Adjustable Tire Deflator Kit
Discussion in 'Off-Roading & Trails' started by SCSPerformance, Mar 14, 2013.
  1. Apr 25, 2013 at 8:39 PM
    #41
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    I would go with the orange package 6-30 PSI
  2. May 9, 2013 at 9:24 PM
    #42
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    IME, it's aluminum valve caps that cause problems due to corrosion of the fine threads. I bought a used car with some that were a PITA to remove.
    I use chromed brass caps without problems on both brass and aluminum threaded stems. The caps have a gasket to seal the stem from water or debris, and always come off if you put a dab of anti-seize compound on the threads. I've had plastic caps crack or disappear, leaving the core exposed. I think we all know what happens when the core is exposed.
  3. Jun 28, 2013 at 2:29 AM
    #43
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    DeBadged, Toyota Bedmat, TRD exhaust, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, Bora wheel spacers, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, {REMOVED-Goodyear Duratrac 285/70-17 LR-D & REMOVED-Procomp 7089 wheels}, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, Back-Up light mod, ECGS bushing, Redline Hood Struts, Leer 100XR, BFG TA KA2 265/70-17 LR-C, FJ Steel wheels
    I use the ARB EZ deflator. It works well and is fast. BUT I wonder how fast it really is overall. Only 1 wheel at a time and a little setup per wheel. I'm thinking of getting a set of Stauns; these sound more convenient.
    Then I air up with a ARB portable - very fast. Less than a minute per tire. I use the ARB inflator - very convenient.
    http://store.arbusa.com/ARB-Portable-High-Performance-12-Volt-Air-Compressor-CKMP12-P3573C9.aspx
    http://store.arbusa.com/ARB-TIRE-INFLATOR-WITH-GAUGE-ARB605US-P21342C9.aspx
  4. Jun 28, 2013 at 7:54 AM
    #44
    BradyT88
    BradyT88 ┌∩┐(◣_◢)┌∩┐
    Somewhere Offroad
    Mostly Stock '05
    That EZ deflator is super fast! I have some of the thread on ones and I'd bet you could deflate all 4 tires faster with the EZ deflator doing them one at a time then I can doing all 4 at once! I was surprised by it when I got to use one once. The only downside is that you wear out the seals in the valve core every time your remove them so it is a good idea to carry spare valve cores on you.
    What do you deflate your tires to and then reinflate them to? I have the same compressor (only mounted instead of portable) and it takes me like 4-5 minutes per tire. I take my 33's from 15-20 psi offroad to 42 psi on-road.
  5. Jun 28, 2013 at 10:54 AM
    #45
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    That's good to know about the seals. I do have some spares in my tire plug kit.
    I have a dclb - I run 32 in front & 28-30 in rear. (I still need to do my chalk test. There's people with Duratracs that run 32/24 based on a chalk test)
    The last few times I aired down for comfort on rocky roads was around 20 front & 18 rear. I played with different pressures. That's what's nice about the ARB deflator.
  6. Jun 28, 2013 at 1:25 PM
    #46
    Chickenmunga
    Chickenmunga Nuggety
    Hillsboro, Oregon
    08 TRD Offroad DC 4x4 (read the build)
    Since it wasn't answered...
    TPMS are a plastic piece that goes inside with a metal shaft. There's an outer metal shaft as well, so it's a bit thicker than standard, but if you are going to hit it, you will still shear it. I've done it before on the Naches Trail, you just have to get that special rock.
  7. Jun 28, 2013 at 1:28 PM
    #47
    ruggedT
    ruggedT The Sticker Guy Vendor
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    I have a set of Trail Head deflators. They work well, but as with any deflator like that the tire needs a certain pressure to start them.
