aftermarket LCA bushings
Discussion in 'Suspension' started by surfrat, Jan 2, 2012.
  1. Jan 2, 2012 at 6:20 PM
    surfrat
    surfrat [OP] Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    Im getting a clunk from my LCA bushings. They need to be replaced. The only aftermarket ones i can find are for 2wd. Anyone have any sources for these?
  2. Jan 2, 2012 at 6:21 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
  3. Jan 2, 2012 at 6:25 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Energy Suspension
    DayStar
    Prothane
    Are the brands you should be looking at.
    Or OEM.
  4. Jan 2, 2012 at 6:27 PM
    GTACO
    GTACO GTACO
    Gabriel
    Murrieta, CA
    07 PreRunner
    Camburg Spindles, Total Chaos UCAs & LCAs, Fox 2.5 c/o front, Fox 2.0 rear, All Pro 3" leafs, Dumped Borla muffler, AFE intake, DTF front bumper, Demello rear bumper.
  5. Jan 2, 2012 at 6:35 PM
    surfrat
    LI, NY
    you dont think what matters?
    from my research theres no poly bushings for OEM LCA for 2nd gens
  6. Jan 2, 2012 at 6:43 PM
    surfrat
    LI, NY
    pretty sure theres a difference between them.
    I hear you on the poly bushings.. trying to stay away from them as well.
  7. Jan 2, 2012 at 6:44 PM
    jflan
    Vancouver, WA
    Yeah, if you're going to use them you should be able to grease them with the correct grease that won't eat them. They will squeak otherwise.
    I've used Lubriplate food grade grease on Energy Suspension bushings instead buying the spendy sh!t in the little tubes.
  8. Jan 2, 2012 at 6:47 PM
    th3bigk0
    th3bigk0 GETTN IT
    Dylan
    Lamecaster
    13 TRD Double Cab
    Fox 2.5 RR C/O's,Camburg UCA,Camburg Spindles,KING 2.5,OME Dakar Leafs,285 KM2,XD HOSS 16'',BHLM,HID's,CB,Hornblasters Shocker 540 train horn,KICKER 12 ported....
    where are you finding the 2wd?
  9. Jan 2, 2012 at 7:03 PM
    surfrat
    LI, NY
    just search tacoma lower control arm bushing on ebay.. you will find them.
  10. Jan 2, 2012 at 7:04 PM
    surfrat
    LI, NY
    Seems the 2wd and 4WD are actually the SAME part numbers...
    Gonna try the ebay ones.
  11. Jan 2, 2012 at 7:39 PM
    surfrat
    LI, NY
  12. Feb 1, 2012 at 7:59 AM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Any update on these bushings? Has anyone bought them?
  13. Feb 1, 2012 at 5:50 PM
    surfrat
    LI, NY
    i never got them. My bushing werent to blame for the clunk.. but the price is right. that for sure
  14. Feb 1, 2012 at 6:18 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    What was your clunk from? Also, I think it was you, but in another thread i think you posted that you were having alignment problems with your camber not being in spec? I have the same problem and I'm having a hard time tracking down the problem. What did you do about it?
  15. Feb 1, 2012 at 7:49 PM
    surfrat
    LI, NY
    i never had any issues with alignment. i searched the forum and found clunks where usually from LCA bushings.. turned out my coilovers where just low on nitrogen
