AGM BATTERY CHARGING - ALTERNATOR VOLTAGE BOOSTER
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05Taco4x4, May 24, 2019.
  1. May 4, 2020 at 2:22 PM
    #141
    John90XJ
    John90XJ Well-Known Member
    2006 Tacoma Access TRD OR
    Save yourself the grief and just replace it now if you already have the AGM. I ran mine for nearly eight months before I did anything with the charging voltage piece. I didn't even know and I've been running AGMs for years.
  2. May 4, 2020 at 4:32 PM
    #142
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Man that's slick :thumbsup:
    Muddinfun[QUOTED] likes this.
  3. May 5, 2020 at 6:18 AM
    #143
    05Taco4x4
    2TR-FE Enthusiast
    Adding these to the OP
  4. May 6, 2020 at 7:33 AM
    #144
    05Taco4x4
    2TR-FE Enthusiast
    Hey guys, I had to pull this from my truck
    Some sensors and maps in the ECM are calibrated to voltage, this will throw off maps in your tune! Injector Dead Time, Ignition Dwell Time and anything else calibrated to voltage- ultimately affecting your fuel metering (mpg, among other things). Boosted guys are really affected by this. I tuned my COPs to .2v below saturation, this had me running them in saturation ever since this mod :mad:
    Edit:
    Warning added to OP
    The circuit does not include the ECM, the ECM reads the actual voltage.
    stickyTaco likes this.
  5. May 6, 2020 at 7:52 AM
    #145
    6 gearT444E
    Deep South
    Herculiner Hootus
    Dang, I guess we can't have our cake and eat it too
  6. May 6, 2020 at 7:59 AM
    #146
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    Well, you can, you just can't be running an aggressive tune to compensate for more aggressive modifications.
  7. May 6, 2020 at 8:07 AM
    #147
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    what about stock N/A trucks?
  8. May 6, 2020 at 8:20 AM
    #148
    05Taco4x4
    2TR-FE Enthusiast
    It throws everyone’s computers off.
    Edit:
  9. May 6, 2020 at 8:26 AM
    #149
    elricfate
    It does but there's enough flexibility in a non-flashed ECU that it should more than adjust for it. When you're running aggressive tunes, you're getting into a very narrow set of criteria you need to hit for maximum potential.
  10. May 6, 2020 at 8:37 AM
    #150
    Muddinfun
    Muddinfun Well-Known Member
    What if you put another diode into the power for the ECM to drop the voltage back down?
    Edit: Don’t know if the diode will handle the load of the ECM.
  11. May 6, 2020 at 9:55 AM
    #151
    6 gearT444E
    Deep South
    Herculiner Hootus
    It's a 20 amp (EFI) and 15 amp (IGN) fuses, I'm sure it's possible to get that in a diode rating.
  12. May 6, 2020 at 2:27 PM
    #152
    05Taco4x4
    2TR-FE Enthusiast
    I don't think you guys are getting what I'm saying.
    The ECM sees the spoofed voltage, EVERYTHING is operating on the actual higher voltage.
    At a given load, let's say the ECM tells the injectors to open for 2.5ms at 13.8v and 2.3ms at 14.2v (injector dead time is smaller as voltage increases) and the ECM sees 13.8 but the injector has 14.2 volts at it, the ECM will tell the injector to open for 2.5ms but should be 2.3ms- you just lost fuel economy. The same can be said about every sensor and electrical metering thingy throughout the vehicle. Not true, I forgot about 5v sensors, but all electrical components supplied power by the alternator.
    Edit:
  13. May 6, 2020 at 4:15 PM
    #153
    6 gearT444E
    Deep South
    Herculiner Hootus
    So the ECM is not smart enough to compensate for it if it also sees 14.2 volts? I guess I don't understand why it would be an issue and how much is affected. I'd think most of those sensors are design to operate over a wide range that the vehicle would be capable of producing.
  14. May 6, 2020 at 4:25 PM
    #154
    John90XJ
    Seems like I would need to hold my foot off the throttle about 9%.
  15. May 6, 2020 at 4:27 PM
    #155
    6 gearT444E
    Deep South
    Herculiner Hootus
    Never!
  16. May 8, 2020 at 5:38 AM
    #156
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    I'm not saying you're wrong by any means and i understand what you are saying about the dwell times on injectors and other sensors. But I have had HPTuners for a while and did the Ford diode after the tune. I noticed no MPG difference before or after the diode or any other oddities. I think we would need to see someone with HPTuners should do a datalog before and after the diode change to see if these findings are accurate.
    I agree with others that the ECM (stock or HPT) would correct for the voltage increase. Specifically regarding air/fuel ratios.
  17. May 8, 2020 at 6:50 AM
    #157
    05Taco4x4
    2TR-FE Enthusiast
    It’s outputs are based on what it senses, absolutely in agreement.
    Maybe @JustDSM can comment
    JustDSM likes this.
  18. May 8, 2020 at 2:49 PM
    #158
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    The stock ECU has voltage compensation tables which will account for voltage swings. All of the 5volt sensors are on a regulated power supply from the ECU which would be unaffected and still report consistently independent of the battery/charging voltage.
  19. May 8, 2020 at 5:24 PM
    #159
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    When you think about it this has to be the case, or else a dying battery would potentially crater an engine even on a stock tune.
    TegoTaco and JustDSM like this.
  20. May 8, 2020 at 5:49 PM
    #160
    05Taco4x4
    2TR-FE Enthusiast
    True but doesn't apply to the COPs or fuel injectors, my main concern being accurate fuel metering and not burning up COPs.
