Aeroforce Interceptor group buy Extended
Discussion in 'Group Buys' started by forcefedjunkie, Jan 8, 2010.
Thread Status:
Not open for further replies.
  1. Dec 9, 2010 at 7:51 AM
    #161
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Have the issues been worked out for the 05/06 tacomas?
  2. Dec 9, 2010 at 12:45 PM
    #162
    forcefedjunkie
    forcefedjunkie [OP] Well-Known Member Vendor
    Todd
    Avon, OH
    Nope. No one has volunteered and Toyota won't give us the info.
    All I need is a truck to stop by for 1 hour.
    Todd
  3. Jan 14, 2011 at 10:59 AM
    #163
    yotatoy
    yotatoy Well-Known Member
    il
    2010 Toyota TRD 4x4 4D V6
    Avid side steps Nokia Yellow fog lights t-rex eyelids trd sport hood front windows tint
    does the loteck two pill work on a 2010 because of the side air bag?
    also will two fit and whats the set up time?
  4. Jan 14, 2011 at 12:49 PM
    #164
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    If you have the side curtain airbags in the A Pillar then I would not use the pod.
  5. Feb 3, 2011 at 10:05 PM
    #165
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    Sub'd great looking guages!
    Also who has these in there truck and how do they like them over some of the other gauges out there?
  6. Feb 6, 2011 at 11:16 AM
    #166
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
  7. Feb 6, 2011 at 8:49 PM
    #167
    taco084gb
    Galen
    NorCal
  8. Feb 7, 2011 at 5:40 AM
    #168
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Feel free there are no royalties involved. ;)
  9. Feb 13, 2011 at 7:32 AM
    #169
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Anyone know what the typical oil pressure is at start up on the 2.7L engine?
    I have a reading of around 82PSI. Does this seem normal?
  10. Feb 14, 2011 at 6:34 AM
    #170
    forcefedjunkie
    Todd
    Avon, OH
    From what I've seen on other cars I'd say so. Typically I see pressures in the 70s at idle which will fall to the high 20's to 30's once the oil is hot.
    Todd
  11. Feb 14, 2011 at 6:56 AM
    #171
    phatdrew
    phatdrew Well-Known Member
    drew
    dover, de
    2" lift, 17" pro comp wheels, 285x70x17 micky t's, billet grill
    is this gb over? anybody purchase this with a 06 4cyl 4x4? any info would be greatly appreciated.
  12. Feb 14, 2011 at 7:41 AM
    #172
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Todd:
    I actually registered over at the Aeroforce forum, same screen name, but did not post the problem.
    I did a lot of reading and I was able to solve my issues. Fat fingering the programming and lowering the contrast on the dial was a biggie. I followed the instruction on how to fix that and somehow lucked into the fix. I was then able to program the 2 values into Analog 1 and the gauge started to work.
    At cold idle the PSI is up at 80+. Once the truck warms up the pressure is around 40PSI at idle.
    There is a lot I can monitor with the gauge but I have to tell you that the directions seem to be written for someone that has 6 months experience with programming the gauge. Not really a big deal.
    Next up is to relabel Analog 1 to Oil Pressure if that is an option and to figure out the cyclic display that has each screen up for 10 to 15 seconds. I am also fascinated with the Annunciator function and how to use it.
    I would also like to figure out how to go back to a parameter once I go past it because I depressed the button for too long.
    Overall the gauge is a big 2 thumbs up.
  13. Feb 14, 2011 at 7:46 AM
    #173
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Mine is on a 09 4cyl 2WD. There was a small challange installing the Oil Pressure module but only because I had never done this before.
    What are you looking to monitor?
  14. Feb 14, 2011 at 8:30 AM
    #174
    phatdrew
    drew
    dover, de
    generally everything since this is my first 4cyl motor to have ever owned. ive always had v8's and diesels. i do a lot of driving up and down the east coast and average about 20k miles a year.
  15. Feb 14, 2011 at 4:42 PM
    #175
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    This gauge will monitor most everything you want. No trans temp for a manual transmission but you can andd an analog input temp monitor to do the job. Each gauge can handle 2 analog inputs.
    Poke around the Aeroforce website and down load the latest manual.
Thread Status:
