Air compressor options
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NMTrailRider, May 20, 2016.
  1. May 20, 2016 at 8:44 PM
    NMTrailRider
    NMTrailRider [OP] Well-Known Member
    New Mexico
    id like to pick up an air compressor just to throw behind my back seat for emergency situations and airing up when needed. Can anyone recommend one? I don't want a cheap-o $19.99 Walmart one. But don't want super expensive either. I'm thinking $50-100 range? What should I get? Amazon preferred.
  2. May 20, 2016 at 8:50 PM
    BrutalityBob
    BrutalityBob Well-Known Member
  3. May 20, 2016 at 8:51 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I've got this one mounted as an OBA compressor. It runs my locker and inflates all 4x32" tires in about 10 mins.
    Smittybilt 2780 2.54 CFM Universal Air Compressor https://www.amazon.com/dp/B004K296N6/ref=cm_sw_r_other_apa_pR9pxbX8X03SM
    And another similar one
    Q Industries MV50 SuperFlow High-Volume 12-Volt Air Compressor https://www.amazon.com/dp/B000BM8RT8/ref=cm_sw_r_other_apa_FS9pxb5SV7GC1
  4. May 20, 2016 at 8:52 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    That one works but it takes a lot more work if you want to upgrade it to a hard mounted OBA
  5. May 20, 2016 at 8:55 PM
    BrutalityBob
    Whats the reason for going hard mounted? Its small, portable and fills things with air. Dont think id need anything more fancy then that
  6. May 20, 2016 at 9:01 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    I got a pancake compressor from Harbor Freight which was around $50 after coupon & has low enough draw that I can plug it into the outlet in the bed. Maybe not small enough if you're looking to leave it in the truck though. I also don't know that I'd trust a HF el cheapo compressor to survive years of vibrations & bumps even though they vibrate when they're running.
  7. May 20, 2016 at 9:06 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Air locker and constant use filling tires after offroading. We don't know the full extent of OPs uses so I was throwing it out there.
  8. May 21, 2016 at 2:23 PM
    k3v11n
    k3v11n Yeah? No!
    Oahu, Hawaii
    2015 SR PreRunner Oahu Edition
    PlastiDip
    He states it is for emergency uses and airing up. :thumbsup:
    I have friends who use the Viair 00088 88p.
    http://www.amazon.com/Viair-00088-8...=UTF8&qid=1463865679&sr=8-1&keywords=viair+88
    NMTrailRider[OP] likes this.
  9. May 21, 2016 at 3:55 PM
    NMTrailRider
    New Mexico
