Aftermarket front camera
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johnnytwotimes, Apr 3, 2021.
  1. Aug 20, 2021 at 4:05 PM
    #121
    npego
    npego Well-Known Member
    2018 Quicksand TRD OFFROAD
    I taped the connection of the red and black plug. Then I took the black/red wire and put on a one of those ring wire connectors on the end and grounded it under the horn bolt.
  2. Mar 9, 2022 at 7:02 PM
    #122
    danoo
    danoo Well-Known Member
    2021 Trail Edition
    Resurrecting this thread. Is there consensus on the best aftermarket camera to use when mounting in the oem pro grille hole?
    piratepegleg likes this.
  3. Mar 21, 2022 at 4:19 PM
    #123
    piratepegleg
    piratepegleg Well-Known Member
    Davey
    Texas
    2022 Lunar Rock TRD OR
    Pro grill, leer 100XR
    has anyone tried this one?
  4. Mar 26, 2022 at 11:30 PM
    #124
    81malibu81
    81malibu81 Well-Known Member
    '21 TRD OR DCSB 6MT S/C
    Maybe a description or link to that camera would be helpful...
    I've got the raayoo, not installed. Ill need a set of something similar to 'reducing washers' as we refer to them in the trades (as mentioned earlier in this thread). Now that I see that one though, I am wondering if the degree of the pitch could be useful in determining how close my front bumper is to something because I'm assuming with it faced down like that the bumper would be in the fov.
    Also, after mocking up the raayoo its clear to me that the one you have pictured would be easier to mount because of it's square shape.
    The raayoo is the perfect size- so perfect, in fact, that it just barely slips through the mounting hole on a pt228-35200 pro grill which necessitates a washer/ bezel of some sort.
  5. Apr 6, 2022 at 3:00 PM
    #125
    Emailyourpassword
    Emailyourpassword Member
    2018 trd offroad
    yes! wondering what you found. lots of feedback on how people modified but wonder if there is a winner.
    Also do most of these camera work with the ABC kits?
  6. Apr 6, 2022 at 3:21 PM
    #126
    DamGuide
    DamGuide Well-Known Member
    Nooga, TN
    2020 TRD Offroad
    I’m still using the ruyeot, I like the way the rayoo or whatever looked better, but happier that I know I won’t have any issues with it rotating and I don’t have anything sticking it in place besides an easy to remove mount.
    All the ones I posted work with the ABC kit, that’s what I have.
  7. Apr 6, 2022 at 3:55 PM
    #127
    Emailyourpassword
    2018 trd offroad
    so you have the the link for that one, the rayoo?
    As well did you have to 3d print or something?
  8. Apr 6, 2022 at 4:41 PM
    #128
    DamGuide
    Nooga, TN
    2020 TRD Offroad
    It’s all in this thread. I am using a 3D printed bracket with the Ruyeout
  9. Apr 6, 2022 at 8:25 PM
    #129
    oldtoyman
    oldtoyman Small bore freak
    Kevin
    North of Seattle
    1994 Harley heritage,2019 Honda Monkey,2023 klx300 , 2013 prerunner TRD off-road
    Anyone have a link to purchase the Ruyeout camera. I have search all the different spellings and can not find it. thanks
  10. Apr 6, 2022 at 8:58 PM
    #130
    Emailyourpassword
    2018 trd offroad
    PM’d you regarding the 3D printed mount
  11. Apr 6, 2022 at 9:50 PM
    #131
    DamGuide
    Nooga, TN
    2020 TRD Offroad
  12. Apr 25, 2022 at 7:58 PM
    #132
    81malibu81
    Can you clarify this? I have the rayoo plus anytime and I am getting no imgage from the front cam. I taped the red wire coming off the yellow plugged RCA as I have read that it is not needed (and hot). The pair of red and black wires off of the black RCA (that connects to the red rca on the cam) - I cut/taped the red and only grounded the black (after separating the wires). In your comment it seems like you are saying you grounded both the red AND the black for that pair- is that correct?
    Any info would be helpful and much appreciated!
  13. Apr 25, 2022 at 8:14 PM
    #133
    81malibu81
    Did you ever figure this out? What did you do with that pair of black and red wires?
  14. May 12, 2022 at 8:34 PM
    #134
    MoneyB86
    MoneyB86 Well-Known Member
    Reagan Country, CA
    2019 MGM Tacoma Double Cab
    I just finished the install and let me tell you what I did to make it work.
    I installed this using a Heigh10 headunit, so it may be slightly different with yours. The RCA video cable has a small red power cable on each end. I used the red end next to the headunit and connected it to the 12v power cable at the headunit.
    The RCA red cable on the camera end is attached to the red cable on the Black / red wire pair. The black cable on the pair I grounded. This made it work.
  15. Apr 4, 2023 at 6:14 AM
    #135
    jrgrieve
    jrgrieve Well-Known Member
    Justin
    2022 Tacoma SR
    @DamGuide, are you still making the 3D print mount for the Natika ABC?
    hotrod 15 likes this.
  16. Apr 10, 2023 at 7:20 PM
    #136
    DamGuide
    Nooga, TN
    2020 TRD Offroad
    yep, I don’t check daily, but I’m still around
  17. Apr 10, 2023 at 8:11 PM
    #137
    jrgrieve
    Justin
    2022 Tacoma SR
    I'll shoot you a DM. Would like to pick one up.
  18. Apr 11, 2023 at 7:56 AM
    #138
    LeFreakyBone
    LeFreakyBone Well-Known Member
    Santa Cruz
    2021 Off-Road Midnight Black Metallic
    Leopard print steering wheel cover
    I’d be interested in purchasing the mount too if you are still making them!
  19. Jul 19, 2023 at 6:16 PM
    #139
    Taco_boy123
    Taco_boy123 New Member
    Oscar
    2018 Toyota Tacoma inferno
    Eibach stage 1 with ome Dakar leafs
    Has any figured out how to remove the lines and reverse image? I just installed ruyeout camera. On Amazon it said cut green wire
  20. Apr 4, 2024 at 6:27 PM
    #140
    Jeffmo86
    Jeffmo86 Well-Known Member
    2021 SR5 Tacoma Nightshade Edition
    None at this time
    What is the part number for that grille? I want to get the same one.
