AGM battery help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by .jake, Dec 7, 2020.
  1. Dec 7, 2020 at 3:42 PM
    .jake
    .jake [OP] Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    OK so my stocker battery is near death. I just know it. Weather is cooling and it's unhappy. So I'm in the market before I get hosed. I need somebody to break down the AGM challenges like I'm 5. Seriously. I read about charging particulars... this and that... now I'm confused. Something about the alt not keeping up with the battery needs. FWIW I have the tow pkg if that helps sort it out.
    So help a brother out... please? Thanks.
  2. Dec 7, 2020 at 3:44 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Get an AGM
    Install it
    Hook a charger up to it once a month if you really want.
    SpeySquatch, E.J., b3itz and 2 others like this.
  3. Dec 7, 2020 at 3:44 PM
    Shellshock
    Iowa
    You can just stick it in and run it. People freak out about it not getting 100% charge but it’s not nearly as big a deal as people make it out to be. It might just last a couple months less. You can top it off from time to time with a wall charger if desired but not required.
    if you want, you can get vf tuner and adjust the charging voltage to give it a bit more juice.
  4. Dec 7, 2020 at 3:46 PM
    ClintS
    ClintS Well-Known Member
    San Diego
    2019 Tacoma TRD Off Road
  5. Dec 7, 2020 at 3:50 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    A cheap Wally World battery for the win. Edit: and a large pizza and wings
    Sharpish, Taco_Coma, BillsSR5 and 2 others like this.
  6. Dec 7, 2020 at 3:57 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    First off, there are two makers of low cost AGM batteries. Johnson controls and Penn Deka. The JC are in most stores as their house brand. They range from $150. to $230. I like the Walmart brand because they cost $140.~$150.
    I think the DEKA brand is better. RockAuto has the DECA for $190. + shipping.
    I got an AGM battery a week after I bought my 2020 SR. The truck charges the battery just fine. Been in over a year and still reads over 13 volts 20 minutes after the engine is shut down. 12.8 volts is 100% charged.
    Steves104x4 likes this.
  7. Dec 7, 2020 at 4:02 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Why not just get lead acid?
  8. Dec 7, 2020 at 4:05 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Sometimes older technology is more than adequate. The latest & greatest almost always involves more $$$. KISS.
  9. Dec 7, 2020 at 4:05 PM
    .jake
    I saw the NAPA are Penn batteries too. Was looking at one for ~$190.
    Sure, I know. But I had questions about something and wanted to tap the TW brains instead of just guessing. Kind of thrust into the market.
  10. Dec 7, 2020 at 4:09 PM
    JoeCOVA
    Joe
    Colorado Springs
    I see, the simple answer is the ECU controls the charging which supplies enough voltage to charge lead acid batteries. It's not enough for an AGM so your AGM will usually only ever sit at 80% capacity. You can buy mods or a RedArc controller that will allow you to fully charge it.
    Unless you really really need it you can buy a nice lead acid battery and be fine.
    I'm running on the OEM battery with winches, lights, compressor and an ARB Fridge, no issues.
    vorkuta775 likes this.
  11. Dec 7, 2020 at 4:13 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    $80 for a 2 year a Walters
  12. Dec 7, 2020 at 5:08 PM
    .jake
    Thanks. Im pretty sure it’s the AZ heat that kills my batteries. All my cars seem to eat them up. Does an AGM handle heat any differently than std batts?
  13. Dec 7, 2020 at 5:35 PM
    SRBenjamin
    Benny
    This is complete BS! Just another keyboard scholar at work.
  14. Dec 7, 2020 at 5:39 PM
    .jake
    Help me understand please
  15. Dec 7, 2020 at 5:43 PM
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    You have some enlightening info to back that statement up?
  16. Dec 7, 2020 at 5:43 PM
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    Can you fit a DEKA group 27 into a Taco if you replace the wires? They don't make a 27F.
  17. Dec 7, 2020 at 5:44 PM
    JoeCOVA
    Joe
    Colorado Springs
    Nothing else to contribute?
    You may want to double check your claim of only two manufacturers of low cost AGM batteries before calling others out.
    t0nyvalenzuela and vorkuta775 like this.
  18. Dec 7, 2020 at 5:48 PM
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    This guy is bullshitting. There is definitely a need for more service charge voltage so you need to change the voltage being supplied by the alternator by editing the ECU values.
    Theres a whole vfTuner thread dedicated to AGM tuning...
    Some people on here...
    Go troll elsewhere...almost a shame you own a Tacoma.
    antlab67 likes this.
  19. Dec 7, 2020 at 5:49 PM
    E.J.
    Josh
    NWA
    Our alternators top out at 13.9 volts, and AGM battery likes to see around 14.4.
    GladiatorNOT likes this.
  20. Dec 7, 2020 at 5:49 PM
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
