After market lug nut size
Discussion in '5 Lug' started by SleazyPetey, Oct 23, 2015.
  1. Oct 23, 2015 at 8:19 AM
    SleazyPetey
    SleazyPetey [OP] Popeyes > KFC
    Pete
    Northern Virginia, USA
    2013 Regular Cab
    The wheels I'm going to purchase require different lug nuts because our stock ones are too fat. When looking at purchasing new lug nuts, there are three options:
    1. 1/2" -20 SAE thread size
    2. 9/16" -18 SAE thread size
    3. M14x1.5 Metric Thread size
    As well as these other options:
    M12x1.25 Metric thread size
    M12x1.5 Metric thread size
    M14x2.0 Metric thread size
    Which one of these will fit the 5 lug taco?
    Any help will be appreciated
  2. Oct 23, 2015 at 4:51 PM
    Clearwater Bill
    Billy
    Largo Florida
    pretty sure they are 12x1.5
    Go to a parts house like Advance Auto. They often have studs mounted on a rack. Take one of your lug nuts in and verify fitment.
  3. Oct 25, 2015 at 12:55 AM
    tacomatt602
    tacomatt602 Well-Known Member
    Phoenix, AZ
    1997 5lug Regular Cab 2.4l
    Doetsch spindles, V6 coils, Fabtech AAL, 4Crawler 2" body lift, Daystar coil spacers, Bilstein 5100s (rear), 15x7 U.S. Wheel Stealth Stars, 225/70r15 Firestone Destination LE2s, '00-04 side mirrors, Prerunner/4x4 grille, Kobalt low-profile toolbox, fucked steering rack D:
    ding ding ding!
  4. Oct 25, 2015 at 7:23 AM
    SleazyPetey
    Pete
    2013 Regular Cab
    Got it. Thanks :)
  5. Oct 25, 2015 at 7:52 AM
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
  6. Oct 31, 2015 at 8:27 AM
    HackD
    William
    FYI .. I just received the above lug-nut set from Amazon.ca. Appear to be of good quality. They will be going on my aftermarket rims, when i receive my 60.1 to 73mm adapter rings. At present, i'm running my stock lug-nuts .. but i also need to carry a socket-set around with me in case of a flat-tire - the stock tire-iron wouldn't fit in the small holes of the aftermarket rims.
  7. Oct 31, 2015 at 8:39 AM
    SleazyPetey
    Pete
    2013 Regular Cab
    My hub centric rings just came in the mail today. My old man's friend, the person who put on my wheels and tires, said your wheels will vibrate like crazy and the lugs can possibly come off if you don't have hub centric rings that match your vehicle's bore width. Couldn't find 60.1 to 83.06mm if my life depended on it so I had to order from a website that makes custom hub centric rings. which was pricey :(
  8. Oct 31, 2015 at 8:52 AM
    HackD
    William
    That is an odd size for hub-centric ring adapters, indeed.
    I have run my aftermarkets for some time without them, but since the suspension upgrade went on (last time rims were removed) i've noted a mild vibration in the 110-120km/h range, smoothing out again > 120km/h. I'm betting one of the front rim assemblies is ever so slightly off-center when put back on.
    No lug nuts missing so far.
  9. Oct 31, 2015 at 9:06 AM
    SleazyPetey
    Pete
    2013 Regular Cab
    I had to get aftermarket lugs for my new wheels. Same size, 12x1.5, but it has to have a 60 degree conical seating. Did you get new wheels? Or do you still have the current ones on your rig
  10. Oct 31, 2015 at 9:15 AM
    HackD
    William
    Still the current Aftermarket 16x7 with +40 bs.
    Waiting for the first snows to hit, to see how these wheel-sets work out - I might replace with different rims and tires, if current rubber isn't up to the task, going with a rim-set with +10 bs and more aggressive tread pattern, this time around. I was playing with the idea of spider-trax spacers.. but it seems like a compromise that might well not be the safest.
  11. Oct 31, 2015 at 9:18 AM
    SleazyPetey
    Pete
    2013 Regular Cab
    Gotcha! Where do you live that snow might be a big issue? But me know how it works out! I avoided the wheel spacers and went with a wheel with a very low offset to give it some stance.
  12. Oct 31, 2015 at 9:22 AM
    HackD
    William
    Southern Ontario - generally we don't receive a whole lot of snow overall, but we do receive a few dumps throughout the winter from Lake-effect squalls. Black ice is actually a bigger issue than snow remaining on the roadways after a storm clean-up..
    And yeah .. i'm thinking offset .. not bs .. I mix those two up all the time.
