Aftermarket LED headlight replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ViceCityCane, Feb 6, 2017.
  1. Feb 6, 2017 at 8:27 AM
    ViceCityCane
    ViceCityCane [OP] New Member
    Jay
    2014 Silver Toyota Tacoma TRD Sport
    Good morning. I recently purchased a 2014 Tacoma TRD Sport and would like to replace the headlights/foglights with LED's. Is there a specific aftermarket brand I should be looking for or any I should avoid for that matter? I found a pair from ANZO that looked really nice but wasn't sure about the brand. Thank you in advance.
  2. Feb 6, 2017 at 8:36 AM
    Tylandus
    Tylandus Well-Known Member
    Midwest
    2019 4Runner SR5 Premium Superwhite
    read the stickies first.
  3. Feb 6, 2017 at 8:40 AM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    You could also retrofit your oem headlights ?
    Or.....depo brand.
  4. Feb 6, 2017 at 8:41 AM
    ChemDawg
    Maine
    2005 sr5 4x4
    Definitely good to research... then ask questions vs other way around :rofl:
  5. Feb 6, 2017 at 11:17 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome to TW! Philips LEDs are the only ones I am aware of that work with the OEM halogen reflector headlights. See this thread:
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-vs-philips-led-headlights.460313/
    You cannot run just any LEDs in a halogen reflector, and no LEDs will be a safe drop in replacement for the fogs, read why here:
    https://www.tacomaworld.com/threads/why-leds-should-not-be-run-in-halogen-reflectors.454371/
    If you want to replace your OEM fogs with LEDs then you need to do complete replacement LED housings, like these:
    https://www.theretrofitsource.com/complete-housings/fog-lights/toyota-oval-morimoto-xb-led.html
  6. Feb 7, 2017 at 3:13 PM
    ViceCityCane
    Jay
    Thanks for the info. Ill check out the stickies too (whatever those are). Appreciate the info.
  7. Feb 7, 2017 at 4:23 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If you go to the lighting forum, they are the threads that are at the very top of the page in their own section.
