Air conditioner won't turn off
Discussion in 'Technical Chat' started by gns, Apr 28, 2010.
  1. Apr 28, 2010 at 10:10 AM
    gns
    gns [OP] New Member
    Greg
    Cincinnati
    2010 Dbl Cab LB TRD Sport
    I just bought a new Taco and the air conditioner won't turn off. The button is lit up and won't turn off when I push it.
    Also the Rec button turns on when I start the truck. It, however, will turn off.
    I have a service appt but I wondered if anyone has seen this before.
    Thanks, Greg
  2. Apr 28, 2010 at 10:16 AM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    Turn your temp knob one click clockwise. You're on the MAX setting where everything kicks into overdrive.
  3. Apr 28, 2010 at 10:20 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Welcome to TW. The 2009 and 2010 trucks have some new logic in the A/C system. Some of it is designed to minimize fogging. However, I have not heard of your situation before.
    EDIT: Btkicker is correct, if your Air mixer switch is on Max A/C you will not be able to disable the A/C compressor.
  4. Apr 28, 2010 at 11:21 AM
    gns
    gns [OP] New Member
    Greg
    Cincinnati
    Thanks. I did have it set to Max AC. I appreciate the prompt answers.
  5. Apr 28, 2010 at 11:37 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Welcome to TW
    :taco:
  6. May 3, 2010 at 4:02 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    If I have it selected to max AC and turn off recirculate, or move it one click clockwise, is this the same AC temp, or does the one click clockwise make it warmer.
  7. May 4, 2010 at 12:24 PM
    btkicker
    Denver
    Same temp (ie ZERO heater core air will be used), it just turns off the REC if you had it on MAX.
  8. May 4, 2010 at 12:34 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    ^TY, I will continue to be lazy and not go the extra click and turn off recirc if I want fresh cold air.
  9. May 29, 2019 at 9:49 AM
    TacomaEd15
    TacomaEd15 Well-Known Member
    Ed
    communist state of NJ
    First Tacoma CPO 2015
    This is truly amazing. It works like a charm. I bought my 2015 Taco Dec 18. I keep the AC on pretty much year round for the defogging. I’m in NJ. While I didn’t have an issue with the ac not turning off previously it just started now. This little trick works!
