Air bubble in heater core
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nalpak99, Jan 9, 2021.
  1. Jan 11, 2021 at 11:15 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    This may be a silly question, but is the coolant level you're checking on from the radiator itself or the overflow? I'm leaning toward saying your head gasket is fine, but a compression test or boroscope would shed more light on that. However, you'd likely see low coolant at more than just the heater core and your climate would be exhibiting more and more issues with heating as the coolant got lower. Also, have you worked on the cooling system at all recently?
  2. Jan 11, 2021 at 11:19 AM
    Nalpak99
    Nalpak99 [OP] Booty Hunter
    Kyle
    2005 Toyota Tacoma pre-runner
    mid travel
    i use the overflow to see the level
  3. Jan 11, 2021 at 11:22 AM
    RedWings44
    Michigan
    Check the radiator itself. Sometimes that can be low and the overflow be fine. Again, you'd likely see other symptoms, but still. It doesn't make much sense, but I've seen it happen on 2 different vehicles
  4. Jan 11, 2021 at 11:23 AM
    Nalpak99
    Kyle
    mid travel
    i could also bull the plugs and check if they are clean or dirty. do u think that would help?
  5. Jan 11, 2021 at 11:26 AM
    RedWings44
    Michigan
    Yes, it could help, but may not tell you everything. My suggestion is, after checking the coolant level, I'd do as another suggested and allow the truck to come up to temp and park it on a slight incline. Then let the truck run on full heat for a bit. Check the radiator level after that, although make sure you let the truck cool before you check the radiator lol.
  6. Jan 12, 2021 at 8:44 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Not silly, very possible. I had that problem on a different truck, overflow full but rad would get low. Small hose from rad to tank had a clamp on the tank end, but not the rad. Didn't leak coolant, but no vacuum to draw out of the tank. Small clamp fixed it. Then I replaced the water pump coz it was weeping, thus the low coolant.
    RedWings44[QUOTED] likes this.
  7. Jan 12, 2021 at 8:48 AM
    Nalpak99
    Kyle
    mid travel
    coolant level fine in rad too. going to bleed the air out today and see if it comes back. I'm thinking I got air in the lines because of offroading, bouncing off of rocks and stuff will cause the coolant to slosh arround.
  8. Jan 12, 2021 at 8:53 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Because the bible (aka FSM) tells us to
  9. Jan 12, 2021 at 8:55 AM
    TireFire
    Olympic Peninsula
    Pretty sure on these trucks the WP has a weep hole and a little coming out isn’t bad nor does it warrant replacement
  10. Jan 12, 2021 at 9:34 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Different truck, same type weep hole. Refilling tank weekly does warrant replacement.
    Jimmyh likes this.
  11. Jan 12, 2021 at 9:36 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Pressurized cooling system, no way for air to enter even if the truck is upside down.
    Jimmyh, TireFire and 6 gearT444E like this.
  12. Jan 12, 2021 at 10:23 AM
    TireFire
    Olympic Peninsula
    If it’s that excessive, sure. But, look up TSB 0117-11. Toyota claims these have an “ejection” port to weep temporarily, which - as stated above - does not indicate a failed W/P
    Jimmyh likes this.
  13. Jan 12, 2021 at 1:11 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    But you need to understand what is happening.
    TireFire[QUOTED] and Too Stroked like this.
  14. Jan 12, 2021 at 1:12 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Well it does tell you that the pump mechanical shaft seal is leaking.
  15. Jan 12, 2021 at 5:20 PM
    #35
    TireFire
    Olympic Peninsula
    Sure, it was a bit tongue in cheek. Just wanted to note that it says so in the FSM :)
    Jimmyh[QUOTED] likes this.
  16. Jan 12, 2021 at 9:16 PM
    #36
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    don't care what the Toyota TSB sez, I WAS TALKING ABOUT A DIFFERENT TRUCK. Don't care if there is a TSB for any vehicle, refilling weekly is excessive. To me. YMMV.
  17. Jan 12, 2021 at 9:40 PM
    #37
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If the coolant level is always spot on and doesn't drop slowly over time the headgaskets are fine
  18. Jan 12, 2021 at 9:56 PM
    #38
    TireFire
    Olympic Peninsula
    Curt much?
    WHY ARE YOU YELLING AT ME?
  19. Jan 13, 2021 at 8:58 AM
    #39
    Nalpak99
    Kyle
    mid travel
    i tried to bleed it with the funnel but the air is still in there
  20. Jan 13, 2021 at 7:00 PM
    #40
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Coz I thought you were my wife. She is hx989 too. :boink:
    TireFire[QUOTED] and Jimmyh like this.
