adjusting headlight beams
Discussion in '1st Gen. Tacomas (1995-2004)' started by houndsmen, Oct 19, 2009.
  1. Oct 19, 2009 at 6:28 PM
    houndsmen
    houndsmen [OP] Well-Known Member
    Hi,
    I am new to tacomas and i recently just bought one and lifted it! well the back stayed a little higher than the front so my lights are pointing down. my tacoma is a 2001.
    How do i adjust my headlight to angle upward? i know there are two screws near the bottom but im not sure which ones exatcly??? and do i have to remove my grill in order to acess these screws?
    Thanx
  2. Oct 19, 2009 at 7:40 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
  3. Oct 19, 2009 at 9:58 PM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    can be tricky, take your time
  4. Oct 22, 2009 at 10:34 AM
    houndsmen
    ok so i know where the screw is do i need to take off my grill in order to get the the face of the screw?
  5. Oct 24, 2009 at 6:46 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    on my 03 the adjuster is inside the engine bay and is supposed to be 4mm socket its on a long piece of threaded stock with a 4mm hex on the end 01 may be different but I dont think so I dont have to take anything apart to adj. I did have to move the battery over slightly but the tightened down in that place so I could make quick adj if I needed to
  6. Oct 24, 2009 at 7:29 AM
    ETaco23
    Evan
    PNW
    ^^Yep, its the same. At end of the threaded stock you will see that its hexed so it can fit a socket.
  7. Oct 24, 2009 at 8:25 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    A 5/32 socket fits about perfect if you don't have a 4mm. I adjusted mine a few weeks ago when I lifted the front a bit.
