AGM Battery
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BMH, Mar 31, 2024.
  1. Mar 31, 2024 at 10:51 AM
    BMH
    BMH [OP] Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    Anyway, truck battery (original) coming up on 4 years old. Still works fine, but being as I live somewhere where it can get in the 90's during summer and -10 in winter, it runs the gambit.
    But, I always try to head trouble off at the pass, have been thinking of getting a new batt for peace of mind.
    Am considering an AGM batt.
    Saw a YouTube video yesterday of... Let's say a questionable source.... (Not 'Care Car Nut' or anything that you can take as gospel) and they claimed that a AGM batt needs to have the voltage bumped up a bit by reprogramming the ECU. Otherwise the batt will never get a full recharging while driving. I'm assuming the reprogramming bumps up the voltage regulator output. So being as I've never ever heard this before....
    A: Is this really a thing?
    B: Or is the person who made the video full of shit?
    C: If this really is a thing, has anyone ever done the reprogramming?
    D: Has anyone replaced their batt with an AGM, never touched anything, and never had any issues?
    What say ye?
  2. Mar 31, 2024 at 10:59 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    It's really a thing.
    And they are heavier.
    And they cost more.
    And at the end of the day you probably won't 'save' by buying it, it will need replacing as well.
    I buy a new battery every 2 years for all my cars.
    NeverStart ( i mean EverStart )....
    90 degrees and -10 isn't that harsh, but I would certainly replace it now rather than risk
    needing a jump in the middle of nowhere.
    We saw temps of 110+ for 30 days straight last year, some days reaching 115-118.
    I've seen the airport shut down because temps busted 120.
    The prior 30 days was 100+ as were the following 30 days.
    Wipers melted onto the windshield. Lethal temps.
    Canadian Caber likes this.
  3. Mar 31, 2024 at 11:01 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    It’s true. A tune will adjust the charging voltage for an AGM battery.
    The stock charging voltage will keep the agm battery at 80%~ and people run them like this fine from what I read. Some people also just give them a full charge from a battery tender (designed for AGM batteries) like once a month.
    I think they also sell voltage boosters you can put inline in the charging system somewhere but not too familiar with that.
  4. Mar 31, 2024 at 11:06 AM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Apparently if you get an aftermarket tune you can have the voltage bumped up to cover the AGM battery's needs.
    joba27n likes this.
  5. Mar 31, 2024 at 11:11 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I don’t see the upside. I can replace a regular battery more often, save money, and still have more reliability since I’m replacing every 36-40 months.
  6. Mar 31, 2024 at 11:50 AM
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC, 2018 4R Limited, 2006 Jeep TJ
    I have a dual battery setup with two AGMs, due to having a fridge. I did a test to see the power usage by the fridge on the auxiliary battery, on a sunny, September day, including while in my garage over a weekend. I first hooked up the batteries to a CTEK charger, having them at 13.1v, then checked them at different times. Readings are here, and you'll note the state of charge of the starter battery, which twice, read 12.97v and 12.91v after driving.
    Off-Grid Engineering Dual Battery System Q&A
    (FYI, with the dual battery system, when the engine is running, both batteries are connected. When the engine is off, batteries are disconnected.)
  7. Mar 31, 2024 at 1:13 PM
    chetterthecat
    chetterthecat Well-Known Member
    OR
    13 sport
    I run x2 power agms, 1 as my house battery and 1 as my starter. I did the diode to bump up the voltage, see 14.2 -14.6...battery stays healthy, feel more comfortable running the radio etc for extended periods of time.
    X2 power batteries are re branded northstar. Come with a great warranty.
    habaneroTrd likes this.
  8. Mar 31, 2024 at 1:21 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    My Optima Red Top is reading over 14 volts while the Taco is running, with no diode mod. No issues with the battery staying charged when sitting for weeks. Bonus: The 20 pound weight reduction got rid of some Taco lean.
  9. Mar 31, 2024 at 1:24 PM
    Bishop84
    Bishop84 Well-Known Member
    I rattle my batteries to death and there's always corrosion on my terminals and carrier. I replaced my battery in a hurry and forgot. New one leaks.
    I do highway speeds on gravel roads often as a reference.
    Chew[QUOTED] and chetterthecat like this.
  10. Mar 31, 2024 at 1:38 PM
    chinoxmk22
    chinoxmk22 Well-Known Member
    Mario
    2023 Tacoma
    What is the lifespan of the OEM battery? .
  11. Mar 31, 2024 at 1:52 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    1 to 8 years from what I've seen reported here.
    908tacoma likes this.
  12. Mar 31, 2024 at 1:57 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    80k miles :D
    Mine lasted around 4 years. Bought an Interstate from Napa auto parts and seems to be going well for the last couple of years. OEM battery seemed to produce a lot of corrosion on the terminals while this aftermarket one doesn’t seem so bad.
  13. Mar 31, 2024 at 1:57 PM
    e6400ultra
    NorCal
    Mine started crapping out, and the positive terminal started leaking, at 5 years.
  14. Mar 31, 2024 at 2:20 PM
    BMH
    Bruce
    Thanks for the input so far guys.
    The reason I was looking at a AGM was:
    A: Rated at a lot higher CCA. About 200 amps more than I'll ever need. Just seems nice to have on hand.
    B: Some of the things I've read, they say it has a certain amount of 'deep cycle' properties. Which, since I camp in this, thinking I can run the inverter longer before I have to run the truck to charge the battery back up.
    I wouldn't mind getting a tune to increase the voltage output for a AGM. From what I can tell, it seems like it needs to be bumped up about a volt over stock. Something in the neighborhood of about 14.5 v.
    Can this be programed without changing anything else? I'm perfectly happy with the way the truck is, as is.
    Does the added voltage have any potentially harmful affect on the rest of the truck...? Say, any of the gazillion other little computer modules in the truck? I know there is some lee-way on operating voltage, but I don't wanna push my luck.
  15. Mar 31, 2024 at 3:39 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  16. Mar 31, 2024 at 3:47 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    What "engine running" detect circuit are you using?
  17. Mar 31, 2024 at 4:09 PM
    Toycoma2021
    Since you have 200A more capacity than what you say you need, I see no reason to get a complete charge on the AGM battery regularly; an occasional charge would do no harm and is what I do when I can remember. Deep cycle is what the AGM is for, so I feel you are on the correct path.
    AGMs don't leak and cause corrosion, a plus. The "added" voltage is not added, but lower than what the AGM would like to see with the engine charging. No harm to the truck as its charging voltage is not changing, unless you do a tune. I can't recall any people here on this site using the voltage increased tune reporting any problems with the higher voltage. I regularly see 14+ volts for a brief time while driving. In these trucks the alternator is controlled by a digital signal (LIN), not a voltage regulator; all contained within the alternator.
    A tune can change the charging voltage but is in my opinion, so far (I reserve the right to change my mind), not necessary. You seem to be happy with the truck as it is. You will have to ask the tuner people if they have a discount for a "voltage only" tune. Perhaps one of them will join in the discussion.
    I run three AGMs, no tune, just a solenoid to connect one to the other two. Don't know how many years they will last with refrigerator, winching and who knows what else I will add in the future.
    I hope I have addressed all your questions.
    habaneroTrd and BMH[QUOTED][OP] like this.
  18. Mar 31, 2024 at 4:39 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  19. Mar 31, 2024 at 4:46 PM
    grogie
    The Off-Grid Engineering dual battery kit came with a Blue Sea automatic charging relay. I as well have a dual battery setup in a Jeep with a National Luna split charger.
  20. Mar 31, 2024 at 5:07 PM
    Toycoma2021
    Thanks.
    grogie[QUOTED] likes this.
