Aftermarket Headlights HELP!
Discussion in '1st Gen. Tacomas (1995-2004)' started by g.potentlifestyle, Aug 18, 2014.
  1. Aug 18, 2014 at 4:15 PM
    g.potentlifestyle
    g.potentlifestyle [OP] 04 Prerunner TRD SR5
    Grant
    Chicago
    Hello :),
    I recently purchased some aftermarket headlights " . Longstory short they are leaking water from the top. I've gone through two sets. I really need some help finding some headlights with a good seal , preferably smoked ( have a blacked out 2004 Prerunner TRD) . Also I can not put back in the factory headlights because i have an aftermarket grill that doesn't have the splitter part for the headlights & turning signal ligghts. Thank you!
  2. Aug 18, 2014 at 6:23 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    Throw them in the oven and pull the lenses off. Then when reattaching run a bead of Butyl sealant around the edges. They won't leak again and the sealant is fairly cheap. Just follow the write-ups for installing some hid projectors. They have the correct times/temps for pulling the lenses off. It's pretty easy.
  3. Aug 18, 2014 at 6:25 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC King Ranch Edition
    I'll take the old ones
  4. Aug 18, 2014 at 8:44 PM
    g.potentlifestyle
    Grant
    Chicago
    TashcomerTexas - they are all beat up , i removed them and tried to smoke them out as well as paint the trim back, things didnt go to well.
    Snowman- Thank you for the tips, will let you know how this goes this week! Thanks again.
