    makikid808
    Kamaki
    Kula,Maui
    Yea that's what I was thinking. So the only thing I came up with that I THOUGHT would of helped was gearing but like said above that's not the reason people put in gears
  6. Oct 27, 2011 at 12:01 AM
    makikid808
    Kamaki
    Kula,Maui
    I think this may have been a stumping question hmmmm
  7. Oct 27, 2011 at 12:02 AM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    regearing has more to do with physics and torque and the moment of inertia. its pretty difficult to explain over the interwebs.
    you may notice a little bit of difference with more weight, but nothing like adding larger tires
  8. Oct 27, 2011 at 12:06 AM
    Maverick904
    Kameron
    Northeast Florida
    if you are not familiar with physics..moment of inertia can be roughly described as a value that has to be taken into consideration when dealing with torque and slowing down or speeding up a rotating object.
    with bigger tires..more mass is further outside the center of the tire than it would be for smaller tires..this increases the moment of inertia which means more energy is needed to start rotating the tires..
    by regearing you increase the torque you have, which allows for the tires to be turned with less energy. making your engine work less and somewhat more efficient.
    hope that makes SOME sense.
    so just the extra weight of a bit of trail armor shouldnt be horribly noticeable in order to regear..atleast..i wouldnt think so.
    but you will probably see a small decrease in MPGs
  9. Oct 27, 2011 at 12:07 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Figure with armor you may add what, 300lbs to the truck?
    Drive around with 2 passengers, do you notice the added weight?
  10. Oct 27, 2011 at 12:47 AM
    makikid808
    Kamaki
    Kula,Maui
    Your right. I guess I didn't think about it that way. Kind of the same fundamentals basically. Hey relentless I'm gonna send you a PM. Want a set of those sliders....
  11. Oct 27, 2011 at 12:52 AM
    makikid808
    Kamaki
    Kula,Maui
    Yea I see where your getting at. This helps to break down the differences.
