Air Bag Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rberumen2, Jan 7, 2010.
  1. Jan 7, 2010 at 8:11 AM
    rberumen2
    rberumen2 [OP] Well-Known Member
    Ralph
    California
    2017 White Tacoma TRD Sport 4x4 DCSB
    Does anyone know how to reset the airbag light. it's buggin me!
  2. Jan 8, 2010 at 2:45 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    It means there is a problem with the system. Fix the problem = no more light.
  3. Jan 8, 2010 at 2:51 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Yeah, you can't reset it. You have to take it to the dealer or a shop that services airbags. Hope that it's not the clock spring, $4-500 to fix and in the meantime your airbag doesn't work.
  4. Jan 8, 2010 at 2:53 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    ^ Excactly. A quick place to check, depending on year, is the harnesses/connectors for the front seat air bags. If you slid something heavy or sharp under your front seats, or had a big alarm or stereo install where the seats may have been removed, these could be damaged. Perhaps not likely but an easy first place to look.
    06Tacooo likes this.
  5. Jan 8, 2010 at 3:04 PM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    Hopefully your situation doesn't turn out like mine seems to be heading.
    My air bag light came on in Dec. I took it to the dealership and they found that the ECU adapter/harness under the steering wheel (where you connect the diagnostic tools) was broken. They could not get a reading from my ECU so they are charging me $300 to fix the harness. After that, they should be able to connect to my ECU and then tell me what the reason is for my air bag sensor coming on.
    $300 + $100 for diagnostic + $$$ for whatever the reason is for the air bag light. This shit is going to cost me easily 1k.
    Plus i need an alignment/rotation/balance bad. Will need new tires pretty soon. HID light just went out. Battery has been dying on me lately (might need new battery). Truck's registration is due in 2 weeks $300 something. Plus a new GF!!
    Ever heard of the saying "When it rains it pours"??
    TacomaNewbie11 likes this.
  6. Jan 11, 2010 at 4:52 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Disconnect the battery for 15 minutes then reconnect, that should reset the ECU. If the airbag light comes back on then you know you have a problem and it wasn't just a glitch.
  7. Jan 14, 2010 at 12:19 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Just noticed this stupid light today. I'll disconnect the battery and see what happens. I bought a new truck to avoid having to put it in the garage as much as my old Ford.
  8. Jan 14, 2010 at 12:29 PM
    rberumen2
    Ralph
    California
    It's just annoying. I don't even care if it works. I just want it off haha
    when I turn on my car it doesn't turn on till I drive away for a few feet. Let me know what disconnecting your battery does? If it works or not
  9. Sep 11, 2011 at 9:14 AM
    en23
    en23 Member
    Eric
    Queen Creek AZ
    06 PreRunner
    What ended up happining with your guys' trucks? My bag light just came on.
  10. Sep 11, 2011 at 6:44 PM
    en23
    en23 Member
    Eric
    Queen Creek AZ
    06 PreRunner
    once you replace the clockpring, does the light go off, or is there another procedure to do?
  11. Sep 11, 2011 at 6:50 PM
    Tacoma Mike
    Southern Maine
    The system does a self check every time you start up the truck and if the problem is not there it will go out.
    However there will be a code stored code..
  12. Sep 12, 2011 at 4:24 AM
    greenacresusa
    greenacresusa New Member
    07 SR5
    After checking several other threads I have a question. The airbag light you all are referring to is the one on the instrument pod below the odometer? Not the one next to the clock? Thanks
  13. Sep 12, 2011 at 8:51 AM
    en23
    en23 Member
    Eric
    Queen Creek AZ
    06 PreRunner
    Is there anyway to get rid of the stored code, or does it not matter? Will it cause it to fail an inspection?
  14. Sep 12, 2011 at 8:52 AM
    en23
    en23 Member
    Eric
    Queen Creek AZ
    06 PreRunner
    I'm talking about the one thats under the tach... looks like a guy with a ball in front of his head.
  15. Sep 12, 2011 at 9:07 AM
    greenacresusa
    07 SR5
    Thanks, just making sure I don't have a problem. We've only had this truck for about 3-4000 miles and weren't familar enough with all the indicators yet.
  16. Sep 12, 2011 at 3:25 PM
    Tacoma Mike
    Southern Maine
    nope
    It goes into history.
    It won't be current or pending.
    Every state is different and we have to make sure the truck does the bulb check and then goes out. means it's a good system.
    I see no reason for a failure for history. Most little pocket scanners only do pending or current.
    I have never failed nor the shop failed a car for history codes. It's just info. not a problem.
    there's a new section called permanent codes and no one can clear those, They go out over a period of time. There would be a lot of failed vehicles for that. I wouldn't worry about it.
  17. Sep 12, 2011 at 9:49 PM
    en23
    en23 Member
    Eric
    Queen Creek AZ
    06 PreRunner
    cool, thanks man.
  18. Sep 12, 2011 at 9:54 PM
    slmgt
    slmgt Well-Known Member
    Greater Seattle Area
    11 TRD Sport w/ JBL DCLB V6 AT
    Husky floor mats (Fr and Rr)
    I tucked my winter tire chains under my driver side seat; is this a safety hazard and if so, why hasn't the light come on?
  19. Jul 19, 2012 at 10:09 AM
    Yournaym
    Yournaym Member
    Sean
    Dallas area
    09 4dr 4whl drv
  20. Feb 24, 2013 at 9:23 AM
    bigcreekcowboy
    bigcreekcowboy New Member
    To hide my lap top I slid it under the passenger seat and now the airbag light is on :mad:. The local dealership is notorious for not honoring warranties and taking every opportunity to rip people off. and there is not another dealership for several hours drive so they can get away with it. I looked under the seat and all the wires look fine. But there is allot more then I was expecting under there. Any ideas where to start looking? Any advice will be appreciated
