adjust caster
Discussion in 'Suspension' started by grexwilbur, Feb 6, 2011.
  1. Feb 6, 2011 at 7:14 AM
    grexwilbur
    grexwilbur [OP] Member
    wilbur
    cape cod
    Tacoma sport
    TRD exhaust,Icon coil overs, Remore res icon rear,Alcan 10 leaf custom rear leafs,pro comp wheels, 285 70 17 Mickey Thompson mtz, afe air
    Are there any caster settings to help w rubbing so i wont have to trim so much? I have 3 inch lift and 285 70 17. Rubbin bad on plastic fender flairs back of front wheel. And sum on cab mounts..dealer said they are set to factory spec as far as alignment goes..what is factory and where should i have it set before i trim?
  2. Feb 6, 2011 at 7:20 AM
    Brunes
    Brunes abides.
    Rotorhead
    I wouldn't mess with the caster blind nor would I mess with it just to avoid trimming. If the truck drives well now- adjusting the caster could affect the drivability.
    Factory is like 2.4-3.1* Toe and Camber = or close to 0*
  3. Feb 6, 2011 at 7:26 AM
    grexwilbur
    wilbur
    cape cod
    Tacoma sport
    Does anyone have any pics of how they trimmed plastic rear portion of flair and still look good?
  4. Feb 6, 2011 at 7:46 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    i think this is what you are talking about. here are the before and after pics of the trimming on my truck:
  5. Feb 6, 2011 at 10:35 AM
    grexwilbur
    wilbur
    cape cod
    Tacoma sport
    That is exactly what im talkin bout..thank u. Did u trim cab mounts look like ya did. If so when u welded patch did u remove rubber mounts first or do in place?
  6. Feb 6, 2011 at 10:36 AM
    grexwilbur
    wilbur
    cape cod
    Tacoma sport
    One more dumb question...what type of saw or cutter did u use on plastic part?
  7. Feb 6, 2011 at 11:24 AM
    NetMonkey
    Geogetown, TX
    i didnt actually do the work. i had a guy at a local fabrication shop do it.
    yes, i did have the cab mounts chopped and welded. he did the cutting and welding in place. i doubt he removed any rubber mounts.
    i am not sure what he used to do the cutting on the fender parts. the fender part probably took some sort of saw and the inner plastic could be cut with a knife or scissors.
  8. Feb 6, 2011 at 12:34 PM
    Brunes
    Brunes abides.
    Rotorhead
    My dremel with a large cutting wheel worked fine for the plastic parts. Quick once over it a polishing bit took the right edges and burrs off.
