Advice on changing transmission fluid
Discussion in '1st Gen. Tacomas (1995-2004)' started by shitroc, Feb 10, 2010.
  1. Feb 10, 2010 at 4:42 PM
    shitroc
    shitroc [OP] Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    Im going to change my transmission fluid and transfer case fluid tomorow and was just wondering if theres anything i should know before i do. Any tips would be appreciated. My tacoma is a 2002 trd sr5 V6 5 spd. I dont know if the transmission or transfer fluid has ever been changed so i figured i should do it. Gonna put in some Royal Purple 75w-90 in both. Does it matter if its synthetic or not. I was told that 75w-90 only comes in synthetic so.
  2. Feb 10, 2010 at 4:56 PM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
  3. Feb 10, 2010 at 5:06 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    yah good call on a pump for sure. i wonder who would carry one of those around here. The manual calls for 75w-90,the guy at napa told me that 75w-90 only came in synthetic. Not just royal purple but 75w-90 in general. I dont know if the napa guy is right.
  4. Feb 10, 2010 at 5:11 PM
    747 function > form
    1st Gen.
    Make sure you buy enough T-IV tranny fluid...I bought 3 qts as per Toyota service guy's instructions (he told me 2.5 qts would do it), drained the fluid, and needed 1 more quart. In other words, buy 4 quarts (hell, buy 5; that way you don't have to ride to the Toyota Parts Department on your bicycle midway through servicing your truck).
    You can always keep the leftover quart(s), or return them.
    Oops...auto tranny experience here...not applicable (or maybe it is). Just buy enough fluid.
  5. Feb 10, 2010 at 5:11 PM
    beetlejuice2275
    beetlejuice2275 Well-Known Member
    Reximus
    Queens, NY
    Drift inspired 08 Reg Cab
    custom ram air. blacked badges, hids, rewired front turn signals and park lights, URD short shifter, Pioneer t-screen (no nav), 10" 1200 watt.
    Not a big deal as long as you stay with synthetic.
    They had a whole thing on Horsepower tv or another and they net like 15 hp just from going to royal purple rear diff and tranny oil from a camaro.
  6. Feb 10, 2010 at 5:15 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    I think the T-IV fluid is only for automatic trannys isnt it. Yah shit that would suck to be short a whole quart.
  7. Feb 10, 2010 at 5:18 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    i heard its also better to go with the GL-4 stuff rather then GL-5. GL-5 stuff can be hard on the syncros. I think i remember reading that somewhere.
  8. Feb 10, 2010 at 5:54 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
  9. Feb 11, 2010 at 6:25 AM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
  10. Feb 11, 2010 at 6:39 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED), 2006 F350 King Ranch 6.0L
    True, GL-5 has and additive that isn't copper friendly. Granted it is a long term effect but you will notice a change in the feel of you gear engagement.
    I used Amsoil in my 98 without issue. I know a few that use(d) Mobil 1 without issue also.
  11. Feb 11, 2010 at 9:33 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Did you say you were going to put gear oil in both the tranny AND transfer case?
  12. Feb 11, 2010 at 1:33 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
  13. Feb 11, 2010 at 2:14 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
  14. Feb 11, 2010 at 2:17 PM
    humanoid
    humanoid bite me
    Sunny SoCal
  15. Feb 11, 2010 at 2:23 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    the front diff takes the same as the tranny and transfer case but with the rear diff i put 80w90. It says right on the bottle of RP "great for manual transmissions".
  16. Feb 11, 2010 at 3:07 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
  17. Feb 11, 2010 at 7:16 PM
    98tacoma27
    Ben
    Beech Creek
    Yes.................on a manual transmission
