AFE or K&N for the?
Discussion in '4 Cylinder' started by Steve E, Apr 8, 2009.
  1. Aug 31, 2009 at 9:40 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    That may be true, but I am not going to gamble my engine over it! Not trying to change your mind Janster, I am just glad you posted so we can give people looking for information both sides.
  2. Sep 10, 2009 at 2:21 PM
    zuter
    zuter Well-Known Member
    Calgary, AB
    09 SR5 4x4 4 cyl
    2nd filter, undercover, debaged, bug deflector, more to follow!
    Thanks Janster
    I looked on the package and couldn't find the instructions. But I'll follow your instructions when I clean both our K&N's next time.
    As for the effectiveness of the filter and letting by more pariculate than the OEM filter I'm sure dgerm is right! How can a filter let in more air without letting in more dirt?!
    However, I religiously change my oil long before OEM spec's thereby minimizing the side effects. While not perfect the cost per OEM filter replacement vs the minimal effect with frequent oil changes is probably the same as following Toyota's oil and filter change recommendations! I just put my money into better oil (synthetic) instead of regular (dino). I'm always asked how do I keep my cars running so long? My answer is "change the oil often"!
  3. Sep 11, 2009 at 4:04 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    That's not a fair statement to say - although many people would agree.
    I don't agree with that statement and haven't had problems with mine when I had them.
    The 'oil' that you spray in there IS the filtering agent. The oil traps the fine particles. These filters are not designed for dusty dirty conditions and when used in those conditions, must be kept clean and cleaned regularly. Once the oil is saturated with dust, it can't filter anymore and will allow dust through. The idea is to keep it clean. I cleaned mine every 6 months.
  4. Sep 11, 2009 at 6:01 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Actually, has the filter becomes dirty it filters better. This is from K&N's wedsite.
    4. How often do I need to clean my K&N air filter?
    If you have not experienced a decrease in mileage or engine performance, chances are your filter is fine and does not yet need cleaning. To be more specific, the filter does not require cleaning if you can still see the wire screen on the entire air filter regardless of how dirty it may appear. When the screen is no longer visible some place on the filter, it is time to clean it. When used in normal paved road, street or highway conditions, our replacement air filters that fit in the factory air box should require cleaning every 50,000 miles and our large conical filters on an intake system should require cleaning every 100,000 miles. When used in dusty or off-road environments, our filters will require cleaning more often. We recommend that you visually inspect your filter once every 25,000 miles to determine if the screen is still visible.
  5. Sep 11, 2009 at 6:35 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    IMHO, I've used the KN in many sports cars and V8 trucks and the drop ins added 1+mpg and I also believed the HP gains - how ever so small they were. The KN (Autozone) intake systems are the bottom of the barrel to what is out there now for any car or truck for the price as they seem to be just be bolt on and not take into consideration the MAF sensor positions and tube sizes to maximize leaning conditions to increase HP and MPG per most Dyno results, AFE, AEM, S&B, Volant are all better options for the price.
    My personal experiences with my current taco, have been- AFE dry drop in, then AFE Stage 2 intake (lost 2+ MPG but gained upper rpm 10+ HP) but it was noisy, now I'm back to AFE dry drop in +.5 mpg (some slight 2-3 HP probably) because that is where I do most of my driving, its quite and easy to clean and pays for itself in 30k miles, its the non-oiled filters I like on our pickey MAF sensors that seem to not like oil on them....
    To each their own, a good oil filter will catch most of the crap that gets by and if that small particles take 500 miles off my 300k mile engine...its not the end of the world because I will have sold the truck by then.
  6. Sep 11, 2009 at 7:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The K&N type filters DO let more dirt in than any other filter. I have tessted my oil, and it rflects this. Any time I had a K&N, AFE, or AirAid, My silica levels were off the chart.
  7. Sep 11, 2009 at 2:28 PM
    Janster
    Jandy
    Lancaster, PA
    :rolleyes:
    Yeah, I know you test your oil. You've mentioned it a gazillion times! ;)
    I have nothing againest oil testing, but I personally don't have the time and I don't see the need for it. The oil will get dirty. Change your oil & filter every 4500-5000 miles and you get rid of 90% (or whatever) of that dirt.
    Having oil tests done would ultimately mean that you're spending way too much time & money trying to figure out which air filter, which oil filter, and what oil to use to get the perfect results. What exactly - would be the perfect result to an oil test - from oil that's been in your engine for 5000 miles? After after all that effort...does it really & truely make your truck last that much longer? Hell, the body & frames rust out long before the engines do!!
    :p Sorry, couldn't help myself.;)
  8. Sep 11, 2009 at 2:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Being as I get my OS free, I did them just for info purposes. Yes, changing the oil is key, but the test I did with the K&N had only 800 miles on the oil, and the silica level was maxed out. I do belive it affects engine longevity, which is why I did the testsing. How much it will affect them, who knows. And, it may vary depending on what part of the country one resides. Being in the desert, Im guessing there is much more dust than in...say...Florida. SO, that could make a difference too. :)
