After removing the black box....
Discussion in 'Wheels & Tires' started by Murphy, Oct 12, 2010.
  1. Oct 12, 2010 at 3:58 PM
    Murphy
    Murphy [OP] Member
    I needed to cut the fender and remove the black box for new rims. Do you need to re-line the area again, or just left it alone? What did you use (a Rhinex type spray)? Does the black box not really do anything ,or was it not a good idea to remove it?
    Thanks for your time.
  2. Oct 12, 2010 at 4:04 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I didn't do anything to the area after cutting the liner and removing the box. If you're worried about it then it might be a good idea to spray the area with some undercoating or something like that. The area behind the liner was painted, so I'm not too worried but I live in the south and we don't get that much snow/ice ie. road salt.
