Aftermarket locker?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Motorkopf, Nov 16, 2007.
  1. Nov 16, 2007 at 11:41 AM
    Motorkopf
    Motorkopf [OP] Conservative
    Victorville, CA
    05 PreRunner SR5 2.7 Manual
    3" Toytec lift, Susp TSB, Detroit True Trac, Carr side steps.
    Has anyone found an aftermarket locker or LSD that will work with a PreRunner 2.7 rear diff?
  2. Nov 16, 2007 at 5:53 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    have'nt looked but you might want to try Powertrax
  3. Nov 16, 2007 at 6:19 PM
    wormhole7
    wormhole7 Well-Known Member
    Lake Dallas, Tx
    TSS
    Leather, Suspension TSB, Billy 5100's up front set at .85, Eaton Posi LSD,Grillcraft Black Mesh Grills,Aires Bull Bar,Black Low Profile Narrow Toybox,Black Headlight Mod,Black Tail lights ,USA Spec,Ipod, PopnLock,Bed Mat,Bug Sheild,Vent Visors, Weathertec Liners,Radar,Nuvi 760,Dog Ramp,Convex Mirrors, Roof Rack, Tint, Borla exhaust, Borla Intake, OBX pedals, Home Link Auto Dimming Mirror with remote, 20" Factory Wheels, Factory Tube Steps
    Something like this perhaps?
    http://www.drivetrain.com/TRD.html
  4. Nov 17, 2007 at 11:01 AM
    JJK
    JJK Active Member
    08 SR5 DC
    TrueTrac Limited Slip
    I replace the open diff in my 08 4x4 sr5 dc with a Detroit TrueTrac.
    I had a similar diff in my 05 Ranger (Torsen) and it was a great truck in the snow and off-road. The Truetrac should fit your 05 I would think.
    It grabs fast and hard. I can't wait to take it off-road or out in the snow.
    I wanted to stay away from a full locker and stick with LSD as I'm on dry pavment 99% of the time.
    Good Luck
    JJK
  5. Nov 17, 2007 at 12:29 PM
    Motorkopf
    Victorville, CA
    Thanks all, but none of those offer anything for the 4 cyl drive train. Not sure about the Trutrac though- I'll give them a call and see.
    I'm hoping I won't have to replace the entire rear end to get an LSD!
  6. Apr 24, 2008 at 2:30 PM
    Motorkopf
    Victorville, CA
    Got a True Trac installed last week. I'm very impressed- thanks for the heads up JJK. I used to spin a wheel all the time at a stop sign on a certain stretch of road which always has gravel on the road. Now I'll put my right wheels off the road completely onto the gravel, and I can't tell I'm even off the road if I take off quickly from a stop. Works great.
  7. Apr 24, 2008 at 4:06 PM
    zmtnbik
    zmtnbik FMLYHM
    4x4 Trd Off-road
    Donahoe (Icon) C/O, TC UCA's, Dakar leafs, BilStein 5125's, 285/70/17 BFG MT KM2's, Raceline Renegade 17x9's, u-bolt flip kit, debadged, TRD CAI, TRD exhaust, URD MAF controller, 20% front window tint, 3M clear bra on bumper, cam locks in all storage compartments, fog light mod, Alpine X100 deck, Co
    I was going to suggest a Lincoln locker, but sounds like you already picked on up. :D
  8. Apr 24, 2008 at 4:22 PM
    concrete jedi
    Rochester N.Y
    If you don't mind, what did that run ?
  9. Apr 26, 2008 at 12:30 PM
    AK Backcountry
    AK Backcountry Well-Known Member
    Eagle River AK
    08 TRD Off-Road
    Snugtop, Scangauge II, iPod Adaptor, Redline Hood Struts, Removed Secondary Air Filter, De-badged, AFE Drop In, Westin Oval Steps Future: Locker Anytime
    +1 on the cost and how hard was the install?
    I have been thinking about converting the locker in my 08 Off-Road to a Detroit True Trac, depending on the cost. My wife's car (all wheel drive) does better in the snow than the Tacoma until I get the Tacoma in 4 wheel and at times also have to engage the locker. My 97 F-150 with a LSD was better in 2 wheel drive. Tires are a factor, but was hoping it would be better. I also don't like the way the open differential spins one tire on even the slightest amount of gravel or wet pavement.
    Planning on the "Locker Anytime Mod" but may just change out the entire rear differential.
  10. Apr 28, 2008 at 8:13 AM
    Motorkopf
    Victorville, CA
    I got the Detroit for about 450 from Drivetrain Specialists. I found a local truck place that would install for 350 (labor), and you'll probably need to replace the bearings also (as I did) which are about $100 for the set. Amsoil severe gear was about $40. You'll need just under 3 quarts. I ended up having the dealer install though, for twice the amount (700) because I trust my dealership- they've been very reliable and honest with me, and because I didn't want to take it on myself. So really, if you did it yourself and you probably could, you could probably do the whole thing for around $600. For me it was about $1300 having a dealer do it. Consider for the same cost, you could get an ARB locker, but I didn't want a locker- I wanted a good LSD. And I don't think you'll find a better one that the Detroit.
