Aftermarket drop in filter Vs. Full aftermarket CAI
Discussion in 'Performance and Tuning' started by WheelinJ91, Apr 15, 2012.
  1. Apr 15, 2012 at 9:46 AM
    WheelinJ91
    WheelinJ91 [OP] Well-Known Member
    Edmonton,AB
    2012 TRD DCSB
    Airaid Intake, MBRP Exhaust, Toytec OME 3" lift w/AAL, Flip-kit, LR UCA's, Weathertech Floor mats, hood and window deflectors.
    Hey so im board at work and figured i would ask people oppinion on this,
    I have a 2012' Tacoma, AFE happens to have a aftermarket "Drop in" filter for somewhere around 80$ + shipping if i cant find a place that sells them near me.
    I would like to eventually get a full CAI but i am wondering what extra benefits does a full on CAI have ?
    And would it be worth me saving my 80$ and waiting for a CAI to come out for the 12'?
    Thanks
  2. Apr 15, 2012 at 10:02 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I'll be the first to say stock is best if you want best protection.
    Power gains are minimal and no MPG gain.
  3. Apr 15, 2012 at 10:03 AM
    WheelinJ91
    Edmonton,AB
    2012 TRD DCSB
    This is to what? Drop in after market filters or full on systems?
  4. Apr 15, 2012 at 10:46 AM
    WheelinJ91
    Edmonton,AB
    2012 TRD DCSB
    Im getting a MBRP exhaust.
  5. Apr 15, 2012 at 10:48 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Only thing after market CAI is going to give you is a sound update. So unless you want louder sound, then get a drop in filter.
  6. Apr 15, 2012 at 3:00 PM
    WheelinJ91
    Edmonton,AB
    2012 TRD DCSB
    I am planning on getting a S/C when they come out with them for the 2012, would this change the situation a bit? I would like the best protection but also performance and the sound will be nice for sure. If i didnt plan on S/C it i would look at throttle body spacer.....
  7. Apr 15, 2012 at 3:15 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    IMHO cai's only significant benefit would be letting you run a pre filter when your offroad and being able to take it off for the street.
  8. May 2, 2012 at 6:27 PM
    Gasitman
    Gasitman Member
    Gig Harbor, WA
    After reading many threads, I will just buy a K&N for the simple fact that it is buy once, cry once. A normal air filter from the stealer is almost $30, a K&N is around $60. Seems to me you will save some $$$ just cleaning it up.
    Thread after thread says no gains with a CAI unless it is hooked up to the TRD blower.
  9. May 3, 2012 at 11:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Is it washable and reuseable?
  10. May 3, 2012 at 11:49 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    AFE drop in FTMFW!!
  11. May 3, 2012 at 11:56 AM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    Afe pro dry s
  12. Aug 4, 2012 at 8:21 PM
    FunTaco
    FunTaco Member
    Vancouver, WA
    08 DBC SR5 4x4 LB
    Just some bitchin' seat covers :), oh ya and a Hard tonneau cover with Yakima sport tracs for movable towers-cross bars & 4 yakima bike racks. I'm working on more
    I have to partially disagree. I say partially because I haven't done it to my truck yet but it will be happening in the next couple of months. (first will be the URD True CAI next week, then exhaust of some kind next month) Soooo. my disagreement argument is that the engine is an air pump (some will say air / fuel pump) Either way an engine uses some of the energy is produces to move that air in and out or through the engine. So if you decrease the resistance, or drag on that air movement you decrease the energy used by the engine to pump it. Now in theory this should leave more power to go the wheels and therefor reduce the amount of fuel you need to deliver to maintain or gain the same speed. Increased efficiency increases MPG. The problem is that increased efficiency also give more "available" accessible power however small that may be, and we all (ok maybe just me) like the sound and feel of that power and we use the shit out of it. so we end up not seeing any increased mileage usually. driving habits will the be the biggest factor as to if you can not rape that extra power and leave it for the increased mileage.
    now that all being said, it doesn't do a whole lot (but still a little) if you only open up one or the other, the intake or the exhaust. They need to both be done and done modestly for a V6 compared to a high displacement V8 to retain some back pressure needed in these new I-robot freaking engines.
    whew. I'm tired now
  13. Aug 5, 2012 at 7:00 AM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Haha I was looking through seeing if someone else would say that lol, but I'm no better. I made a post and spelled the title wrong last week
  14. Aug 5, 2012 at 7:13 AM
    UNDEAD1153
    UNDEAD1153 Well-Known Member
    Weston
    Chattanooga Tennessee
    White 2011 TX Pro Double Cab
    Rough Country 6" lift, 17" XD Addicts, 315/70/17 Nitto Trail Grapplers, 6K HID's, Wet Okole's, Kenwood DD head unit, Custom Exhaust
    Isn't the reason CAI's are louder because it's removing the secondary air filter? Wouldn't you get the same result (sound wise) by adding say an AFE Pro Dry S filter and removing the secondary filter? Or are you also getting sound from somewhere else??
  15. Aug 5, 2012 at 7:29 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I think more of it has to do with the resonance through the tube. Idk for sure, just a feeling I have. I have an AFE pro dry s drop in on mine and I removed the secondary filter but noticed no change in noise.
  16. Aug 5, 2012 at 7:32 AM
    UNDEAD1153
    Weston
    Hmmm.....maybe could be coming from the box and like you said the tube. Did you notice any changes at all with what you have done? (mpg's, hp)
  17. Aug 5, 2012 at 9:05 AM
    NtacomaR
    NtacomaR Well-Known Member
    nick
    sparks
    2012 Tacoma Baja
    suspension, wheels, rims, trd exhuast, CAI
    i will be installing the new Airaid cai intake in my 2012 baja...i will also be doing a before and after dyno...i run 91 octane BTW. i will be doing the dyno either monday or tuesday. thread title under Performance will be "Dyno Results for 2012 Baja With Airaid intake"
  18. Aug 5, 2012 at 9:22 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  19. Aug 5, 2012 at 7:14 PM
    WheelinJ91
    Edmonton,AB
    2012 TRD DCSB
    I just installed the Airaid for 2012 like a week ago, I didn't do a dyno or anything but i did see i improvement in power and pickup, I cant wait for the exhaust to get in.
    Also i left the lid thing off for now i will put it on during the winter though, and may just put it on a leave it but who knows haha.
    Edit: I also have a M/T truck, so i notice it a lot when I shift.
  20. Aug 5, 2012 at 8:53 PM
    UNDEAD1153
    Weston
    By tune, do you mean dyno tune or like the URD MAF calibrator?
