Aftermarket front camera
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johnnytwotimes, Apr 3, 2021.
  1. Aug 18, 2024 at 8:29 AM
    #141
    NotAnAustrailianLawyer
    NotAnAustrailianLawyer New Member
    Tom
    Tacoma!
    If I have a Tacoma with a rear facing camera that came with it new and I install an aftermarket front facing camera how do I control when the front facing camera is on? Is there a programmable button on the console that I can use to turn the screen to the front facing camera when I need it?
  2. Aug 18, 2024 at 8:50 AM
    #142
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
  3. Aug 18, 2024 at 10:56 AM
    #143
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    Trail Grid Pro has Anytime Front/Rear Camera Kit, for $30 more, you can have them pre-solder connectors. So it will be “plug and play” when get kit.
  4. Aug 18, 2024 at 10:57 AM
    #144
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    The anytime backup camera kit comes with a multi switch that lets you switch between front, back or off "anytime". Even when driving.
  5. Nov 4, 2024 at 5:06 PM
    #145
    3Sheetz
    3Sheetz Member
    Went through the entire thread.
    I have a 2023 OR with no front camera + OEM trd pro grille. Can anyone confirm if my understanding is correct?
    - The ABC is needed to allow me to add a front camera and use it with my stock head unit
    - The Nakita camera that comes with the ABC doesn't fit the camera hole on the OEM pro grille, but it can fit using a bracket (Damguide can 3d print one)
    -There are other cameras that can be used with the ABC, but none of them fit the hole on the pro grille unless we rig it ourselves, or use the Ruyoet camera and get a custom 3d printed bracket from Damguide.
    Does anyone know where I can get the Ruyoet camera? Or any other camera+bracket that works with the ABC and pro grille?
    And can anyone confirm the Nakita camera that comes with the ABC is the same one Damguide designed a bracket for? There was a link to Amazon, so it's hard to tell if it was the same camera from ABC.
  6. Nov 4, 2024 at 5:38 PM
    #146
    DamGuide
    DamGuide Well-Known Member
    Nooga, TN
    2020 TRD Offroad
  7. Nov 5, 2024 at 10:39 AM
    #147
    LeFreakyBone
    LeFreakyBone Well-Known Member
    Santa Cruz
    2021 Off-Road Midnight Black Metallic
    Leopard print steering wheel cover
    I’d love to purchase one of the mounts you print if you sell them!
    Currently, the camera I have is held in place with silicone in the pro grille. It’s been fine enough, but slightly off center.
  8. Nov 5, 2024 at 11:45 AM
    #148
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    Hello there!
    What kind of connection is needed to make the front camera work?
    I have a Joying head unit so no oem connection, but if I understand type of connection, I may be able to make it work.
    Thanks
  9. Nov 5, 2024 at 2:17 PM
    #149
    DamGuide
    Nooga, TN
    2020 TRD Offroad
    send me a dm
