Aftermarket Trans Cooler
Discussion in '1st Gen. Tacomas (1995-2004)' started by jgill21, Nov 7, 2018.
  1. Nov 7, 2018 at 1:02 PM
    jgill21
    jgill21 [OP] Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    I'm about to tow a pretty light load for the first time since my transmission swap. Even though its roughly 700lbs or so, I still want to run an aftermarket cooler to try to keep those temps as low as possible. Anyone got one they would recommend?
  2. Nov 7, 2018 at 1:55 PM
    02hilux
    Planet: EARTH
    How often do you plan to tow? 700lbs is not much for a tacoma and you shouldn't need to add a transcooler.
    jgill21[OP] likes this.
  3. Nov 7, 2018 at 5:56 PM
    stinger86
    stinger86 Well-Known Member
    San Diego, CA
    2016 Double Cab Limited
    While I agree, an inline transmission cooler doesn’t have many downsides though.
    jgill21[OP] and The Driver like this.
  4. Nov 7, 2018 at 6:23 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Good for heavy towing and off roading.
    ectrd, jgill21[OP] and The Driver like this.
  5. Nov 7, 2018 at 7:57 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
  6. Nov 7, 2018 at 8:21 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Go with the biggest B&M plate cooler you can fit that offers the highest GVWR or BTU ratings !!!
    Not on my truck but on my Camaro , I'm running a B&M # 70274 plate cooler and with a 4500 stall converter it keeps the trans temp at a safe level even on a 110° day here in the High Desert
    Ngneer and jgill21[OP] like this.
  7. Nov 7, 2018 at 11:40 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    So do they not come with a cooler from the factory or is it just less than stellar performance wise?
  8. Nov 8, 2018 at 6:06 AM
    jgill21
    Jake
    Nashville
    There have been times where I've towed about as much as the truck weighs, if not more. Its not too often, but it just seems like the trans tunnel gets too warm for comfort anytime I hook up to a trailer.
  9. Nov 8, 2018 at 7:50 AM
    Glamisman
    Glamisman Well-Known Member
    the stock cooler in the radiators have been know to have problems, rare but it does happen.
  10. Nov 8, 2018 at 12:33 PM
    ectrd
    ectrd Well-Known Member
    '04DC
    4 tires, a steering wheel & a seat
    This is a good choice...
    I would advise anyone with the A340F (or E series) automatic to go aftermarket trans cooler , these trannys do not do well with heat
