adriancast build
Discussion in '2nd Gen. Builds (2005-2015)' started by adriancast, Jul 14, 2013.
  1. Jan 6, 2016 at 4:08 PM
    #421
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    I recommend lots of anti seize when you reassemble your lower control arm bushings. Will help a lot for alignments since nothing will freeze up on you
  2. Jan 6, 2016 at 4:12 PM
    #422
    Manwithoutaplan
    ID
    did you look on rock auto.com??
  3. Jan 6, 2016 at 4:13 PM
    #423
    Manwithoutaplan
    ID
    Make sure you get new cam bolts and hard ware.
    jztacoma likes this.
  4. Jan 6, 2016 at 4:14 PM
    #424
    jztacoma
    Upstate NY
    Semi Stockish
    And beef up the alignment tabs to if you have access to a welder
    Manwithoutaplan likes this.
  5. Jan 6, 2016 at 4:16 PM
    #425
    Manwithoutaplan
    ID
    Yea not a bad idea.
  6. Jan 6, 2016 at 4:16 PM
    #426
    jztacoma
    Upstate NY
    Semi Stockish
    Something I forgot to do and now have to take it all apart again... Hind sight 20/20
  7. Jan 6, 2016 at 4:17 PM
    #427
    Manwithoutaplan
    ID
  8. Jan 6, 2016 at 4:53 PM
    #428
    adriancast
    adriancast [OP] Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
    you have a pic or link?
  9. Jan 7, 2016 at 4:30 AM
    #429
    jztacoma
    Upstate NY
    Semi Stockish
    So here's what happened to mine. If you have time you can get the total chaos kit and weld in new alignment tabs. think those are $90 and you need someone who's good at welding to burn them in, guesstimate your alignment and get it to a shop for a final alignment... Or what you can do if your tabs are still in good shape is put some flat steel up against the tabs and weld them in... Mine are bent back into shape for the time being until i can get the time to burn in the total chaos ones since my tabs are all fucked up
    MTopp likes this.
  10. Jan 7, 2016 at 11:32 AM
    #430
    adriancast
    Adrian
    Ontario, Ca
    Ok. I see now. Probably won't end up doing that just yet, but maybe in the future. Im sure the polyurethane bushings will help out a lot.
    MTopp likes this.
  11. Jan 15, 2016 at 11:03 AM
    #431
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Build is looking good man.
    adriancast[OP] likes this.
  12. Jan 16, 2016 at 10:37 AM
    #432
    MTopp
    05 SR5 4x4
    Was gonna say that the LCA bushings may be very difficult to remove and replace with poly, maybe?
  13. Jan 16, 2016 at 11:19 AM
    #433
    Manwithoutaplan
    ID
  14. Jan 16, 2016 at 11:29 AM
    #434
    adriancast
    Adrian
    Ontario, Ca
    MTopp[QUOTED] likes this.
  15. Jan 16, 2016 at 6:36 PM
    #435
    Manwithoutaplan
    ID
    DId you end up buying those 7100's??
  16. Jan 16, 2016 at 7:49 PM
    #436
    adriancast
    Adrian
    Ontario, Ca
    Not yet. I'm planning a trip for me and my girlfriend, so going to have to wait a little bit.
  17. Jan 16, 2016 at 8:06 PM
    #437
    Manwithoutaplan
    ID
  18. Jan 16, 2016 at 8:43 PM
    #438
    MTopp
    05 SR5 4x4
    I see. Not a bad option. I just got new lcas though with the frame. I just need to weld the alignment tabs and antisieze the bolt before it seizes
  19. Jan 17, 2016 at 1:23 PM
    #439
    ryux4x4
    ryux4x4 Well-Known Member
    JP
    2018 Tacoma TRD PRO (Calvary Blue)
    sweet truck what size rim and tire?
  20. Jan 17, 2016 at 2:24 PM
    #440
    adriancast
    Adrian
    Ontario, Ca
    285/75/16
    MTopp likes this.
