Advantage/Dis-Advantages of welding vs. bolt-on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SPORT, May 6, 2011.
Do you prefer to bolt-on or welded rock sliders? Why?
Poll closed Jun 5, 2011.
  1. Weld the damn thing on! It ain't going anywhere.
    49 vote(s)
    45.4%
  2. Bolt on for easy removal/replace
    39 vote(s)
    36.1%
  3. Glued on. huh? (Elmers)
    20 vote(s)
    18.5%
  1. May 7, 2011 at 8:44 PM
    #181
    DrewH
    DrewH Well-Known Member
    :wave:
  2. May 7, 2011 at 8:45 PM
    #182
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    :wave:
  3. May 8, 2011 at 5:49 AM
    #183
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    or the worst of both worlds!! you weaken the frame by drilling holes AND risk making it snap in half by welding it..
    :D
    looks like that dumbass is finally gone? he hasnt been responding to his other arguments in another thread about modifications to our trucks
  4. May 8, 2011 at 6:11 AM
    #184
    jandrews
    '09 FourDubDee TRD OR
    My truck's been falling apart ever since I welded on sliders and bolted on some skids.
    I can't get it to anywhere.
  5. May 8, 2011 at 11:07 AM
    #185
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    i bet that's what caused your rear diff to blow as well...
  6. May 8, 2011 at 11:13 AM
    #186
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I think using some velcro to attach the slider would be the best. No holes or welding on the frame and you can easily remove them to touch of the paint. Much better than glue or duct tape imo. :cool:
  7. May 8, 2011 at 2:37 PM
    #187
    bitejr138
    bitejr138 CTID
    Kelly
    St. Maries, Idaho
    ...yeah, you're not supposed to weld sliders onto the rear diff. :facepalm:
  8. May 8, 2011 at 3:46 PM
    #188
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Don't tell me you're masturbating
  9. May 8, 2011 at 6:04 PM
    #189
    JLink
    Josh
    Ocean, NJ
    :jerkoff:
  10. May 12, 2011 at 8:09 AM
    #190
    SPORT
    SPORT [OP] Well-Known Member
    Rick
    CA bred, currently living in York, PA
    TRD Off Road 4x4 V6
    3" level lift 1.25" Wheel Spacers
    What we have here is a failure to communicate...
    Bunch of trolls I tell ya. :D
  11. May 12, 2011 at 11:00 AM
    #191
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Put it this way... does anyone know ANYONE who has had a frame failure from welding or even bolting on sliders? I'd like to see/hear proof. We are all speculating.
    Regarding STRENGTH of bolt on vs. weld-on, the answer is in the physics. Bolts are only small points of connection of sliders to frame, while welds are a much larger contact point (when done right, with a good base plate and good welds).
    The frame is meant to flex a bit. I'd rather have welded yet properly spaced plates to the side of my frame rather than holes.
  12. May 12, 2011 at 11:35 AM
    #192
    allpro
    allpro Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    Well after reading this I guess I'm screwed! I had a set welded on, grinded them off, now I have another set bolted on. Watch out school buses! :D
    But in all seriousness, we've sold thousands of sliders for nearly 15 years, both weld-on and bolt-on, and have never heard of them causing the frame to break, nor deemed illegal.
    In fact, our latest design for the 05+ Tacomas has a full L-bracket plate that runs the length of the frame for the back 3 legs where the frame isn't boxed for added strength. We also utilize some existing holes in the frame to minimize the amount of drilling needed, but you still need about 10 added holes per side for adequate support for use as sliders, unless you weld them on. And there are plenty of welds on the frame from the factory!
    (Not all holes are for bolts. They fit over the existing bolts/rivets in the frame)
  13. May 12, 2011 at 11:39 AM
    #193
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    ^ love that new mount design, Sarah! :thumbsup:
    I wonder if welded sliders were the real cause of the 1st gen frame recall that Toyota issued?
    :devil:
  14. May 19, 2011 at 10:02 AM
    #194
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    I voted Elmer's Glue. Why not? Honestly, weld it! Bolts will bend, and leave space between frame and the mounts. If the bolts were to ever move, bend, the holes through the frame are going to get wowed out. Welding is much stronger and you don't have to drill more holes in your frame. Seeing those AP bolt-on sliders. Dayum! But...still IMHO I would prefer weld on.
