Aftermarket front camera
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johnnytwotimes, Apr 3, 2021.
  1. Apr 3, 2021 at 12:24 PM
    johnnytwotimes
    johnnytwotimes [OP] Well-Known Member
    SoCAL
    2021 TRD OR DCSB
    Just purchased a OEM Pro grille from Toyota same price as aftermarket ones it was a no brainer but obviously came with the front cam mount already. Where can I get an aftermarket front camera?
  2. Apr 3, 2021 at 8:53 PM
    kyledamon
    kyledamon Well-Known Member
    Kyle
    Burlington, VT
    2016 AC TRD OR
    Interested as well..
  3. Apr 3, 2021 at 9:00 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    Pretty much anywhere. Depends how involved you want to be. You can source individual parts and build a kit or you can check out anytimebackupcamera.com
    johnnytwotimes[OP] likes this.
  4. Apr 3, 2021 at 9:11 PM
    johnnytwotimes
    SoCAL
    2021 TRD OR DCSB
    Will do
  5. Apr 3, 2021 at 9:19 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    The anytime camera doesn’t mount quite the same way as the the new heritage grille. The grill requires a cube style camera with a plug out the rear
    , where as the anytime is wedge, almost 45 degrees and the wiring runs though a post that would interfere with that heritage grill mount. There is a kenwood one for $99 that keeps popping up on my searches I just haven’t gotten up the nerve to get one yet. 5F240BE9-C5B3-4F0B-BF64-D2A52A67C09F.jpgIf you zoom in there you can see the top camera spot is just a blank and there is an anytime camera in the Toyota letters
    danoo and johnnytwotimes[OP] like this.
  6. Apr 3, 2021 at 9:22 PM
    waltuo
    Toyotas
    Why not? The Natika ( premium camera as they call it) can be mounted horizontally.
  7. Apr 3, 2021 at 9:25 PM
    DamGuide
    DamGuide Well-Known Member
    Nooga, TN
    2020 TRD Offroad
    I can make a mount for two types of cameras currently and working on a third from the advice of a member here that may work better. Been charging around $8 to make one.
    These are the two cameras I currently do.
    https://www.amazon.com/gp/product/B07TPD5DYR/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8
    https://www.amazon.com/gp/product/B07HNRYHZ6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8
    Will start working on the third when I get back from the beach. Let me get some photos of both of the above from my mobile phone.
  8. Apr 3, 2021 at 9:30 PM
    DamGuide
    Nooga, TN
    2020 TRD Offroad
    This photo is the Nakita which has a much wider field of view, but it picks some of the grill on the corners because of that. Wider field of view isn’t as good of an image as well. The Nakita doesn't fit as well as the Ruyeot, but I had the Nakita on my original 2020 OR grill and tried to make it work with this one as best I could. It is a bit too wide to fit all the way snug against the front of the camera slot. Will have to get the Ruyeot tomorrow which I have on the truck currently. Second photo is of the mounts.
  9. Apr 3, 2021 at 11:04 PM
    johnnytwotimes
    SoCAL
    2021 TRD OR DCSB
    PM’d
  10. Apr 4, 2021 at 6:51 AM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    It can be mounted horizontally but it doesn’t fit into the oem spot. It does look like you need a bracket though
  11. Apr 4, 2021 at 7:21 AM
    waltuo
    Toyotas
    I see. There’s always :sawzall:
    Benny blanco[QUOTED] likes this.
  12. Apr 4, 2021 at 7:27 AM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    I recently acquired the heritage grill with the trd level/lift. The whole grill needs to come out to mount the camera ( the top screw is hiding behind some plastic) I haven’t taken the grill out yet because my anytime camera that I had on the the OR grill was able to be mounted a little lower. I just wanted to mount it quick and head out to Death Valley.
  13. Apr 4, 2021 at 7:31 AM
    DamGuide
    Nooga, TN
    2020 TRD Offroad
    yeah it’s a pain in the ass to tweak mounts because of this, I usually end up installing my or grill for a week while I play around with it in the house. I just don’t want to cut an accessible hole in the rest of my grill.
  14. Apr 4, 2021 at 8:00 AM
    danoo
    danoo Well-Known Member
    2021 Trail Edition
    Interested here as well. I also have an oem pro grille and i want to put a camera in the existing camera hole. Open to aftermarket solutions. But curious, Can you hook up an oem front camera to the anytime kit?
  15. Apr 4, 2021 at 8:27 AM
    DamGuide
    Nooga, TN
    2020 TRD Offroad
    I looked at this option and the answer is probably if you make a harness or just hardwire it up, but the cost is high when these aftermarket cameras are like $20. OEM Camera is like $400 new and that’s a tough pill to swallow to test it.
    Here is the Ruyeot installed
  16. Apr 4, 2021 at 10:56 AM
    danoo
    2021 Trail Edition
    which is the best camera you’ve tested?
  17. Apr 4, 2021 at 11:03 AM
    DamGuide
    Nooga, TN
    2020 TRD Offroad
    I currently like the Ruyeot because it fits the hole the best and has a cleaner image due to lower FoV. You don’t see as much though, so the 210 FoV is better if you want to see more, the grille camera hole is only visible in the extreme corners of the image on the screen, it’s a very wide view. I’d like to find a 190 FoV and see if I could get a mix of both.
    I’m gonna order the third camera for when I get back from the beach and see if I like it. It’s 170 FoV as well. It will be mounted in front of the hole and you hopefully won’t see the hole at all. Just need to see if I can mount it securely where it won’t twist.
    piratepegleg likes this.
  18. Apr 4, 2021 at 11:12 AM
    AZ_TACO
    AZ_TACO Well-Known Member
    Desert Southwest 33.41512, -111.83148
    2009 PreRunner TRD OR
    Toytec Boss 2.5” Front Toytec & Block 1.5” Rear SPC UCAs CMC Black Rhino Warlords BFG KO2s aFe Wet EA Filter Overhead Temp/Compass repair x3 Rigid D Series Pro Blood Sweat Some tears.
    I wonder if anyone who has a front camera and lower bumper light bar like the hidden caliraised or even flush mount notice glare or any issues with image?
    shotgunbilly420 likes this.
  19. Apr 4, 2021 at 1:58 PM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
  20. Apr 4, 2021 at 2:07 PM
    DamGuide
    Nooga, TN
    2020 TRD Offroad
    If you have the anytimebackupcamera system it plugs right up, no issues. That’s the one I have.
