AFE Air Filters
Discussion in 'Performance and Tuning' started by Burns, Jul 20, 2007.
  1. Jul 20, 2007 at 6:54 AM
    Burns
    Burns [OP] Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Has anyone had any experience with the AFE high flow drop in air filter's? Thinking about getting one for my POS X-Runner.
    http://www.performanceproducts4trucks.com/productpage.aspx?cid=17&sid=265&pid=111246
  2. Jul 20, 2007 at 10:07 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I just dropped one in my 2.7L yesterday. I am already noticing a difference in high RPM torque and HP. It isn't a ton of power, but it is enough to keep me from downshifting as much to pass on a hill.
    I can't tell you much about the MPG yet - I have been heavy footing it to see what the difference "feels" like.
    I will let you know more when I can calm my testosterone. ;)
  3. Jul 20, 2007 at 10:11 AM
    Burns
    17 DCSB Off-Road
    Cool thanks for your input man. Anyone else?
  4. Jul 23, 2007 at 4:53 AM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    First impressions of the AFE filter driving from San Antonio to Houston and back and then spending a day in the hills around Kerrville, TX...
    The low end doesn't seem to show too much of a difference. There is a bit more oomph after 2,000 RPMs quite a bit more after 2,700 RPMs. My truck had some issues holding a hill at 70-80 MPH, but no issues now.
    I averaged 26 MPG over the weekend with moderate amount of "brisk" driving.
    (AFE drop-in Air Filter and Secondary Air Filter removed)
  5. Jul 25, 2007 at 5:33 AM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    Ok, with the above mods, no heavy footing, 75 MPH w/cruise on, in the rain - 28 MPG!
    Finally.
    Maybe the AFE filter was worth it. ;)
  6. Aug 7, 2007 at 6:41 AM
    myopera
    myopera New Member
    I put a K&N Air Charger on my 06 V6... its a big difference from stock... more passing power... and loud, almost too loud on full gas... but kicks ass... not sure how gas mileage is... didn't check it yet... that was the reason for installing to bump that up... once i check i'll post any gains... stock is about 20 mpg...
    4.0, 6 speed... 4x4... extended cab, SR5...
  7. Sep 25, 2007 at 12:56 PM
    m3dragon
    m3dragon Well-Known Member
    Sacramento
    get volant or K&N. I run AFE in my M3 and it is made out of steel. Can you say heat soak. Not good for HP or MPG
  8. Nov 3, 2007 at 5:44 PM
    m3dragon
    Sacramento
    AFE had a great design but with the heat sheild being metal it is sucking in more hot air. I called them on this and they said it was to keep the cost down but they are 200 more then the compotition.
    Someone said that the new design are plastics. If that is the case that is good thing as there is fare less heat soaking.
    I did I IR test on the Steel box in my M3 and it was running 130 and causing the heat temp to give false readings. I can't wait to get it out and get the carbon boc in.
  9. Nov 3, 2007 at 6:29 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    well the one's they're talking about in here are the drop in filters....not the complete filter systems.
  10. Nov 3, 2007 at 7:51 PM
    m3dragon
    Sacramento
    The design makes it thinner than a paper filter hence it will be better. But if it ran cooler it would be much better than running warm.
    One thing we need to know is if the AFE filter is ITG Foam. If it is it does flow a lot of air but allows larger particiles into the motor. Formula 1 runs ITG but those are race cars that run 2 races before a motor rebuild.
  11. Nov 6, 2007 at 7:28 AM
    m3dragon
    Sacramento
    I canceled my order for Volant and am going to give AFE another shot now. All the people I talked to with Volant say it hurts MPG. Plus does not seem to gain much performance.
