AFE Cold Air
Discussion in '2nd Gen. Tacomas (2005-2015)' started by monsterkx2fiddy, Mar 15, 2012.
  1. Mar 15, 2012 at 1:42 PM
    monsterkx2fiddy
    monsterkx2fiddy [OP] Well-Known Member
    Birthplace of Davy Crockett
    Im about to buy the Afe stage 2 si from Autoanything. Does it come with hardware to plug the hole thats on the bottom?
  2. Mar 15, 2012 at 2:08 PM
    NEAScott
    NEAScott Well-Known Member
    Scott
    Toledo, Oh
    2014 Chevrolet Impala Limited
  3. Mar 15, 2012 at 2:12 PM
    NEAScott
    Scott
    Toledo, Oh
    Not seeing it in the instructions or the breakdown ??
  4. Mar 15, 2012 at 2:31 PM
    NoSoup4You
    NoSoup4You Well-Known Member
    David
    San Clemente
    2008 DCSB DMZ LT 4x4
    Camburg | King | Glassworks | DMZ | Nitro | Banks | Pelfreybilt | Brute Force Fab | Bay Area Metal Fab | Baja Designs | Rigid Industries | STL
    I just bought one of these as well .. the instructions and part sheet did not include the plug, but it was surely included in the kit (mine was black, not red)
  5. Mar 15, 2012 at 3:02 PM
    NEAScott
    Scott
    Toledo, Oh
    It must be pre-installed then in the box?? Strange to me that it isn't noted as a separate piece.
  6. Mar 15, 2012 at 3:10 PM
    tango down
    tango down Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
    Best place to buy the urd intake? I'd search but I'm on a barely smartphone.
  7. Mar 15, 2012 at 6:53 PM
    monsterkx2fiddy
    thanks guys. i thought i read somewhere if you plan on getting water over your hood to install the plug.
    I would go urd to get true cold air but it seems like it would just heat up to the same temperature after passing through the intake tube. And it would suck to not be able to hit a puddle because of the cai.
    Im mostly getting it because of the sound but then again i dont want it to be super loud!
  8. Mar 15, 2012 at 6:55 PM
    monsterkx2fiddy
    I also hate how you have to take the engine cover off.
    Anyone know if the trd exhaust flows better then stock?
  9. Mar 15, 2012 at 7:59 PM
    NoSoup4You
    David
    San Clemente
    Engine cover can stay on with the afe. Check my build thread for pics.
  10. Mar 16, 2012 at 6:51 AM
    monsterkx2fiddy
    Thank you no soup4you and wokfpack5150. Ordering my intake today
    What I ment is that the Urd is a true cold air intakebut unless you put ice on the intake tube like some do. Metal is a good conductor of heat so by the time the cold air passes through the intake tube it will have gotten a little warmer? That's just my thinking. Or is the air passing through so fast that the cold condensed air isn't having time to heat up?
  11. Mar 16, 2012 at 6:55 AM
    monsterkx2fiddy
    Nvm you already answered that about heat soak.
    Well my buddy has one in his modded altima. Its loud when he steps on it but under 3k rpm its quiet.
  12. Mar 16, 2012 at 6:58 AM
    monsterkx2fiddy
    And as far as the trd exhaust will I see any gain even if its just 2-3 horsepower?
  13. Mar 16, 2012 at 7:10 AM
    monsterkx2fiddy
    Ima be pissed if I have to spend 200$ to fix my check engine light -.-
  14. Mar 16, 2012 at 7:22 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    How you figure that? Seems to me about the same amount of heat would be absorbed, to a point, regardless if moving slow or fast. Fast would mean more air to do the absorbing. In the end, the same heat transfer would likely take place. At least IMO.
  15. Mar 16, 2012 at 9:06 AM
    monsterkx2fiddy
    okay ive searched found that afe has thrown check engine lights.
    but all you have to do to fix it is unplug battery and drain it then the problem will go away?
    so my question is is there any chance if i buy my afe cai that i will have to buy urd maf for 200$?
  16. Mar 16, 2012 at 9:40 AM
    NoSoup4You
    David
    San Clemente
    hmm .. been running my aFe for about 2-3 months on my daily driver, no CEL here.
    In any case, disconnecting the battery will likely clear the CEL .. if the issue persists the CEL will come back (and it's not something to be ignored just becuse you have a CAI). Instead, I would recommend getting the OBD II reader from Harbor Freight .. you can always check the CEL before clearing it, and clear it without cutting the battery.
    As for the URD MAF cal .. this will not clear a CEL (that I'm aware of). It's designed to modify the full-throttle (can't remember if that's open or closed-loop) MAF sensor signal to adjust for the air flow in your aftermarket CAI.
  17. Mar 16, 2012 at 1:08 PM
    monsterkx2fiddy
    Taoscott is hooking me up. Anyone done service with him? Sounds pretty good to me
  18. Mar 23, 2012 at 4:41 PM
    monsterkx2fiddy
    Well I ordered it through truckaddons fro mscott because they'll beat any price. Taking a little longer then I wanted but scotts been very helpful.
    So go to him
