adjustable coil overs
Discussion in '1st Gen. Tacomas (1995-2004)' started by kvatland127, Jan 14, 2014.
  1. Jan 14, 2014 at 9:38 AM
    kvatland127
    kvatland127 [OP] Well-Known Member
    oregon
    04 tacoma 2.7
  2. Jan 14, 2014 at 9:39 AM
    kvatland127
    oregon
    04 tacoma 2.7
    All i need is the fronts
  3. Jan 14, 2014 at 10:15 AM
    Exhaust
    Exhaust Well-Known Member
    Erik
    Wharton State Forest
    02 DC TRD
    Extended breather, Grey Wire mod, Tundra brakes, Rockford-Fosgate sound, General Spring HDs, 5100s + 880s, Heated Seats, TRD Supercharger, 2.1 Pulley, URD 7th Kit
    No. The mounting points are different, that's why the first and second gens are always separated in stores.
  4. Jan 14, 2014 at 10:18 AM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    They are? When did they change the dimensions of the mounting holes on the strut towers?
  5. Jan 14, 2014 at 10:21 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    in 05 when they switched to 2nd gens...
  6. Jan 14, 2014 at 10:23 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Yeah huh, :facepalm: I'm surprised it is far enough off to not slip in as they both use a 3 bolt top hat.
  7. Jan 14, 2014 at 10:37 AM
    bellassaiw10
    Currituck NC
    The bottom uses different mount also I don't think a 2nd gen shock body will fit
  8. Jan 14, 2014 at 10:42 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    No! The 6 lug, '04 front suspension is very different from the '05+ IFS setup. Also, the rear shocks wont work either because the top mounts are different.
  9. Jan 14, 2014 at 11:43 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    top hat is pretty much the same..what is different is the 2n gen shocks are longer and have the long tiny extension on the lower mounts to clear CVs.
    they won't fit.
  10. Jan 14, 2014 at 11:44 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    So would this work if he were lifting then or is it too long to fit?
  11. Jan 14, 2014 at 11:46 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    still too long. Geometry is all sorts of different.
  12. Jan 14, 2014 at 11:52 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Well that's a bunch of gay ballz
  13. Jan 14, 2014 at 1:02 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15Âş clocking
    Like everyone said, the geometry is way different between the generations, BUT...
    you can use the coil spring from a second gen on a 1st gen, even though it's longer.
  14. Jan 14, 2014 at 2:00 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Additionally, the top hat on a 2nd gen has a substantially larger bolt pattern, like 3/8-7/16 more between bolt holes. They will not interchange.
