Advice wanted
Discussion in '2nd Gen. Tacomas (2005-2015)' started by northern cal, Nov 25, 2012.
  1. Nov 25, 2012 at 6:35 PM
    northern cal
    northern cal [OP] Active Member
    bay area
    tacoma TRD
    My new 2012 dbl cab with three inch lift, rear leaf springs sqeek like hell. Sounds like a fourty year old farm truck on the back/dirt roads. Only about 2000 miles now. Just need Lube? What type? Or should it go back to dealer?
    Thanks for any real advice. :confused:
  2. Nov 25, 2012 at 6:42 PM
    Ray
    Ray Well-Known Member
    San Diego
    09 Pre-Runner
    Was the lift a dealer install/option (or if you bought the truck used from the dealer?) If yes, then I'd take it to them. If you had an outside shop do the install, that's were you should take it. If you installed it yourself, them I would think that it woudl be up to you to correct.
    Ray
  3. Nov 25, 2012 at 6:46 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    if you jump on the bumper, can you pinpoint the location on the noise? maybe you cn get a better idea once you kno exactly where its coming from
  4. Nov 25, 2012 at 6:48 PM
    northern cal
    bay area
    tacoma TRD
    Was bought from the dealer with a ProComp set up. Set up in stalled by 4Wheel parts. Not to impressed with them so far.
  5. Nov 25, 2012 at 6:48 PM
    hakabo
    hakabo Well-Known Member
    Jacob
    Concord, NC
    08 urban runner 4x4
    perhaps just clean the leaf springs? I had this happen on my truck and hit it w/ the pressure washer and it stopped
  6. Nov 25, 2012 at 6:50 PM
    northern cal
    bay area
    tacoma TRD
    Seems to be coming from the rear mount of the leafs as well as the center axle mount.
  7. Nov 25, 2012 at 6:52 PM
    dayNnite4
    Nick
    Southern NH
    '11 4x4 5-speed AC
    careful with the axle, could get serious
  8. Nov 25, 2012 at 6:59 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    Go to your dealer. Ask. I had a lift on my truck, I installed myself. They did the TSB.
