Advice from real owners
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sml2727, Jan 20, 2013.
  1. Jan 20, 2013 at 6:12 AM
    sml2727
    sml2727 [OP] Well-Known Member
    I have been shopping for a new to me tacoma, and I have come across a real nice 2005 extended cab with the trd off road package, the truck a low 55k on the motor.
    What should I look for before I actually buy it? what where the major problems with this year? I know this is the first year for the new design so there could be problems im not aware of, some stuff I have read on google said that there pretty bad and to stay away (mostly due to frame rusting and bad motor) are these true?
    I'm sure you get a lot of questions like this so just add this one to the list..lol
    Thanks for all responses, I will be going tomorrow to take it for a test drive so I hope to get a good bit of input here.
  2. Jan 20, 2013 at 6:20 AM
    RichLec
    RichLec Member
    Rich
    Mass
    2013 Tacoma Double Cab
    I will put this out there. Sounds like with the low miles this truck may have sat for a while. You may want to check all the rubber pieces to make sure they are not starting to Rot. As for problems with this year/type I do not know any of that so I can not speak to that.
    Rich
  3. Jan 20, 2013 at 6:20 AM
    Taco Libre
    Taco Libre Well-Known Member
    JohnnyHildo
    Saskatoon, SK
    2008 Black 4x4 Access-Cab TRD OffRoad
    Rear TSB, 5100s @ 0, Toytec 3" lift, Total Chaos UCAs
    mine is a 2008 so i haven't ever bothered to look into what problems 05's came up with. i'm gonna bet the overhead compass/thermometer isn't working which is a common problem with tacoma's from the start of second gens to at least my year and likely longer. in many cases fixable and in reality a minor problem to begin with. good luck with the drive bud!
  4. Jan 20, 2013 at 6:24 AM
    Hot2na
    Hot2na Well-Known Member
    '05 ...era of rust....check every inch of the frame
  5. Jan 20, 2013 at 6:36 AM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    I have an 05 trd off road.with 157 thousand miles on it. I would say, check the frame for rust (surface rust will always be on most o5s due to age and use) if it looks bad then step away. Also, If you test drive it, do it like you stole it. Make sure the transmission functions flawlessly. Take the VIN number to Toyota Services to check any work performed by them. Also, look at the truck closely for any "new" looking paint (for chips) as well to see if it has been repainted. Just my 02.
    Overheard console, blower motor chirping are thing to look for as well as sagging leaf springs.
    As for the motor being "bad" , I have not had one issue with my motor. Change oil when you need and keep fluids up to date and you will be gtg
  6. Jan 20, 2013 at 6:40 AM
    bash42
    bash42 Well-Known Member
    Eastern PA
    '22 DCLB TRD OR Super White
    Is the truck in the northern climate? Also how much $?
    Just remember its an 8yr old truck, I wouldn't break the bank for it.
  7. Jan 20, 2013 at 6:41 AM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    and the frame rust issue affected the 1st gens, not the second gens btw. There has been no recall for frame rust on my 05 taco
  8. Jan 20, 2013 at 6:45 AM
    bash42
    Eastern PA
  9. Jan 20, 2013 at 6:48 AM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    Yeah, Using the search I found one issue. It is generally known that 1st gens have a recall. Find me a recall on a 2005 taco for frame rust
  10. Jan 20, 2013 at 6:52 AM
    bash42
    Eastern PA
    Just because there hasn't been a recall doesn't mean it's not a known issue.
    Back to the original point, the guy looking to buy a 2005 should check the frame because it is possible that it will have rust issues. ;)
    Google.com is an amazing thing.
    https://www.google.com/search?q=2005+tacoma+frame+rust+recall&ie=UTF-8&oe=UTF-8&hl=en&client=safari
  11. Jan 20, 2013 at 6:54 AM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    Yep- thats the one link with a picture-not a recall.I am glad you are slapping your own face:)
    BTW- can you also try and find the actual toyota recall announcement? Or even a TSB on the issue? And you dont even own a 05. I do, I have zero issues with frame rust.
    The comment was to etna who stated that 05 was the era of rust.
    OP, look, it is a 8 year old truck, There is going to be a little wear and tear on it, unless you buy it from a grandma.
  12. Jan 20, 2013 at 6:57 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
  13. Jan 20, 2013 at 6:59 AM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    I can see that ones that happened were because of owners assuming toyota would have fixed their frame issues from the 1st gens, and then not properly taking care of their frames after road salt, and water IMO
  14. Jan 20, 2013 at 8:11 AM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Before I rant about toyota and rust, to answer the question to or original poster. The main issue on the 05's were faulty engine mount setup where the flange welded to the frame collapses into the frame. Try and pull toyota histoy using the vin to verify what work has been done to the truck by previous owners.
    Also low mileage is not always a good thing for vehicles since it means they are sitting for longer periods which hardens seals and lets water sit in the exhaust and other areas without drying out.
    Toyota just keeps dropping the ball on frames.
    Dealers are now getting new lifts to do frame swaps on the sequais due to the size of the vehicle.
    The 2nd gen tacoma will likely fall into this catagorie of need frame swaps as well.
    All steel rusts with moisture or salt it just depends on how you treat or protect it. A can of 99 cent flat black paint would provide better protection than the joke of a product toyota used.
    Some will say yeah my truck is not rusting but they live out in areas where there are still glass topped fuel pumps looking new.
  15. Jan 20, 2013 at 9:12 AM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    I had my 05 Tundra until last year. It only had 51K miles on it. Never sat for more than a week's vacation. I just lived 4-6 miles from work for many years. Didn't have anything wrong w/ it. Wish I still had it for towing purposes.
    Just check it out for rust and other issues mentioned above. Just wanted to throw it out there that because it is low miles, doesn't mean it wasn't driven daily.
  16. Jan 20, 2013 at 9:27 AM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    I bought an 05 with 58k on it a year and a half ago and have 66k now. I still don't stack on the miles because I ride the motorcycle a lot in the summer. Things to look for are ticking from the exhaust manifolds, front cover oil leaks, soft rear leaf springs (excessive axle wrap), and a mildew smell from the interior suggesting water has been leaking in. My frame has some surface rust, but I wash it regularly, so I'm not concerned with it advancing out of control. All frames will experience some rust in their lives. That being said, I am really happy with mine and have no regrets. If you like it, buy it.
  17. Jan 20, 2013 at 10:20 AM
    sml2727
  18. Jan 20, 2013 at 10:27 AM
    scottw1
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    No way. You can use whatever you want. 87-93 or whatever comes in the pump now days.
  19. Jan 20, 2013 at 10:27 AM
    bash42
    Eastern PA
  20. Jan 20, 2013 at 10:28 AM
    scottw1
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    17K for a V6 is pretty steep. I'd have to get a few K's off that sticker price before I bought it. I didn't do any research but that seems high.
