After Market Mirrors with Turn Signal Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MC68440, Apr 26, 2014.
  1. Apr 26, 2014 at 7:18 PM
    MC68440
    MC68440 [OP] Active Member
    Los Angeles CA
    2013, 4x4 Access, TRD Dark Blue
    No Mods, more of add-ons.
    My 2013 Access TRD came with sock non turn signal side mirrors. I wanted to put mirrors with turn signals on it so I checked here. There were a few posts here but the jest of it was as long as you have 5 wires at the connector, then the harness supports side mirrors with turn lights. :D
    Well I ordered the mirrors and installed them - but of course, the turn signal lights don't light. :mad:
    Any one add these types off mirrors on a 2013 Access TRD?
    I checked for any blank fuse slots that may need a fuse but did not find a single one. :confused:
    Any suggestions??
  2. Apr 26, 2014 at 8:42 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Do you have voltage to the wires (truck's connector side) when you use the turn signals?
  3. Apr 26, 2014 at 8:57 PM
    MC68440
    Los Angeles CA
    I'll check that tomorrow but I suspect not.
    So it sounds like:
    If voltage - no bulbs in the mirrors :eek: or plugs on mirrors not wired correctly :eek: but the power mirrors do work :confused:
    If no voltage - the other end of the wiring harness isn't hooked up :eek::eek: or there's a fuse that's needed?
  4. Apr 26, 2014 at 9:06 PM
    File IFR
    Central MA
    Did you buy a Toyota mirror housing/signal unit or an aftermarket... what brand? If you have a Toyota unit, they have LEDs in them (3 each side), so no 'bulb' is needed.
    AR15xAR10 likes this.
  5. Apr 26, 2014 at 9:22 PM
    MC68440
    Los Angeles CA
    They are after markets - have no idea if they are LED or not. No instructions or anything supplied, fit perfectly but I'll take them apart tomorrow.
    These are them:
    http://www.ebay.com/itm/37092594313...l?_from=R40&_sacat=0&_nkw=370925943132&_rdc=1
  6. Apr 26, 2014 at 9:48 PM
    File IFR
    Central MA
    At the truck's connector, how many wires are enclosed in the cable... not the pins at the connector, but the wires in the cable?
    This will determine if your truck has it wired for future turn signals.
    3 wires run the power mirror, one (-) and two (+).... IIRC. Then you need 2 more for the LEDs/lamps.
  7. Apr 27, 2014 at 7:22 AM
    MC68440
    Los Angeles CA
    There are 5 wires at the connector in the door and 5 wires in the mirror's connector.
    I'll verify and post pictures in a few.
  8. Apr 27, 2014 at 7:59 AM
    MC68440
    Los Angeles CA
    So the connectors have 5 wires each. I also measured the voltage at the two additional wires for the lamps / LEDs - no voltage present when signal is on :mad:
  9. Apr 27, 2014 at 11:12 AM
    MC68440
    Los Angeles CA
    Ya, OK, I found the problem with these signal mirror not working...:mad:
    So, there are 5 wires in the harness AT THE MIRROR CONNECTOR :D
    but not on the other end of the harness :eek:
    So, the door wiring harness is wired for turn signal mirrors, but the wiring harness in the cab is not!
    Traced the wires back through the door and to the passenger's kick panel. Found the interconnection plug and saw that while the wires from the mirror lamps go in the plug, but the mating socket doesn't have them coming out. Also, there are no loose wires near the connectors to tap ...the main wiring harness doesn't have them wired.
    I guess I could run wires myself but at this time I'm not in the mood - oh well :(
    AR15xAR10 and Norton like this.
  10. Apr 27, 2014 at 12:25 PM
    File IFR
    Central MA
    It seems like you know whats going on now.
    Find the harness/wires from the turn signal stalk on the column, splice in and bring new wires to the empty harness under the dash.... or something like that.
    :thumbsup:
    ** Edit. LEDs take 3 volts, I'm sure the LED board on the mirror already has resistors to knock the voltage down from 12v to 3 v. I haven't heard of any issues there, so you'd be fine as it is.
  11. Apr 27, 2014 at 2:09 PM
    MarkH
    MarkH Well-Known Member
    Mark
    San Jose, CA
    13 PreRunner TRD Off Road
    I put the LKQ ProEFX towing mirrors on my 2013 TRD OR Access Cab and the turn signals worked just fine with the wiring that was in place. I did not have to run any additional wires.
    Norton likes this.
  12. Apr 27, 2014 at 3:37 PM
    MC68440
    Los Angeles CA
    Thanks for the suggestions and help! ;)
  13. Apr 27, 2014 at 3:43 PM
    MC68440
    Los Angeles CA
    Is it a PreRunner? :confused: Maybe they have different wiring than the 4x4's.
  14. Apr 27, 2014 at 4:03 PM
    Bunk454
    Bunk454 Well-Known Member
    Huntsville, AL
    '13 MGM DCSB TRD Off-Road
    I installed the exact same mirrors, but was NOt able to get the turn signals working. Same problem as the OP. The wiring is there (in the doors), but no voltage.
    I never traced the wires into the harness, but I suspect that different models trucks had different harnesses installed....which is curious to me, as I would have thought it would be cheaper to stick with a standard harness for all models.
    Norton likes this.
  15. Apr 28, 2014 at 9:53 AM
    MarkH
    Mark
    San Jose, CA
    Yes, I have a PreRunner.
  16. May 18, 2014 at 7:31 AM
    double dee
    double dee Well-Known Member
    Arizona
    I'm trying to figure out getting my turn signals to work as well. After reading other threads I am trying to make sure I understand this. I have a 2014 off road and have the correct wires in the door but not elsewhere. I need an add a fuse from the turn signal under the dash to the pink + wire in the door panel. then ground the white - wire in the door?
  17. May 19, 2014 at 10:18 AM
    MC68440
    Los Angeles CA
    Well, I never followed through with my wiring but I did find the wiring diagrams for my 2013 - I think it should be the same idea with the 2014's.
    Looking at the diagrams, it seems like the "Flash Relay" is your best shot at getting the signals. It has both the left and right signals as well as hazard and best of all, it is fused. On trucks that have the turn indicator mirrors, those mirrors are connected there also. Specifically, the Right Hand Mirror connects to pin 18 of the Relay, and the Left Hand goes to pin 9. Looking at the diagram you can also use 7 and 5 or even 11 and 4 if you don't have the "Shorting Pins" installed.
    Again, I have not wired mine at this time but when I do, this is the route I'll take. I don't like the steering column idea because I want both mirrors to flash when (if) the hazards are on. The other side of the LED lamps go to ground. I have attached the parts of the electrical diagram I was referring to.
    I would not trust the wire colors as I have heard that they can change over the model years. Just find the relay (listen for where the click click click is coming from :p) then check for the right voltage at the right time and place, tie in that spot.
    Also, since you have a 2014, I'm pretty sure it is still covered under Toyo's warranty - I have no idea how this would effect the warranty but disclaimer disclaimer etc...
    Let us know how it turns out!
  18. May 19, 2014 at 10:28 AM
    eliasj7
    eliasj7 Well-Known Member
    Elias
    Beaverton, OR
    2013 Tacoma TRD Offroad
    5100's w/ OME 885X, LR UCA's, OME Dakar Leaf Springs w/ OME Nitrochargers. Grillcraft MX Grill w/ white grill trim. AFE Intake. Redline Tuning Hood struts. ADD W1 Oil Catch Can. TRD Cat Back Exhaust.
  19. May 19, 2014 at 4:47 PM
    voz
    voz Nothing Witty To Say
    VOZ
    VOZLAND
    The Clean One
    In Progress, Progressively
    subd
  20. May 27, 2014 at 8:03 PM
    double dee
    Arizona
    I wish someone would do a write up with pictures so I can get these things working :(
