aftermarket light bulbs
Discussion in 'Lighting' started by RDAY, Jan 20, 2009.
  1. Jan 20, 2009 at 12:31 PM
    RDAY
    RDAY [OP] Well-Known Member
    NY
    07 Tacoma SR5 4x4
    r there any aftermarket bulbs out there that are better than stock, silverstar ultra? PIAA?
  2. Jan 20, 2009 at 12:42 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    Phillips X-treme power bulbs get good reviews
  3. Jan 20, 2009 at 10:14 PM
    G-Sak
    G-Sak Well-Known Member
    PNW
    2005 TRD Offroad SR5 DC 6 speed
    FX-R Projector Retrofit with Apollo Shrouds, Digital HID 55 watt ballasts, D2S Philips 85122+ bulbs in the Winter and Digital HID 55w 5k bulbs in the summer, Bakflip G2, Pop N Lock, Tint, Grillcraft with PIAAs behind it, ScanguageII and a few audio/video upgrades.
    The PIAA Intense White bulbs are pretty good. I ran them for a while and they put out a much whiter light than the stock bulbs. If you like a slightly blue color then the PIAA Xtreme White bulbs would do the trick.
    As for the silverstar ultras, I have not used them on any of my vehicles, but I did install some on my girlfriend's car this past weekend and they are better than the stock ones were. The difference was not anything to brag about though.
    I would consider looking into the Phillips X-treme power bulbs like Delmarva suggested above. I have heard good things about them as well. They claim they put out up to 80% more light than standard halogen bulbs. That is quite the claim if you ask me!
  4. Jan 20, 2009 at 10:19 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have the Silverstar Ultra's for my headlights and they aren't bad at all. Much brighter then the stock bulbs. But if your going for the HID look, these aren't the ones you want. I used to have just the Silverstar's and not the ultra's for the fogs and they worked good as well, also brighter then the stock fogs. But now I have some other bulbs in the fogs.
  5. Jan 20, 2009 at 10:23 PM
    G-Sak
    PNW
    Which bulbs for the fogs have you had the best results with if you don't mind me asking? I'm looking to upgrade in the future.
  6. Jan 20, 2009 at 10:28 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Well I really liked the Sylvania Silverstar's! Only reason I swapped those out were for some yellow bulbs instead.;)
  7. Jan 21, 2009 at 4:50 AM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    x2... I run Superstarts in my headlights and Nokya Hyper Yellows in my fogs.
  8. Jan 21, 2009 at 7:49 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I was using the silverstars for a little while, much better than stock but not even close to my HID's :D
  9. Jan 21, 2009 at 8:22 AM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    I just changed mine last night to the Silverstar Ultra's for the headlights and the fogs. Schucks Auto has them with a $10 instand rebate and a $10 mail in rebate right now so I was happy to buy them. I also replaced my wifes car's headlights with the same. Comparing the new builbs to the stock ones the stock ones almost had a yellow look to them compared to the Silverstar Ultra's. So far I am happy, I just hope they last a while. Also since Schucks auto is also Checker, Kragen, or Murray's dpending on where you live it may be worth while to look at these.
  10. Jan 21, 2009 at 9:17 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah they are good lights! Just not the ones for you if you want that HID look.;)
  11. Jan 21, 2009 at 5:10 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    what are the part numbers for are trucks? I want to check them out online to see what there is so what would u choose if I were to decide between PIAA and the phillips?
  12. Jan 21, 2009 at 5:17 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    Personally, I wouldn't get either, unless you want to have to replace your bulbs every 4-6 months.
  13. Jan 21, 2009 at 5:32 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    we have a one low beam bulb and one high beam bulb right? it doesnt switch on the same bulb on our truck does it?
  14. Jan 21, 2009 at 5:49 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    cause i am looking to order some from www. powerbulbs.com but it says there can't be any high beam bulbs found but theres tons on low beam bulbs.
  15. Jan 21, 2009 at 6:29 PM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    Hi and Lo beams are the same bulb. Headlights are H4 and Foglights are H10
  16. Jan 22, 2009 at 6:19 AM
    RDAY
    NY
    07 Tacoma SR5 4x4
    thanks
  17. Jan 22, 2009 at 6:53 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    i have the piaa intense white bulbs and one bulb went out on me after a year but was replaced under warranty the piaa's are a solid bulb and i reccomend them. Sorry you had a bad experience
  18. Jan 26, 2009 at 4:33 PM
    stephbm6
    stephbm6 Well-Known Member
    West Jordan, Utah
    2006 TRD Double Cab
    Can you buy blue turn signal light bulbs?
