aFe dry intake throwing MAF code??
Discussion in 'Performance and Tuning' started by tacos_modern_life, Aug 18, 2016.
  1. Aug 18, 2016 at 6:59 AM
    tacos_modern_life
    tacos_modern_life [OP] Well-Known Member
    Brandon
    Portland, OR
    2015 Inferno TRD Pro
    TRD S/C, afe/TRD intake, TRD exhaust, Work Meisters, Retrax, Baja Designs Amber Fogs
    So for the past couple months my 2013 4.0 has had the check engine light intermittently come on but would only be on for about 50 miles or so and would then shut off. I'm running the aFe dry intake which was just cleaned last month. Today I finally got a chance to use my code reader and it's giving me code P0101 which indicates the MAF to be faulty or miscalculating. Anyone else with this setup ever have this problem? Not sure if it's actually my MAF or if something may need adjustment :notsure: Figured I'd ask around here first before investing a couple hundred bucks to replace.
    Thanks in advance for any input :cheers:
  2. Aug 18, 2016 at 8:51 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Check to see if it is plugged in properly, and make sure your silicone couplings are properly secured.
    Lord Helmet likes this.
  3. Aug 19, 2016 at 10:01 AM
    tacos_modern_life
    Brandon
    Portland, OR
    silicone coupling was wedged in some weird way so i had air bypassing most likely. Light shut off this morning. Hopefully it won't be back now that its properly set lol thanks a lot :oldglory:
    inwood customs, Lord Helmet and Aw9d like this.
  4. Aug 19, 2016 at 10:03 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Excellent. :thumbsup:
  5. Aug 19, 2016 at 11:17 AM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    I've had my afe pro dry (whatever) intake on my 2014 for 10 months. No CL light
  6. Aug 27, 2016 at 5:50 PM
    bushman31
    bushman31 Well-Known Member
    Ron
    Draper, UT
    TRD
    Old Man EMU suspension, 33" tires, 4.56 gears, Leer shell, airlift airbags, Fab 4's rear bumper and tire carrier, and some other shit.
    Have you guys noticed any performance increase with the intakes?
    Thanks,
    Ron W.
  7. Aug 28, 2016 at 10:26 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Peruse through the link in my signature.
    bushman31 likes this.
  8. Aug 29, 2016 at 1:04 AM
    tacos_modern_life
    Brandon
    Portland, OR
    my pro dry doesn't have any "noticeable" increase. I think its about 1-2 HP gain. More just cost effective in the long run and easy to clean. You may want to go with a cold air intake for performance :burnrubber:
  9. Aug 30, 2016 at 5:59 PM
    bushman31
    Ron
    Draper, UT
    TRD
    Thanks. I am thinking of doing a snorkel for the obvious reasons. I am looking for a little performance improvement, especially when I am towing my camper in higher altitudes, but I have to keep the engine stock for the most part. My wife's law!
