After a 3' lift, how should I get the Alignment done?
Discussion in 'Suspension' started by wangluoqis, Nov 4, 2011.
  1. Nov 4, 2011 at 2:55 PM
    wangluoqis
    wangluoqis [OP] Active Member
    Regina Saskatchewan
    2013 Tacoma DC SR5
    Should i just the go to the shop an tell them to Align my wheels? or there is a specific number that i should use for the Alignment?
    ps: a have set of 16'' offset-12 rims and 285 75r16 tires.
  2. Nov 4, 2011 at 3:00 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    0 Camber, 0 Toe and the higher the Castor the better, shoot for 2 or better on the Castor if you can get there. With factory UCA's, I doubt you'll get that high though.
  3. Nov 4, 2011 at 3:03 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. With your setup, you will probably need aftermarket UCA's to get back into factory specs.
  4. Nov 4, 2011 at 3:04 PM
    98tacoma27
    Ben
    Not Beech Creek
    X3 here
  5. Nov 4, 2011 at 9:54 PM
    wangluoqis
    Regina Saskatchewan
    2013 Tacoma DC SR5
    what is the best option without aftermarket UAC's?
  6. Nov 4, 2011 at 10:01 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I've been told as much caster as possible. I have mine at roughly 2.5 but thats because my LCA's were seized.
    Without aftermarket UCA's they're just gonna try to get as close to stock as possible but it will never drive right, it will drive straight, but just feel loose.
  7. Nov 6, 2011 at 1:03 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    3 feet is a lot of lift! (title)
