aftermarket keyless entry wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dewey7015, Apr 17, 2011.
  1. Apr 17, 2011 at 5:32 PM
    Dewey7015
    Dewey7015 [OP] Well-Known Member
    Massachusetts, USA
    2018 TRD sport
    Ok,
    good news...bought a simple keyless entry system off fleabay for, .99
    yes, 99 cents..
    My problem it seems that no one on this site has installed one of these.
    I need to know how to locate + and - door lock wires, and parking light wire, near the fusebox.
    any help ??
    thanks
    Dewey
  2. Apr 17, 2011 at 6:13 PM
    Erll
    Erll Well-Known Member
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
  3. Apr 18, 2011 at 3:14 AM
    Dewey7015
    Massachusetts, USA
    2018 TRD sport
    Directions came with the unit.. The issue is locating wires on my truck. Thanks.
  4. Apr 18, 2011 at 8:11 AM
    Dewey7015
    Massachusetts, USA
    2018 TRD sport
    14 even..
    Promise to post pics if someone steps up with some info...cmon guys, can't go wrong for $15 keyless entry for a 2nd gen..
  5. Apr 18, 2011 at 8:20 AM
    Erll
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    i verified these against my truck with the astrostart keyless that I had installed. They look correct
    Battery Constant 12v+ Positive Wire (+): White/Blue And White/Red
    Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
    Starter Positive Wire (+): Green/Black (This vehicle uses (2) starter/crank wires, when connecting to a remote starter you must connect both starter/crank wires to the starter/crank wire from the remote starter.)
    Starter Positive Wire Location: Ignition Switch Harness
    Second Starter Positive Wire (+): Black/White (This vehicle uses (2) starter/crank wires, when connecting to a remote starter you must connect both starter/crank wires to the starter/crank wire from the remote starter.)
    Second Starter Positive Wire Location: Ignition Switch Harness
    Ignition Positive Wire (+): Black/Red
    Ignition Positive Wire Location: Ignition Switch Harness
    Second Ignition Positive Wire (+): Blue/Yellow
    Second Ignition Positive Wire Location: Ignition Switch Harness
    Accessory Positive Wire (+): White/Green
    Accessory Positive Wire Location: Ignition Switch Harness
    Key Sense Negative Wire (-): Green/Black
    Key Sense Negative Wire Location: Ignition Switch Harness
    Parking Light Negative Wire (-): Green
    Parking Light Negative Wire Location: At Headlight Switch Or Bceu, Pin 13. The BECU (body electronic control unit) is attached to the back of the fuse box, with a single 26-pin plug.
    Parking Light Positive Wire (+): Green
    Parking Light Positive Wire Location: At Fuse Box 13-Pin Plug, Pin 10
    Power Door Lock Negative Wire (-): Purple (When testing the door lock and unlock wires, you must test these wires when turning the key in the drivers door key cylinder only.)
    Power Door Lock Negative Wire Location: In Drivers Kick Panel, 10-Pin Plug, Pin 4
    Power Door Unlock Negative Wire (-): Green/Black (Requires Double Pulse)
    Power Door Unlock Negative Wire Location: In Drivers Kick Panel, 10-Pin Plug, Pin 8
    Door Trigger Negative Wire (-): The drivers door is a green/yellow (-) in the 18-pin plug, pin 7, the passenger door is a red/black (-) in a 22-pin plug, pin 8, the rear doors are a pink/black (-) in an 18-pin plug pin 6, when connecting to an alarm system, use all (3) door trigger wires and diode isolate
    Door Trigger Negative Wire Location: At Fuse Box
    Domelight Supervision Wire (-): Blue (Requires Relay)
    Domelight Supervision Wire Location: At Fuse Box, Black 13-Pin Plug, Pin 9
    Trunk Release Negative Wire (-): N/A
    Trunk Release Negative Wire Location: N/A
    Horn Negative Wire (-): Green/Red
    Horn Negative Wire Location: At Fuse Box, 18-Pin Plug, Pin 10
    Tachometer Wire Negative Wire (-): Black/White
    Tachometer Wire Negative Wire Location: At Data Link Connector, Pin 9. The data link connector is located under the driver side of the dash.
    Brake Light Positive Wire (+): Blue
    Brake Light Positive Wire Location: At Fuse Box, 11-Pin Plug, Pin 2
    Factory Alarm Disarm Wire (-): Disarms With Key Sense Wire. The key sense wire will disarm the vehicle without unlocking the doors by applying a (-)negative to this wire during remote starting.
    Factory Alarm Disarm Wire Location: At Ignition Switch Harness
    Factory Anti-Theft System: Transponder Anti-Theft System, Requires Bypass Module And Extra Ignition Key. The transponder anti-theft system is standard on all v-6 models.
    Factory Anti-Theft System Location: Transponder At Ignition Switch Tumbler
  6. Apr 18, 2011 at 10:16 AM
    Dewey7015
    Massachusetts, USA
    2018 TRD sport
    Now that's what I'm talking about.. Just goes to show, this place is great!! Thanks.
  7. Apr 18, 2011 at 10:22 AM
    jrdbrn
    jrdbrn Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    *Waits for Dewey to report in his truck caught fire while on the interstate.
  8. Apr 18, 2011 at 11:03 AM
    Erll
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    how do you make a taco sound like a dog....?
    add a .99 keyless entry and press the button ......... Woof (up in smoke)
  9. Apr 20, 2011 at 6:07 AM
    Dewey7015
    Massachusetts, USA
    2018 TRD sport
    Thanks for the info guys, unfortunately the wiring is different.. there is no 26 pin on the back of the fusebox. wires are different. anyone been able to find actual wiring diagrams of a 2009? anyone splurged for the manual? You think Haynes would have the info?
  10. Apr 20, 2011 at 6:11 AM
    Erll
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    I think the 26 pin plug is under the engine compartment fuse box.
  11. Apr 21, 2011 at 3:29 AM
    Dewey7015
    Massachusetts, USA
    2018 TRD sport
    nope, BCEU should be behind the fusebox in the cab, behind the tray. Plug should be in the bottom right as you look at the fusebox...or so the paper says..
  12. Dec 27, 2017 at 9:19 AM
    huj2000
    huj2000 Well-Known Member
    dan
    Burbank, il
    2010 Tacoma Offroad 4.0 V6
    Supercharger
    can anyone help me out im trying to find the 10 pin connector that has the lock/arm and unlock/disarm wires i already know what color the wires i need are but im having trouble finding the connector i know its supposed to be in the driver kick panel but thats about as much as i know can someone help out please
  13. Nov 6, 2023 at 10:40 PM
    Mpstickers
    Mpstickers Well-Known Member
    THIS is awesome, wow. I’m having trouble with the wiring as I'm installing an aftermarket RFID push button start in my 2000 Taco, V6, 4x4, Automatic transmission. I’m not doing apple juice l I’mremote start or door locks or anything like that. I thought I’d wired it up properly, it’s pretty straight forward. However, when I try to start the truck with the push button installed it just cranks and cranks, no start. Take it out, and put it back to stock configuration, it starts right up. It’s as if there a wire not connected or something that I missed. Any way you could share a list like the me you did here only for a 2000 Taco? And again i wouldn’t need all the lighting and door lock stuff. Just the ignition stuff. The way you listed it makes a lot more sense than any of the other stuff I’ve found.
