Adjusting Fox 2.0 Performance Series
Discussion in 'Suspension' started by Polarisman, Jan 1, 2013.
  1. Jan 1, 2013 at 12:24 PM
    Polarisman
    Polarisman [OP] Active Member
    Vidalia,LA
    07 TRd Sport Double Cab 4X4 with Factory 20's
    Factory Toyota 20 inch rims, on Bridgestone Tires In channel Ventvisors, Window Tint, Bed Mat, Running boards
    Hello everyone,
    I have the fox 2.0 Performance Series coilovers on my 2011 Tacoma. I want to adjust the driver side shock to compensate for the tacoma lean. Im planning on going with 1/4 of an inch higher. I have spanner wrenches, but my question is: How and what to measure to reach this height? What reference points could I use? Thanks, I"m kinda new at this. Here is a pic of the shocks (not mine).
    Thanks again,
  2. Jan 1, 2013 at 4:23 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Hub to fender. Install the coilovers. Let it settle. Then adjust it. Jack it up and leave it at full droop is the easiest way to turn the collar.
  3. Jan 1, 2013 at 4:28 PM
    IluvTEA
    IluvTEA Well-Known Member
    South Dakota
    '10 DC LB 4x4 SR5 Super White
    Cooper ST 265/75/16 on Flat Black TRD OR wheels, window tint, blacked-out badges, front mudflap trim, BHLM, Base Black Rear Bumper Swap, Color-matched grille, Custom Relentless Fab plate bumper powdercoated flat wrinkle black and "TACOMA" backlit with Drunknsloth LEDs, Camburg 2.5" coilovers, LR UCAs, Power sliding rear window, Back-up camera anytime, FX-R projectors/Morimoto 3Five Ballasts/D2S bulbs 5000K, Black WeatherTechs, heated TRD seats with Roadwire Graphite Leather, OEM Roof Rack, front mud flap delete, Black Level 8 Guardians, TreadWright 285/75/16 with KG ...
  4. Jul 19, 2014 at 5:58 PM
    sirsaechao
    Tim
    CA
    Yes turn the collar up go preload the spring = more lift.
  5. Feb 23, 2017 at 12:49 PM
    bilplat
    bilplat Simply Driving Into Mordor
    Bill
    Denver, CO
    '17 White A/T 4x4 TRD OR DCSB
    ARE Hard Top
    I've heard that you can damage the aluminum threads by not removing the spring preload on the adjustment ring before turning it. There are not holes for spanner wrenches so you can't use those, and it seems a bit out of the question to turn the adjustment ring by hand if there is a 600 - 700 lb/in spring exerting force on it.
  6. Feb 24, 2017 at 10:04 AM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Yea, I would contact the vendor about the best way to adjust these. The 2.0 fronts aren't like most, and people have stripped theirs trying to adjust them like they are.
  7. Feb 24, 2017 at 10:07 AM
    bilplat
    Bill
    Denver, CO
    ARE Hard Top
  8. Feb 24, 2017 at 4:01 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Does anyone know the exact spring rate of these? I would assume 600-700 as mentioned above just by how they feel driving, but I'd like to get a real #.
    I've adjusted them by hand by using a spring compressor first.
  9. Sep 2, 2017 at 2:40 PM
    Sodom
    Sodom Well-Known Member
    New England
    2001 Xtra Cab SR5 4x4 3.4L 5-Speed Gold
    Fox 2.0 IFP Coilovers, Fox 2.0 IFP Shocks
    What spring compressor did you use? I have one, but it doesn't fit between the coils.
  10. Sep 2, 2017 at 6:25 PM
    Sterling_vH111
    Sterling
    socal
    I'm pretty sure I just rented a spring compressor from an auto parts store. Was almost 2 years ago I did that.
  11. Sep 2, 2017 at 6:26 PM
    Sodom
    New England
    Alright, thank you.
