AFE Performance. numbers: Towing and non towing.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mvega1969, Jun 16, 2008.
  1. Jun 16, 2008 at 8:28 AM
    mvega1969
    mvega1969 [OP] Well-Known Member
    Laredo
    '17 Tacoma DC LB 4X4 TRD Off Road.
    Well.... NUMBERS... after I Installed my AFE Pro Dry S drop in filter these are the results:
    NON-TOWING (verified with Scangauge II)
    better at highway speeds (from 65MPH to 70MPH)
    WIND Speed is an important variable. (It does really affect performance).
    SETUP: DC, 4X4, LB, 17" tires (OEM -35 PSI-), 5 persons (530 pounds) and 530 pounds of weight on bed.
    BEFORE / AFTER
    MPG 18.6 MPG @ 65-68 MPH / 22.4 MPG @ 70MPH
    RPM 2000 RPM @ 66 MPH / 2000 RPM @ 70MPH
    After 70 MPH you began to get a steady performance or a small lost on MPH or an increase of RPM.
    Winds of 25-35MPH decreases performance almost 3 MPG @ 70 MPH and increases RMP to keep 70MPH up to 2350-2450RPM.
    Not good aerodynamic, even with a LEER CAP.
    TOWING -folding trailer, Fleetwood E3- (verified with Scangauge II)
    better at highway speeds (from 60MPH to 65MPH)
    WIND Speed an important variable. (It does affect performance).
    SETUP: 08 TRD Sport, Tow Pckg, Four Doors, 4 wheel drive, Long bed, 17" tires (OEM -35 PSI-), 5 persons (530 pounds) and 530 pounds of weight on bed.
    BEFORE / AFTER
    MPG 12.8 MPG @ 60-65 MPH / 14.3 MPG @ 70MPH
    RPM 2500 RPM @ 65 MPH / 2100 RPM @ 70MPH
    After 62-65 MPH you began to get a steady performance or lost on MPH or an increase of RPM.
    Winds of 25-35MPH decrease almost 5 MPG @ 65 MPH and increases
    RPM to keep 70MPH up to 2500-2800RPM.
    On 15 to 25 grades going up, there is no way to use D 4th is the only gear to get it up and is normal a 50MPH speed @ 2000-2250 RPM
    Total aprox weight on RV is 3,000 pounds. Everything loaded (except water in their tanks).
    RV tires are 15" at 50 PSI.
    DAMN! I need the TSB on my '08, it has been reduced almost 2" in the back when towing and there is around 450 pounds tongue weight.
    END POINT... AFE is GREAT!
  2. Jun 16, 2008 at 8:38 AM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    Good write up. Looks like il be buying a drop in filter soon. haha
    I just got my tacoma and so ive been searching around to see what parts people like and is beneficial. Would I see better mpg is i were to get an intake set up compared to a drop in?
  3. Jun 16, 2008 at 8:45 AM
    mvega1969
    Laredo
    Price wise! go for the drop in... the whole intake system will be great (but more $$$) and as more air get into the motor that same amount has to go out... means that if you want the 100% of performance for an intake system you will need to think in a performance exhaust system that will help you out.
  4. Jun 16, 2008 at 8:52 AM
    deadbolt
    deadbolt do w3rk!
    Socal
    Thanks. I looked at the AFE site, will the 05 filter fit an 08?
  5. Jun 16, 2008 at 8:55 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Yes it does.
  6. Jun 16, 2008 at 9:39 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. Custom dents.
    Good write up. I can't wait to get mine in from the group buy.
  7. Jun 16, 2008 at 11:08 AM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    Agreed.
  8. Jun 16, 2008 at 11:23 AM
    deadbolt
    deadbolt do w3rk!
    Socal
    I wanna switch out my filter. however the truck is only 3 weeks old. might be a waste but if it gives me better mpg then i should. d=
  9. Jun 17, 2008 at 7:10 AM
    dougmays
    dougmays Well-Known Member
    Doug
    Gainesville, FL
    2007 SR5 Tacoma 4WD/Tow Pkg Black
    Westin Bull Bar, Firestone Destination AT 255/70/16
    has the group buy already happened? Also just for my own knowledge...is this filter just a replacement of the old? not sure exactly what the drop-in filter is?
  10. Jun 17, 2008 at 7:17 AM
    mvega1969
    Laredo
    This is a replacement for the OEM, it will fit where the stock is. Is not part or whole of an air intake system. But it will perform almost like it. It is cheaper and for the price is the best option.
  11. Jun 17, 2008 at 8:19 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    dougmays yes the group buy has already happened. I don't know if it is still going on or not. Not sure if there was a time frame or not. Contact Mceagle, he is the man.
  12. Jun 17, 2008 at 8:35 AM
    dougmays
    Doug
    Gainesville, FL
    thanks.. will do
