After market lockers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AgingDisgracefully, Aug 3, 2022.
  1. Aug 3, 2022 at 12:58 PM
    AgingDisgracefully
    AgingDisgracefully [OP] Well-Known Member
    Peter
    2016 Tacoma SR5 V6 4X4
    After many delays I am moving toward putting lockers in my '16 SR5. I lean toward putting from and rear lockers in but wanted to sort of get a sense of whether many others have done front lockers and their pros and cons? My understanding is that you have to be very careful steering with front lockers engaged. Thanks
  2. Aug 3, 2022 at 2:03 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    you will probably almost never need the front locker in these trucks unless you are doing some serious offroading, even then I have not yet needed one.
    Pros and cons to the front, only pros for the rear
    71tattooguy, Mully, oconnor and 3 others like this.
  3. Aug 3, 2022 at 2:09 PM
    AgingDisgracefully
    Peter
    This is the great debate I am having. I think my main concern is crossing muddy streams. I have seen a TRD OR with rear locker on get stuck (I actually had to pull him out) and then a land cruiser with front and back lockers got through the same spot. It was close in both cases but the front locker I think helped.
  4. Aug 3, 2022 at 2:12 PM
    AgingDisgracefully
    Peter
    Which is not to say by the way that I am not weighing what you are saying. To be honest with you are am surprised by how few times I have had to engage four wheel drive.
  5. Aug 3, 2022 at 2:13 PM
    JoeCOVA
    Joe
    Colorado Springs
    80 series? Those things will drive circles around us.
    I hate mud and try to avoid it but that is a very good reason for a locker. The locker will help the the tires clean mud from the tread which otherwise may sit idle due to the inherent nature of open diffs.
    If you frequent mud often, then I would def consider one, if not you could always consider maxtraxx/treds winch etc.
  6. Aug 3, 2022 at 2:16 PM
    AgingDisgracefully
    Peter
    I am in the Carolinas and most of the time it is fine but when it gets really wet the clay soil here forms this insane mud.
  7. Aug 3, 2022 at 2:20 PM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    1) Buy the rear locker, use remaining money on a winch. [if there was a limit on money to be spent]
    2) no body remembers the day you didn’t get Stuck. :rofl:[recoveries = memories to clarify]
  8. Aug 3, 2022 at 7:16 PM
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    I don't use the rear locker often (honestly more often turn it on/off to keep the actuator and such from seizing than actual use)... but the two occasions where I really did need it I was really glad I had it and it was the difference between being stuck once and making it up a hill the other time. It probably also helped more than I realized a few other times when I put it on in advance as a precaution, and it's helps slow the truck some when descending very steep hills (with engine braking and the actual brakes)
  9. Aug 3, 2022 at 7:35 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    My advice: Sell Tacoma, buy Land Cruiser. Or it's much less reliable cousin Wrangler.
    Mully, cammerv8, CS_AR and 1 other person like this.
  10. Aug 3, 2022 at 7:38 PM
    AgingDisgracefully
    Peter
    Heh. I have a friend who has a 97 Land Cruiser. It is ... an experience owning if
  11. Aug 3, 2022 at 7:50 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Rear locker and a winch, I have never been stuck.
    Good luck with your truck.
  12. Aug 3, 2022 at 7:55 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
  13. Aug 3, 2022 at 7:58 PM
    JoeCOVA
    Joe
    Colorado Springs
    not everyone sees signatures...
    Chew likes this.
  14. Aug 3, 2022 at 8:10 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    If its a muddy stream no, I put ARB's front and rear and used it everytime we would wheel. Do you have to be easy on turning yes. Get over obstacle than immediately turn the front off. As far as the 80 series, yes it will outwheel a tacoma all the time. Ive got 2 and they are beasts. Nothing like them, front locker, center locker, rear locker, I6, can fit 37s with no lift, solid axles and linked, 93 and up are Full float rear end, 9.5 rear ring gear, They are beyond stout and underpowered. Simply amazing
  15. Aug 3, 2022 at 10:24 PM
    ShimStack
    Ben
    NC
    Fixed it.
    JoeCOVA[QUOTED] likes this.
  16. Aug 3, 2022 at 10:33 PM
    eon_blue
    Azusa, CA
    Unless your truck is built to conquer serious rock (boulder) crawling trails you most likely will never need a front locker, assuming you have a rear locker that is. Get a rear locker and you'll be good.
  17. Aug 4, 2022 at 4:44 AM
    AgingDisgracefully
    Peter
    I think streams and steep hills are a motivating concern
  18. Aug 4, 2022 at 4:53 AM
    AgingDisgracefully
    Peter
    So I was thinking about having a regear done as well when having lockers installed. Can you even regear just the rear? Would four wheel drive still work?
  19. Aug 4, 2022 at 5:04 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    If you regear just the rear and engage 4WD you're going to have a bad day. Have to regear front and back if you plan on using 4WD.
    Mully likes this.
