AFE Performance. numbers: Towing and non towing.
Discussion in 'Towing' started by mvega1969, Jun 16, 2008.
  1. Jun 16, 2008 at 4:11 PM
    mvega1969
    mvega1969 [OP] Well-Known Member
    Laredo
    '17 Tacoma DC LB 4X4 TRD Off Road.
    Well.... NUMBERS... after I Installed my AFE Pro Dry S drop in filter these are the results:
    NON-TOWING (verified with Scangauge II)
    better at highway speeds (from 65MPH to 70MPH)
    WIND Speed is an important variable. (It does really affect performance).
    SETUP: DC, 4X4, LB, 17" tires (OEM -35 PSI-), 5 persons (530 pounds) and 530 pounds of weight on bed.
    BEFORE / AFTER
    MPG 18.6 MPG @ 65-68 MPH / 22.4 MPG @ 70MPH
    RPM 2000 RPM @ 66 MPH / 2000 RPM @ 70MPH
    After 70 MPH you began to get a steady performance or a small lost on MPH or an increase of RPM.
    Winds of 25-35MPH decreases performance almost 3 MPG @ 70 MPH and increases RMP to keep 70MPH up to 2350-2450RPM.
    Not good aerodynamic, even with a LEER CAP.
    TOWING -folding trailer, Fleetwood E3- (verified with Scangauge II)
    better at highway speeds (from 60MPH to 65MPH)
    WIND Speed an important variable. (It does affect performance).
    SETUP: 08 TRD Sport, Tow Pckg, Four Doors, 4 wheel drive, Long bed, 17" tires (OEM -35 PSI-), 5 persons (530 pounds) and 530 pounds of weight on bed.
    BEFORE / AFTER
    MPG 12.8 MPG @ 60-65 MPH / 14.3 MPG @ 70MPH
    RPM 2500 RPM @ 65 MPH / 2100 RPM @ 70MPH
    After 62-65 MPH you began to get a steady performance or lost on MPH or an increase of RPM.
    Winds of 25-35MPH decrease almost 5 MPG @ 65 MPH and increases
    RPM to keep 70MPH up to 2500-2800RPM.
    On 15 to 25 grades going up, there is no way to use D 4th is the only gear to get it up and is normal a 50MPH speed @ 2000-2250 RPM
    Total aprox weight on RV is 3,000 pounds. Everything loaded (except water in their tanks).
    RV tires are 15" at 50 PSI.
    DAMN! I need the TSB on my '08, it has been reduced almost 2" in the back when towing and there is around 450 pounds tongue weight.
    END POINT... AFE is GREAT!
  2. Jun 16, 2008 at 4:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Good post! :)
  3. Aug 20, 2008 at 6:47 PM
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    Seriously..??!! 2 mpg gain?? I get 20 mpg daily driver, 16 towing Fleetwood Niagara.. It's Houston, so it's pretty flat... AFE/K&N.. expect same results? Does it feel stronger when towing?
    I just the TSB done, it's a great improvement for towing with a load in the bed. Great Truck, add cold air intake and get 50+ horses, and 2 mpg improvement??? Why wouldn't Toyota do it from the factory?
    Gonna have to buy one now..
    -Sam
  4. Aug 20, 2008 at 6:50 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    go with just a filter......not the complete intake. not worth the money.....and in no way,with an intake will you get 50 more horses.
  5. Aug 20, 2008 at 6:53 PM
    SamSter0077
    Katy, TX
    Hey MVEGA1969 do you have photo's? Was it easy to put in, would you do anything differently?
    -Sam
  6. Aug 20, 2008 at 6:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    all he put in was the drop in filter......just open the airbox and pull old one out, put new one in.
    sam.....did you remove the secondary airfilter yet?
  7. Aug 20, 2008 at 7:01 PM
    SamSter0077
    Katy, TX
    Nah, have not done anything under the hood. Have been very happy with it, I am not really into going fast, but Improving Gas Mileage and towing Gas mileage.. Big time interested. I was thinking about doing the cold air intake from K&N.. surely MVEGA1969's results are not "just" a better Filter.. are they??
    -Sam
  8. Aug 20, 2008 at 7:07 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yessir they are!!! just the filter!!! cold air intakes only work in the upper rpm's anyway........and these days,. trying to save gas........upper rpm's aint where you wanna be. remove your secondary air filter...locaed in the airbox, behind the reg. air filter, and put you an afe pro dry s drop in filter in. you'll have the truck idling better, and you'll have better gas mileage.....guaranteed. plus....with the afe.....you wont have to oil it.....just wash, and dry it!!!
  9. Aug 20, 2008 at 7:12 PM
    SamSter0077
    Katy, TX
    Just like that? if it's just another filter, than I bet it is cheap.. I didn't see it on my Google search, got a link by chance?
    Thanks,
    Sam
  10. Aug 20, 2008 at 7:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    there was a group buy here not too long ago.....you may still be able to get in on it..........try this link and look thro some of these threads for more info......its gotta be there somewhere.
    http://www.tacomaworld.com/forum/search.php?searchid=28870
  11. Aug 20, 2008 at 8:02 PM
    SamSter0077
    Katy, TX
    Wow, long thread.. thanks for the heads Up! Will remover the Secondary this weekend, and order the AFE Dry filter.
    Thanks,
    Sam
  12. Aug 20, 2008 at 8:05 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no prob man!!:)
  13. Aug 21, 2008 at 4:58 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    13 TRD OR DC MGM
    Stock for now
    x2
    Thanks for the info mvega. How many tanks have you run through your truck or mileage on the AFE? Since putting in mine, I haven't used the truck much so I don't have the data you have. Just curious. Thanks.
  14. Aug 21, 2008 at 6:03 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    i haven't seen these great gains with the drop in yet, its hard to give it too much credit...I'd attribute most of the gain to the removal of the secondary filter. Overall i might have to sell and go AFE stage 2 54-81162 with the enclosed box...I love the way that intake looks..similiar to my old S&B for my titan - any offers for a slightly used AFE drop- in? shoot me a pm and its yours
  15. Aug 21, 2008 at 6:55 AM
    mvega1969
    Laredo
    Well, I have not removed the secondary air filter yet, and the numbers already presented has been the same. On my last towing trip of almost 500 miles (roundtrip), things got a little bit better (1-2MPG), using only PREMIUM ($3.71 -Exxon- Laredo & San Marcos gas stations). I felt that there is not enough gain (with my towing & non-towing setup) using the PREMIUM, I mentioned the two places where I fill up during this trip because even being the same gas company (Exxon) but different gas stations the one on San Marcos gave more MPG (3-4) than the one in my hometown (Laredo). When I got back to Laredo and after almost 4 full tanks of PREMIUM gasoline I fill it up with UNLEADED, I noticed almost immediately that you get faster high MPG (it goes easier up to 20+MPG) but in the long run it does not go more then 330 miles per tank.
    These are the numbers, PREMIUM gasoline on my setup is not worth.
  16. Mar 22, 2010 at 5:34 PM
    CPOSTED
    CPOSTED CPOSTED
    Hollis
    The Albany NY Area
    13 TACO TRD SPORT
    CAP, WINDOW VENT SHADES
    Question, what is this PRO DRY E thing you speak of? Not framiliar. Please advise thanks
    CPOSTED
  17. Nov 8, 2010 at 6:09 PM
    Flugelhornjazz
    Flugelhornjazz '06 4.0L 4x4 6-sp MT Access
    New England
    06' 4.0L 4x4 6sp MT Access
    AFE CAI, all synth fluids, 2.5" exhaust w/ FlowMaster, Optima Deep Cycle battery, Fog mod, SnugTop cap, HID headlights, silicone hoses
    The "Pro Dry" aftermarket air filter replaces the factory filter. I have one on my '06 4x4 V6. Performance filters have been available for many years from a handful of manufacturers. Most were the oil type; you massage or spray filter oil into the filter before installing it. The idea was that the oil would trap more dirt than OE paper filters. Well, newer vehicles have mass airflow sensors that get coated by the oil from the trick air filter...bad situation. That messes up the sensor, which sends corrupted data to the control module, which screws up mileage because the air temp/EFI timing/etc adjustments the computer is making are off. Many aftermarket companies like K & N and AFE offer free flowing dry media filters (Pro Dry for example). What you get is an extremely low restriction air filter that allows the engine to take in all the super clean air it can possibly gulp...with no downside. :cool:
  18. Nov 10, 2010 at 10:41 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    I can understand wanting more power with a new air filter but how is it physically possible that changing an air filter gives you 4 more MPH at the same RPM when you are not towing (66 v. 70 @ 2000 RPM)?
    And again, when towing how do you get a 5 MPH increase in speed with a 400 RPM reduction when you change the air filter (65 @ 2500 and 70 at 2100)?
    The tires, gearing and transmission ratio didn't change. How did you do that? Does not compute.
