Additional proformence mods
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MadMikMills2015, Sep 30, 2016.
  1. Sep 30, 2016 at 6:59 PM
    #41
    MadMikMills2015
    MadMikMills2015 [OP] Member
    Michael
    Pennsylvania
    2010 sc Tacoma off road 6 spd
    Spectre cold air intake Urd 2.85 sc pulley swap Trd super charger Jba equal length shorty headers Trd catback exhaust Trd engine tune Urd stage 3 clutch Urd light weight fly wheel
    Did it effect your tune? That's my fear. From what I read, the down stream o2 is needed to retune the fuel/air ratio
  2. Sep 30, 2016 at 7:18 PM
    #42
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    http://www.rceng.com/technical.aspx?UserID=41059431&SessionID=PkGagAdpAQzfCqNjYRuX
    Using the calculator at the bottom of the page, you can put in the numbers to determine how much B.H.P. your currently sized injectors can handle.
    I did calculations with BSFC at .60 and IDC at .80. Roughly 350 B.H.P. before those injectors are maxed. Then again with BSFC at .55 and IDC at .90, for a little wiggle room. Roughly 390 B.H.P. before maxed.
    Using a 12 percent drivetrain loss, you can see, that the injectors will not safe handle 382 whp. Unless that shop told you Brake H.P.
  3. Sep 30, 2016 at 7:52 PM
    #43
    MadMikMills2015
    Michael
    Pennsylvania
    Cool, I have been looking for a tool like this. Yeah it's not whp.
  4. Sep 30, 2016 at 8:24 PM
    #44
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    It's been a while since I installed, but I'm pretty sure the read o2 sensor is between the front and rear cats. The new y pipe deleted the rear cats but had a spot for the sensor. Because the change is all downstream of the sensor it didn't change much of anything.
  5. Sep 30, 2016 at 8:25 PM
    #45
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :thumbsup:
    Always need a refence point to start from, that way we're all on the same page.
  6. Oct 1, 2016 at 5:26 AM
    #46
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    I think Brian Mauck was seeing close to ur numbers with your bolt ons.
  7. Oct 1, 2016 at 5:27 AM
    #47
    inwood customs
    Dave
    Ur hitting 10psi with a 2.85?
