Advice for newb looking to purchase a new Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thegrandpoohbah, Jan 3, 2010.
  1. Jan 3, 2010 at 7:58 PM
    thegrandpoohbah
    thegrandpoohbah [OP] Well-Known Member
    Terrace, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    Hello everyone. My GF and I are currently living in Fort Nelson, BC, Canada which means lots of wilderness and even more winter. My trusty 2003 Toyota Matrix XRS just wasn't designed to handle these conditions so we have decided to purchase a new truck. I am looking at getting a 2010 Toyota Tacoma 4x4 Double Cab V6 with the TRD Offroad package. All the reviews I've read suggest that this is an excellent small truck and the price is just within our budget. Is there anything that I, as a prospective buyer, should be aware of with regards to this truck? Any issues to look out for or things that I should consider replacing sooner rather than later? Thanks in advance for your help.
  2. Jan 3, 2010 at 8:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
  3. Jan 3, 2010 at 8:05 PM
    cntstan
    cntstan Well-Known Member
    Chuck
    Wisconsin now, North Carolina will always be HOME
    08 DC SR5 4X4 ; 94 Ford Bronco
    3" Toytec coilovers, rear AAL,satoshi'd grill,ARE topper,TRD exhaust, All Pro winch bumper, Warn winch, All Pro skid, Pro comp 7089's, Supersprings, Wet Okole seat covers
    Welcome to TW! The stock tires are no good in snow :thumbsup:.
  4. Jan 3, 2010 at 8:08 PM
    thegrandpoohbah
    Terrace, BC, Canada
    Thanks, I'd assumed as much. I would be replacing them with Nokian WRG2 or Hakkapeliitta R tires.
  5. Jan 3, 2010 at 8:09 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    I put studded winter tires on mine and it's like driving a tank out here in New Brunswick. We just got hit with a bad storm and I have no trouble getting around.
    Cheers!
  6. Jan 3, 2010 at 8:15 PM
    thegrandpoohbah
    Terrace, BC, Canada
  7. Jan 3, 2010 at 8:21 PM
    ColdZeroBSP
    ColdZeroBSP Yo homie, that my briefcase?
    Geoff
    Tewksbury MA
    2012 TRD Sport DC
    console vault, viper remote start, weathertech front and rears
    Welcome! The only thing that annoys me is the rear suspension on bumpy roads or carrying anything heavy. There is a TSB for upgraded spring packs which supposedly helps so you may want to see if you can work that into the deal before you drive it off the lot.
  8. Jan 3, 2010 at 8:23 PM
    cntstan
    Chuck
    Sounds like you would be very happy with a Tacoma. I've had 6 trucks and 3 of them have been a Tacoma (I keep coming back to them for some reason :D). Perfect size for driving everyday, very reliable and the resale value speaks for itself. As long as you're not planning on pulling huge loads you'll be happy with that truck.
  9. Jan 3, 2010 at 8:25 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    G2's are good but i would go with the Hakka R's or if you can, go with the hakka 5's. Those things are insane on ice and snow.
  10. Jan 4, 2010 at 7:36 AM
    thegrandpoohbah
    Terrace, BC, Canada
    If there is a TSB, would the issue not be fixed before the dealer sold the truck? Or are they not required to do that? Thanks for the heads up though, I'll make sure to ask about it.
  11. Jan 4, 2010 at 7:46 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    No they haven't been doing it before it is sold. They are waiting for the customer to bring it back and complain that the bed hit the bump stops under a small load...probably anything over 6-700 lbs.
    I thought I remember the Canadian trucks had the 4 leaf pack. Either way it is easy to tell. When you go look at your new truck count the rear leaf springs. If there are three you need the tsb, if there are four you are good to go!
    With the OR package, they will just replace the rear springs and get an alignment. If you are planning on adding any lift to the front like the billies 5100's or coilovers do it first then take the truck in for the tsb and you can get an alignment for free...because if you change the front shocks you will have to have an alignment regardless.
    Hope this helps, and welcome to TW!
  12. Jan 4, 2010 at 7:48 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    sounds like a good truck. Welcome to TW.
  13. Jan 4, 2010 at 10:32 AM
    ColdZeroBSP
    Geoff
    Tewksbury MA
    2012 TRD Sport DC
    Hendooman pretty much said it. A TSB is not a recall so the dealers are not required to do the upgrade or even tell the customer about it. It has to be a specific complaint about a "harsh ride" over bumpy road and/or under heavy load. Just count the leafs when your looking at the trucks. Good advice about waiting if you plan to lift the front.
  14. Jan 4, 2010 at 10:47 AM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    Welcome to TW!
    I've never heard of those tires you mentioned so I looked them up...Those are car tires, not really close to the correct size for a truck.
  15. Jan 4, 2010 at 10:50 AM
    akyota
    akyota Well-Known Member
    Fairbanks, Alaska
    10' DC trd-offroad mag gray
    none yet
    You buying there in Nelson, whitehorse or south?
  16. Jan 4, 2010 at 10:54 AM
    BSP4x4
    BSP4x4 Guest
    Welcome and by no means is the 2nd gen a "small" truck! You're gonna love it!
  17. Jan 4, 2010 at 10:56 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    You'll enjoy whatever Tacoma you buy.
    My only advice is the same I give to anybody (and follow myself)... why not consider saving a few thousand bucks and trying to find a slighly used truck? Let the first guy take the major depreciation hit driving off the lot.
  18. Jan 4, 2010 at 1:12 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Like everyone said, the tires and leaf springs are all I'd look out for. Personally, I wouldn't sign until they swapped the 3pack over for the 4 pack of leaves as the 09 and 10 are not listed on the TSB yet.
  19. Jan 4, 2010 at 1:37 PM
    BSP4x4
    BSP4x4 Guest
    I have to disagree with buying used! GO NEW...there is only a 2-3 kdifference, and if your spending 23K on a truck, IMO. it's very damn close to spending 25K....and the comfort of being the ONLY driver is worth it!
  20. Jan 4, 2010 at 1:40 PM
    thegrandpoohbah
    Terrace, BC, Canada
    These are the tires I was referring to: http://www.nokiantires.com/product-group?group=2.01
    I was going to get them locally at Kal Tire since they have wicked customer service.
