Air Conditioner Dial: Either Full-Blast or Off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Raymondo17, Sep 4, 2019.
  1. Sep 7, 2019 at 8:36 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  2. Sep 7, 2019 at 11:48 PM
    Raymondo17
    Raymondo17 [OP] Well-Known Member
    Ray
    Sacramento
    '06 PreRunner
    I’m not quite sure whether it’s, shall we say, 2nd gear or 3rd gear that’s working along with 4th gear (full blast). I just know it’s not 1st.
    TnShooter likes this.
  3. Sep 8, 2019 at 5:30 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    You've replaced the resistor and plug 5x? There's either something else wrong or you're not crimping the splices very well imho.
    Crimp tools that crimp on the other side of the pivot work best. The ones with the crimp die between the handles require a lot more effort to get a decent crimp.
  4. Sep 8, 2019 at 7:53 AM
    Raymondo17
    Ray
    Sacramento
    '06 PreRunner
    >Before you redo the wiring, check the NEW resistor.<
    After installing the resistor, I plugged in the old harness and checked to see if it worked. Worked perfectly. I then proceeded to clip off the old harness and install the new one, with less than stellar results. So unless checking it could have blown the new resistor, it’s probably my lame first attempt at crimping wires. (My crimper is a between-the-handle unit on my wire stripper, so that’s probably not helping things.)
  5. Sep 8, 2019 at 11:23 AM
    Raymondo17
    Ray
    Sacramento
    '06 PreRunner
    Ok, I went out and attempted to start from scratch, cutting off the old butt connections and this time using the ol’ reliable wire nuts to connect the wires. But now I’m back to the AC being either full blast or off.
    I’ve never used a multimeter before but tried my hand at it. I set the knob to ohms and put the probes in slot one and three on the new resistor. The multimeter displayed “OL”. (Overload?) so I stepped away from the multimeter and resisted the urge to crack open an early morning beer.
    Could I have blown the new resistor in my feeble attempt at wiring the new harness?
  6. Sep 8, 2019 at 1:42 PM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    OL simply means there is no continuity between those two slots. I've never had a problem with my resistor so I don't actually know if there should be.
  7. Sep 8, 2019 at 3:15 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    I suggest you watch or read few tutorials. Knowing what you are reading on a multimeter is more than half the battle.
    https://www.google.com/search?client=firefox-b-1-d&q=how+to+use+a+multimeter
  8. Jan 21, 2023 at 2:26 PM
    Blkturbo!
    Blkturbo! Well-Known Member
    Sean
    Henderson, NV
    08 Tacoma; 05 Seadoo RXP; 94 Turbo Supra
    Icon Coilovers, Downsouth UCAs, rear Icon "2.5" shocks and Toytec single AAL. Still gotta do exhaust, dark headlights and re-gear the rear diff.
    Is the Amazon kit made by Toyota or aftermarket? It appears to be aftermarket, in which case, i gotta ask why not just replace resistor with the OEM unit? Just asking in case im missing some reasson or another. Thanks
  9. Jan 21, 2023 at 3:54 PM
    TnShooter
    Deogee
    STOCK
    Blkturbo![QUOTED] likes this.
  10. Jan 21, 2023 at 5:08 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    is this not a sticky? i mean used Tacomas should have one in the glove box at this point.
    up under the dash behind the glovebox, and like $20 its fixed
  11. Jan 24, 2023 at 12:11 AM
    Blkturbo!
    Sean
    Henderson, NV
    TnShooter[QUOTED] likes this.
  12. Jan 24, 2023 at 6:01 AM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Someone here told me to keep a small bottle of electrical spray cleaner handy and use it whenever it starts happening. I have to use it about twice a year for last three years and it works. Just unplug it, spray, let dry a minute and you're good
  13. Jan 24, 2023 at 5:18 PM
    Blkturbo!
    Sean
    Henderson, NV
    For $70-80, I'd get the Toyota replacement parts and sleep well at night knowing i'm not going to find myself offroad somewhere with an electrical fire. Like what nearly happened 2 weeks ago. OEM on Amazon and, also, the dealerships are aware of these parts and stock them...I just now got home from Toyota with the stuff.
    Here are the OEM units on Amazon for $70
    Amazon.com: TOYOTA Genuine Updated Blower Motor Resistor & Pigtail Connector for Tacoma 2005-2017 - Parts 82141-04Q80 & 87138-04070 : Automotive
    Otherwise, my suggestion would be to keep a fire extinguisher in your truck if you plan to continue ignoring it like I tried to do since a year ago.
    An $80 electrical fire from something so simple isn't worth losing my truck over, particularly with today's vehicle inventory and costs.
    dirtnsmores[QUOTED] likes this.
  14. Jan 24, 2023 at 7:27 PM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    That's good to know I didn't think something like that would cause an electrical fire
  15. Jan 26, 2023 at 8:59 AM
    #35
    Blkturbo!
    Sean
    Henderson, NV
    I ignored it for a year or more while simply not using my 3rd fan speed - since that’s the only thing that caused a burning smell back then. Suddenly, 2 weeks ago it was worse than ever and could start seeing a hint of smoke in the cabin and I could smell it under the hood too. Burnt my harness clip all the way through.
  16. Jan 26, 2023 at 9:19 AM
    #36
    Blkturbo!
    Sean
    Henderson, NV
    Ok everyone with experience replacing these parts:
    I installed my new resistor and harness and everything works fine EXCEPT now I get a loud electrical kind of ticking noise from under the hood whenever I use the heater on the upper dash vent position (And if the AC button is turned on).
    All else is perfect. WTF is that noise I’m getting which seems to come straight from the AC compressor under the hood?? Ughhh
